Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Craftsman chain drive is 1994 and has worked fine. Recently door would not close. Manual indicates sensor mis alignment. I have re-aligned and door will work a couple of times or not at all. Receiver green LED is very dim or not lit. I checked voltage at each sensor 6 volts. I also switched sides with sensors same issue only with receiving sensor. Sending eye lights receiver eye doesn't . I don't think it alignment as I have moved receiving sensor around a lot with no long lasting effect. Seems like receiver on some occassions will work for 1 or two cycles of door then green LED will not stay lit. I have read that I may need to sequence the sending sensor to the recieving sensor. Is there a way to isolate to see if the recieiving sensor is bad or if the unit has a bad control board at the unit.
    Champion:
  • 244 Answers
Problem is probably alignment of sensors. clean off lenses too. you replace them in pairs, but i doubt you need to.
Posted on Jan 15, 2009
My garage door does not want to close but it will open with no trouble I reset it but it still does the same thing the one I have is 1/2 HP model #139.54985 can you help me?
You need to check your sensors first. If they are lit and aligned, increase your down force. Have you recently had the springs adjusted or serviced by a garage door tech? If so, force probably needs to be adjusted and the tech failed to adjust it accordingly. If not, one of your sensors is probably misaligned which is usually the problem.
Mar 01, 2015 | Craftsman 1/2 HP CHain Drive Garage Door...
Why will the doors go up on my garage door opener but not down using the remotes. It works fine using the keyboard.
It is your remote control that is not functioning when the down button is pressed. There is no easy way to test the remote but the small light on the remote should flicker we the button is pressed. If it does not flicker press down hard on the button a few times in effort to get the light to flicker as that will be indicating that transmission is taking place. Dust can prevent good contact with the switch inside the remote and by pressing hard on the button may re-establish contact again. It is however not fail prove as the light can flicker but is still not transmitting to the motor control box. The fact that the keyboard and up function is working indicates that the remote is malfunctioning and need to be replaced.
Sep 21, 2014 | Craftsman Garage Door Opener 1/2 HP Chain...
Chamberlain garage door will not close
If your garage door will not close from the open position and reverses immediately or part way down there is a safety beam problem, usually there is a safety light on the opener which will flash when the safety beam is activated or faulty. Clean the photo beams with a clean damp cloth, check if the door now operates, if it does not, check that the safety beams have not become misaligned, there is normally a light on one of the sensors that indicates when they are correctly aligned, if the light is on it means they are not aligned, the light off indicates they are aligned. If they are not aligned try adjusting them, if this does not work they are probably faulty.
Further reading garage door opener repair guide
Jun 16, 2012 | Chamberlain Power Drive 1/2 HP Chain Drive...
Remote will open the garage door, but will not close it. It will move the door a few inches, and then return to the fully open spot. the control inside the garage works fine, except that recently you...
This indicates that the safety sensors are mis aligned. You can re align them by hand. There should be an led light on each sensor and each should be on, not flickering or off, no matter the color. Also check the surface they are mounted to for stability. For instance if they are mounted to the track and the track moves as the door cycles then you will have issues. This should solve your problem. Thanks BB
Aug 31, 2010 | Chamberlain 3Button Remote Control Model...
Garage door won't close with remotes
Yeh, read manual. Do both sensors have led lit. try aligning. you have safety beam problem,
Jan 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door won't go down using control
Make sure to clean off the lens so there's nothing blocking signal and make sure that theres no obstructions in the way of the photo cells before and during cycle. make sure that you have power going to them by having the Amber or red light displayed at all times and make sure that the green light is present for alignment. If it works for a couple of cycles and then goes back to being non active, make sure that the tracks or the surface that sensors are mounted to are not moving as door is in operation therefore they will move out of alignment during or after a cycle and will not allowed to operate! Make sure that none of the wires going to the cells are punctured through by any Staples! sometimes it could happen and when you move the cell around it could relocate from the staple and go back to norm, then after cycle it could short out from vibration which will send wire back to hitting stable! If none of these are helpful and you want a quick fix go down to your local home improvement store and buy a set of photo cell/safety cells and wire them up as diagram displays which is very simple and easy.
Mar 17, 2017 | Sears Craftsman LiftMaster Chamberlain...
Programing limits on a Grifco MK3 Garage door Operator
It has the "Protector System" (safety sensors). chec the sensor indicator light on the receivinng eye the green light had a slight flicker.cleaned both the sending eye and receiving eye lens of dust and cob webs, then realigned the receiving sensor for a steady green indicator light. then check the door function it now works fine.over time, temperature, and viberation the sensors become dirty and get out of alignment, as no one had tampered with the sensor alignment prior to this. Hope this works for you.
Nov 21, 2008 | Sears Craftsman LiftMaster Chamberlain...
Craftsman Garage Opener /
door will not go down unless you hold down the inside botton.
Sep 14, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
74 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
