Question about Samsung YP-U2X Digital Media Player
How do I f/w update??????
I have a samsung m230 version YP-U2J, and since about a week ago whenever I turn it on, the screen says "Need to format with f/w updater". THen it automatically turns off. I plugged it into the computer, and Napster didn't recognize it, although usually it does. I clicked Update Napster when my mp3 player was plugged in, but nothing happened. I really need help, I can't afford to get a new mp3 player!!!!!!I would really appreciate your help, if I figure it out before anyone helps, I'll notify you. THanx so much!
  • 2 more comments
  • Anonymous Nov 18, 2007
    I've resetted the player... i've tried everything i could think of and when i turn it on it says mldb error and then it says needs to format with f/w updater....
  • Anonymous Aug 08, 2008
    its a stupid piece of **** thats what this thing is!
  • Anonymous Mar 05, 2009
    hey i have a samsung mp3 player YP-MT6 and every time i plug it in it says need to f/w update , what do i do ? i tried what u guys said on top but nothin happend
  • Bkferguson May 11, 2010
    need help
    Scholar:
  • 121 Answers
Here's the site with the firmware upgrade download: http://www.samsung.com/support/productsupport/download/Model_Select.aspx?type=Digital+Audio+Player(YEPP)&typecode=200600&subtype=Yepp&subtypecode=200601&model=YP-U2JQB/XAA&filetype=FM&language= although I'm sure that the f/w updater is within this program here: http://www.samsung.com/support/productsupport/download/Model_Select.aspx?type=Digital+Audio+Player(YEPP)&typecode=200600&subtype=Yepp&subtypecode=200601&model=YP-U2JQB/XAA&filetype=SW&language= That should help you with your problem. First download and install the first link, then use the tools that are within that program. Once finished, update it with the firmware update and you should be alright.
Posted on Apr 02, 2007
  • Joshua Hori
    Joshua Hori Apr 02, 2007
    I meant to say download and install the second link first...
  • Joshua Hori
    Joshua Hori Apr 10, 2007
    At least state what happened...Did you use the f/w updater, and if you did, what happened afterwards?
I has the same problem. You have to push the play button (hold it down), plug it into the computer and continue to hold it down until the computer finds the hardware (about 10 seconds). After that I was able to launch the firmware update. It found the device and installed the new updated firmware. After completion, the device worked fine.
Posted on Dec 24, 2008
I just went through this today and had to call 1(800)Samsung to resolve. There is a reset hole on the end opposite the USB connector but pressing it made the problem worse (now it boots to 20% and just powers off with no messages). I downloaded the firmware updates but the software could never find the player even though when I plugged into the USB port Windows would see SOMETHING was plugged in.
First make sure the firmware updater software is installed on your PC. Then the key to the fix is to take the player, press and hold the Play button (on top, same as power) and while holding it in then plug into the USB port. Windows hardware wizard will launch. Tell it ok and let it auto find the drivers. From this point when its all done now launch the same software and relaod the firmware and resync from WMP.
Posted on Dec 16, 2007
SOURCE:
Occuring the problem when turning on with the title"bulding eror"
Click here for Firmware Update from samsung.com
Here is the instruction for updating the firmware:
  1. Download the YP-U2J Updater
  2. Remove Mp3 player if you already connected to the USB port
  3. Run the program (You should see something like: Please connect the device)
  4. Hold down the Play button and connect the Mp3 Player to USB port(Hold down the play button while you connect the device, you should seea message (normally after 8 seconds) like: Initializing on YP-U2J Updater program screen)
  5. After you hear the Windows chime "new device found" or the message"Initializing" on YP-U2J Updater, you can now remove your hand fromplay button.
  6. Check the Format Data Area checkbox (By clicking the yes button, you will lose all of your data in your Mp3 player)
  7. Click the "yes" button
  8. Finally, click on the Start button (takes less than a minute). DO NOT REMOVE YOUR DEVICE
  9. IMPORTANT: After updating the firmware, you MUSTdisconnect the Mp3 player and turn it on. You will see a 20% messagefor about 50 seconds and it will be restarted automatically.
Dec 13, 2008 | Samsung YP-U2X Digital Media Player
Samsung YP-U2J
Hi dear :
your mp3 player is need to update firmware version to install in it.
So go to samsung site and pick your firmware. and update it now
i hope its start regularly...........
Oct 10, 2008 | Samsung YP-U2X Digital Media Player
Samsung YP-U2 & Windows Media 11 on Vista Home Premium
CLICK Here to Download : Firmware Update
This error is common with Windows Media Player
Here is the instruction:
Update: Pleasekeep in mind that if you sync your Mp3 player with a computer that hasa Windows Media Player 9 or 10, you should do these steps again
Aug 22, 2008 | Samsung YP-U2X Digital Media Player
PROBLEMAS CON MI SAMSUNG YP-U2J
YP u2 J is only audio player? Can it be used to store pictures from pc and tranfer them to digital picture frame?
Jun 20, 2008 | Samsung YP-U2X Digital Media Player
YP-U2J - Need download - Didn't come with CD
In case you have a problem to connect your Samsung YP-U2J Mp3 player, you should update Firmware to get it working. The new Firmware may be downloaded from Samsung.com.
In case u have WMP 11 and player not working, this error is common after installing Windows Media Player 11
  4. Hold down the Play button and connect the Mp3 Player to USB port (Hold down the play button while you connect the device, you should see a message (normally after 8 seconds) like: Initializing on YP-U2J Updater program screen)
  5. After you hear the Windows chime "new device found" or the message "Initializing" on YP-U2J Updater, you can now remove your hand from play button.
  9. IMPORTANT: After updating the firmware, you MUST disconnect the Mp3 player and turn it on. You will see a 20% message for about 50 seconds and it will be restarted automatically.
Update: Please keep in mind that if you sync your Mp3 player with a computer that has a Windows Media Player 9 or 10, you should do these steps again
Jan 27, 2008 | Samsung YP-U2X Digital Media Player
Mp3
Follow these steps:
Jan 04, 2008 | Samsung YP-U2X Digital Media Player
Cannot use my player-device manager problem/deleting files
This error is common after with Windows Media Player 11
Jan 01, 2008 | Samsung YP-U2X Digital Media Player
Yp-u2j
My samsung yp-u2j is not connecting, its realy pissing me off, because my cumputed wont download the new hardware i need...
Dec 08, 2007 | Samsung YP-U2X Digital Media Player
YP-U2JXB & YP-U2JZW Won't sync...Help!
Error C00D1236 virtually always indicates one of two things:
1) The device is trying to sync hidden files--are there any?
2) There is licensed media that is being synced, and the license is either corrupt or has expired. If you have any licensed media, then try going back to where you purchased it (in an iTunes-like music management program? In WMP?) and refresh/renew the license.
The bad news is that until C00D1236 is resolved, you can't sync your device. frown.gif
You can bypass syncing, and directly transfer files, In my computer, the mp3 plaer will be shown as a drive.
Now if one of the two solutions above is not feasible for u, try this:
Nov 22, 2007 | Samsung YP-U2X Digital Media Player
YP-U2J MP3 PLAYER
hmm i got the same problem as jenn1519 ill plug mine in and when i usually plug it in the computer makes a bing noise like it recognizes that its in the usb plug but 2 seconds later it will make the bong noise that i unplugged it which i didnt so i cant put any new music on. it will charge but it wont let me get any music on. and windows doesnt read that its in there.
and also my mp3 player is very important for me its a gift from a friend so plzz plzz help ? :(
tanko!!!
its ma emil add hot_chilligirl@yahoo.com.au
Sep 11, 2007 | Samsung YP-U2X Digital Media Player
Samsung YP-U2X Digital Media Player Logo
786 people viewed this question
Top Samsung Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
