2006 Kia Rio Logo
bradley fosberg Posted on Aug 20, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My code reader gave two codes, P0077 and the same one but on the right side of screen had a p/d, what does that mean, i replaced high bank 1 02 sensor and got rid of the code now just stuck on the other one
allobd2
Level 3:
Genius:
  • Kia Master 1,207 Answers
  • Posted on Aug 21, 2012
allobd2
Kia Master
Level 3:
Genius:
Answers
1207
Questions
5
Helped
420033
Points
3657
The P0077 means Intake Valve Control Solenoid Circuit High.
you should try to clear the fault code, if it is still on, you must take it to car repair shop.
car diagnostic tool
Anonymous
Level 2:
Sergeant:
  • Expert 312 Answers
Anonymous
Expert
Level 2:
Sergeant:
Answers
312
Questions
Helped
117148
Points
983
Code p0077 = valve solinoid
4 Related Answers
Anonymous
  • 1986 Answers
  • Posted on Sep 08, 2009
SOURCE: engine light on code po141 oxygen sens bank 1 sens 2
bank 1 will be whichever side cylinder 1 of your engine is and bank 2 will be the opposite side. It's named bank 1 and bank 2 so that no matter how the engine is laid out, bank 1 is always on the same side as cylinder 1. I cannot say whether the right hand or the left hand one will be bank 1 as I do not know where your cylinder 1 is. The garage should know
Anonymous
  • 17 Answers
  • Posted on Dec 13, 2009
SOURCE: 2002 kia sportage with P0171 diag code. Fuel
you have a vacum leak either in a hose or a vacum cap, check all hoses and caps, replace questionable peices
Joseph Prosser
  • 780 Answers
  • Posted on Nov 11, 2010
SOURCE: I have a P0011 "Camshaft Position/Bank 1 code.
OK check the CMP sensor connector for cleanliness, sometimes oil can get in and disrupt the signal transmission to the ECU. Check the wire loom continuity all the way back from the CMP to the ECU. If the error code persists remove the cam sensor, clean its tip of any debris and refit.
Testimonial: "Thanks joe2mercs...you had the problem diagnosed correctly. Cleaned and light has not come back on. U saved me a lot of $."
david balderston
  • 437 Answers
  • Posted on Feb 09, 2011
SOURCE: 03 kia spectra, what do I need to replace or fix,
this means you have a bad convertor one the side of cyclinders 123
I changed my mass air flow sensor and still wouldn't start put code reader back on gave me same code po174 but now tells me that my oxygen sensor or O2 sensor bank 2
code p 0174 refers to system too lean--bank 2===causes ---intake /exhaust leak---fuel pressure/ pump---injector/s ---AIR system---hose connections
Replace the heated oxygen sensor (HO2S) in the exhaust manifold before the cat converter bank 2 as it is the principle controller of the air/ fuel mixture
1helpful
Engine light is on
code p0077 refers to intake valve control solenoid , bank 1--circuit high===causes --wiring short to positive---intake valve control solenoid---ECM
You do have a problem but as yet you have not noticed the lower performance
Renault 2008 trafic
P0077 Intake Valve Control Solenoid Circuit High (Bank 1)
P0078 Exhaust Valve Control Solenoid Circuit Malfunction (Bank 1)
These are the codes my records show but i dont think this is right so check with the code reader makers
1helpful
O2 sensor
You have a lean condition that drove the sensor high
& that is where it is staying
If you could put an oscilloscope on it, you would see it
is not switching.
I would check fuel trim on both banks first,then work on
the right side,if you find only one side with issues
Exhaust System Leaks on bank one
Loose O2 Sensor on bank one
Bad Converter on bank one
Is that code combined with other codes?
You may not know, as a code reader won't
get you what I'm asking for,only professional
software will
Broken Connector !!! What was repaired & how
That maybe the whole issue as an O2 is an output
sensor with a narrow voltage band & goes between
.02 &.075 volts
The sensor could be bad
You replace upstream sensors every 100,000 miles
Error code p0077 p/d
Hi there:
P0077 - Intake Valve Control Solenoid Circuit High (Bank 1)
Check in this link page 22: FSM//H4SO%20Engine/GD(H4SO)%20General%20Desc.pdf
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
What does code po077 mean
P0077 HYUNDAI - Intake Valve Control Solenoid Circuit High Bank 1
Possible causes- Intake Valve Control Solenoid Circuit Bank 1 harness is open or shorted
- Intake Valve Control Solenoid Circuit Bank 1 circuit poor electrical connection
- Faulty Intake Valve Control Solenoid Bank 1
2answers
P0138 and p0158
These codes, po 138 bank 1 sensor 2 shorted to voltage and code po158 means bank 2 sensor two shorted to voltage. these are the two rear oxygen sensors in the exhaust system. there two up frt and two in the rear, check the wiring on the two rear sensors, make sure that the wiring is not cut or stuck between metal. if the wiring is good then replace both rear sensors, when you get them ask for the left and right after the cat sensors. or bk1 s2 and bk2s2. after replacing them reset the computer. go to an auto parts sotre or if you have a code reader you can do it. hope this helps good day.
4helpful
2answers
Error code p0032 on 2004 dodge caravan. what is the code?
Hi.
P0032 means HO2S Heater Control Circuit High (Bank 1 Sensor 1).
It means high impedance from O2 sensor, check wiring to sensor and replace the sensor.
Check O2 sensor located in bank 1 (cylinder 1 side- see here), and after the catalitic converter (there is also an O2 sensor before cat converter).
1helpful
My 1996 F150 says PO174What does it mean
bank two is on the drivers side. cylinders 1234 right side, Bank 1, 5678, bank 2. you have something like a vacuum leak effecting one side only. Not all code readers come up with all the codes. Its possible you have other codes possibly on the bank 1 side also. If you have a K/N filter it could of deposited oil on the MAF sensor on the intake there or you may have a clogged air filter. . If you really only have one code for one side you may have an intake gasket leaking or the egr may be stuck open a little which could effect the idle quality.
Top Kia Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Kia Expert? Answer questions, earn points and help others
