Question about Sony KDF-55WE655 55" Rear Projection Television
Flashing led The power led flashes 3 times green and the 6 times red and then continues to repeat the patttern. nothing else happens it is not the bulb/lamp led...and i changed the lamp just for giggles($189 wasted) sony-kdf-e55a20 rear projection 1-1/2 years old any suggestions...
  • 4402 Answers
SOURCE: Sony KDF-42WE655 Replacement Lamp
First thing i would ask is where is the smell coming from?
Posted on Jan 31, 2008
  • 41 Answers
SOURCE: Sony KDF-55xs955 TV will not turn on. Red LED flashes 6 times.
This sounds so simple, but this is what i gathered from Sony's website. Sounds to me like it may be a service issue.
The STANDBY light will flash if the television detects an issue within the television. Some of these issues can be resolved simply by following the steps below to reset the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required . Please note the number of times the STANDBY light flashes and relay that information to the service center.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
Posted on Dec 05, 2008
Where is therm fuse location
Posted on Jan 30, 2009
  • 586 Answers
SOURCE: I have a grand wega kdf-55wf655 projection tv.
The detail of your fault is given below according to the SELF DIAGNOSTIC SYSTEM.
The description is given below:
6 : Low B error When no "DD 6V " is detected, pin 129 of TV-micro is low and it turns off the main power.
This problem is little bit technically difficult, therefore i advise you to please contact any expert who can handle this or contact SONY SERVICE CENTER.
Hope you will understand my saying.
Thanks for using fixya.
Posted on Jul 02, 2009
  • 336 Answers
SOURCE: sony grand wega kdf-e55a20 will not turn on when
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it : But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs it could be time to replace the lamp.The lamp you need is XL-2200.Have a blessed one!
Posted on Apr 02, 2010
  • 4889 Answers
SOURCE: My SONY Grand Wega KDF-E55A20
It is definitely the lamp. The lamp is not yet dead but is at the end of its life. Replacing it should resolve the problem.
Posted on Jan 30, 2011
0 characters
1 Points
I have a 56' that wont show picture
Power board is bad.. I had the same issue.
Apr 13, 2010 | Samsung HL-S5679W 56" HDTV
MOST LIKELY problem is the convergence amps but.....
It might be your vertical or horizontal circuit...those initiate a 3 blink failure code too....
Dec 01, 2007 | Panasonic PT-50DL54 50" Rear Projection...
Power/standby led beeps red light 6 times
Your Thermal fuse is out. I just replaced mine, the part is only $4.85 on Ordered (2)
Feb 16, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
My Panasonic PT-60Dl54J tv shut itself off and the power button is now flashing red 6 times. What has happened, how do I fix it?
This is straight from the service manual (I'm not sure what the problem is but it sounds serious):
8.2. Power LED Flashing timing table
When an abnormality has occurred, the protection circuit operate and cuts the power supply. At this time, the defective line can be
identified by the number of flashes (red) of the power led indication at the front of the unit.
3 FAN SOS 94
4 MAIN 3.3V 88
Dec 06, 2009 | Panasonic PT-50LC13 50" Rear Projection...
No picture or sound
Does anything start to work? Any of the three fans start to turn, Lamp ignite, etc., when you press the power button or does nothing happen before the Red LED starts blinking. How many times does the RED LED blink?
Jul 25, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
Tv went off while watching a program power standby red light blinks 6 times then pauses then repeats tried unplugging unit waiting a few minutes then replugged same results nothing. can anyone help me ?...
Here's an excerpt from the Sony Manual online. And the link -
The POWER/STANDBY (red) indicator flashes three times
If your power/standby indicator is flashing in a pattern of three flashes, this may indicates that the lamp cover is not attached securely. Follow the directions in the Operating Manual under changing your lamp that related to closing and securing the Lamp Cover. Ensure that the Lamp Cover Door is securely fastened by tightening each screw.
The POWER/STANDBY (red) indicator flashes continously
If your power/standby indicator is flashing continuously, and the lamp cover has been secured, your TV may be in need of service.
The POWER/STANDBY indicator is lit up green (not flashing)
A sustained green light indicates your TV is on.
The POWER/STANDBY indicator is lit up red (not flashing)
A sustained red light from your power/standby indicator simply indicates that your TV is in standby mode. This shows you that your TV is ready to be turned on with the remote.
Is it the power light and not the lamp light? If the lamp light is flashing then replace the lamp.
Apr 07, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
KDS-R60XBR1 Sony Projection SXRD Power Issue?
how many times does it blink pause then blink again?
Dec 01, 2007 | Sony KP-41T65 41" Rear Projection...
Television won't turn on
If its a DLP tv chances are the bulb went out, double check with the manufacturer before getting as they are not cheap, around the $250 range.
Oct 26, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony KDF-55WE655 55" Rear Projection Television Logo
Top Sony Projection Televisions Experts
Steve Sweetleaf
Steve Sweetleaf
Jason Harris
Jason Harris
Are you a Sony Projection Television Expert? Answer questions, earn points and help others
