Question about Kodak ESP 5 Printer
My Kodak ESP5 keeps saying "Paper Jam please remove paper jam" But there is no paper in it?
  • 5 more comments
  • Fifthoctave Jan 30, 2009
    I have the same issue. I have the same printer, brand new and as soon as I turn it on it makes a load crunchy noise and the screen reads:
    "Error. Paper Jam. Clear Jam. Press OK to continue."
    Any ideas?
  • Anonymous Feb 05, 2009
    i called the support center and they sent me a new one
  • Anonymous Feb 21, 2009
    there has definatley not been any paper jammed. Message just came up when i turned it on. Tried all sorts...still a problem
  • Anonymous Feb 22, 2009
    I just bought this printer, and it keeps telling me there is a paper jam! There is no paper in it!
  • tuba1983 Mar 03, 2009
    My ESP 5 also says "paper jam," even though there is no paper in it. I appreciate the advice. I am going to call technical support when the call center opens in a few minutes. I did not save my receipt from where I purchased it though. I hope that will not prevent me from being eligible to receive a new printer.
  • phillyherb Apr 01, 2009
    I have the same problem, believe it or not, I am about to get my 5th Kodak ESP printer in less than 3 months, They (the service reps) don't seem to have any answer for this problem and now that I see this site, I see it is a problem for many out there.
    They just keep sending me new ones and pretty much say "good luck this time". I am sure many are as frustrated as I am.
    I need my printer, not excuses.
    Herb
  • Anonymous Apr 14, 2009
    This printer is terrible, get a canon
My esp 5 gave me this same message. I'm not an expert but here is what worked for me.
I turned off and disconnected both cables (usb and power) then reconnected and turned on.
At this point it still read paper jam, so I took ink cartridges out and paper out.
I then reinstalled ink cartridges and PULLED OUT THE PAPER TRAY to it's FULL capacity, added about 5 sheets of paper, and on the main menu I chose the allignment function and printed a test page and suddenly....no jam!
Hope this works for someone. For some reason pulling the tray all the way out cleared the "jam" message for me. Now if I could just get the new ink cart to work I'd be all set! Good Luck!
Posted on Jul 21, 2009
Had the same problem,paper roller feed not working.Contacted Kodak online they sent me a replacement printer,now OK
Posted on Feb 08, 2009
We have a sp 3250 all in one printer. We had a paper jam. We removed the paper jam and now the printer is telling us that there is still a paper jam. Please tell me what to do next. Thank you.
It is just sensing as if you haven't yet removed the jam. So, while switched on, keep pressing the load or toner or cancel buttons on top. Also make sure you cleared the printing queue that was instructed when the paper jammed.
Dec 04, 2010 | Kodak Esp 3250 Allinone Multifunction ( ...
Error code 3528 keeps coming up,telling me to remove back cover and remove paper jam then replace back cover.there is no paper jam,checked printer heads no paper anywhere?
I have this printed and if you read (carefully) through the manual it tells you it doesn't like single sheets of paper. If ever my paper feeder tray runs below say 3 sheets then this error will crop up so keep it topped up with paper. The same goes for photo paper too.
Sep 13, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
How to fix paper jam in kokdak esp5 printer
www.kodak.com/go/itg
Select all-in-one printer
Select paper jam and follow the steps
Jan 15, 2010 | Kodak ESP 5 Printer
I have a ESP5 printer. There is an error message that says I have a paper jam, but I cannot find any paper.
A Piece of Paper may be in there. Find out it by replacing Catridge. Off the printer switch, See inside, out the paper from tray. Then keep it one by one.On Printer
Dec 10, 2009 | Kodak ESP 5 Printer
Paper Jam
Refer to www.kodak.com/go/itg and select all in one printers and then paper-jam . it will step by step show you on how to remove the paper-jam. if the printer does not work,after those steps Call kodak @ 1800 421 6699 and they will replace the entire printer for you free of cost.
Jun 28, 2009 | Kodak ESP 5 Printer
Screen says paper jam, can't find anything
close properly your paper jam cover at the back of your printer down side. if not clean and check the sensor for paper jam.
May 20, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Paper jam error light on kodak esp 5
  1. Remove the paper tray.
  2. Disconnect the power cord, wait 5 seconds, then reconnect the power cord.
    NOTE: The printer will reset and eject the paper. If the paper does not eject, try to remove it manually.
  3. Replace the paper tray.
  4. Press the Print button on the printer to resume printing.
Apr 01, 2009 | Kodak ESP 5 Printer
Kodak ESP5 Printer - actual paper jam
you can pull it out from front and if you don't want pul it out from front just open up the cover of roller then take off the paper.
you are done
Good luck
Feb 09, 2009 | Office Equipment & Supplies
Paper Jam
on the back release the cover and pull it out. you cant release the tension.
Jan 27, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak ESP 5 Printer Logo
2,423 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
