Question about Kitchen Ranges
Upper oven door won't close properly.
Appears to be a gap at the bottom, heat escapes around door.
You will need 2 new door hinges as they go weak after a time.and people tend to rest things on the door when open this will also weaken the hinges.they can be puchashed and fitted by anyone who is handy.(ie) not a big job only a few screws..hope this helps
Posted on Dec 20, 2008
GE under oven drawer sags, won t close properly, big gap exists between drawer face and oven door.
Don't look too hard for a solution to the problem. I have seen this same issue with three or four other manufacturers brand stoves. Not sure why they can't build a drawer that won't bind and stick, but they seemingly cannot.
Jan 06, 2015 | GE Stove/Oven/RanWhite Glass Top -...
Kebs208dss11 model double oven. When upper oven is on with door closed, steam can be seen escaping from top of door. Door is closed all the way. Even when putting pressure on door to make sure it is...
The first thing I'd suspect is a poorly fitting door seal / gasket. This will permit the heat inside the oven to escape. Check to be sure the the one installed is defective (cut, split, frayed, dislodged, etc.) Replacement parts:
Make sure this is the part you need before ordering.
Feb 25, 2014 | KitchenAid Ovens
Oven door will not fully close allowing heat to escape and light stays on
Is the door locked? if it is it won't close all the way if it was in the locked position before it was closed. like if it was programmed for "self clean" without the door being closed, the lock would be engaged still.
Jun 09, 2012 | Electrolux EW30ES65GS 30" Slide-in...
I have an ILVE oven and the door is not closing properly so heat is escaping from top left and right sides, discolouring the white frame polyurethane. How do I adjust the door so that the bottom comes out...
Hi david23413, it's the ILVE service team here. Please contact our Service Manager, Peter Dale, on 02 8569 4672 to discuss your issue further.
May 22, 2011 | Ovens
Oven takes forever to heat up - its a thermador double oven - me272
Hello- Check these things first-  Door seals tend to get stiff over time. This is normal. Door hinges can become loose or get bent a bit, causing door to not close tight. This little gap can allow heat to escape, causing extended pre-heat times and frequent cycling of elements. If door doesn't seem to pull shut tightly- hinges will need to be replaced. If oven appears to operate normally otherwise, this should solve problem.  Let me know if the info helps- have more if needed- Thanks  - Ed
Mar 17, 2010 | Thermador C272 Electric Double Oven
Oven door does not close fully
You need to replace the oven door hinges.
Please rate my solutrion.
May 15, 2009 | Neff B1421 Electric Single Oven
Well firstly if the door wont close properly you shouldnt use this device as if you are in the kitchen whilst it is in use your slowly cooking yourself . If the door is open microwaves can escape and that is Radiation Lethal if you get too much or too close ?.
The reason it is not heating is probably because most of the microwaves are escaping and not bouncing around your oven cooking your food .. but actually bouncing around your home cooking you . My advise to you is get it repaired by a qualified Domestic appliance engineer or bin it and get a new one ..
Regards Vortash
May 12, 2009 | Microwave Ovens
Beko SC152 oven door will not close properly, couple of mm gap at the top and heat is escaping, please help regards adele
your door hinges are probably worn,theyre under spring tension.
go to your local appliance repair shop with the model number and they can order you some,or arrange to do them.
hope this helps.
Mar 23, 2009 | Ovens
Toaster Oven Repair
Toaster switch does not stay down. I have to hold the switch down to get toast. The heating element works fine as does the oven. Can we fix the switch? Or, do you know someone to whom we can send it for repair? Thanks!
Sheila Newton
Winston-Salem, NC
Aug 16, 2008 | Toaster Ovens
The oven door are not closing all the way
spot, Maytag put out a service bullitin on this issue....TDC-0017B-B, They put out a new hinge kit...part #12002111 for single and 12002112 for double units. This may be covered under this service flash. Call Maytag service and inquire about the above mentioned service bullitin. Problem addresses doors not back.
Sep 03, 2006 | Jenn-Air WW30430P Stainless Steel Electric...
Kitchen Ranges Logo
83 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
