Question about Philips CDR795 2-Disc CD Recorder
Trays locked All of sudden I cannot open either tray, I get the message "trays locked". I have unplugged unit but still did not work. Thanks,
  • initialjkd Nov 08, 2007
    trays locked. have tried switching on and off and re booting, doesnt work
Remove the tray out & put the grease on gears under the tray
Posted on Apr 05, 2007
SOURCE:
Wont print. Cant detect paper.
There's a problem with the software in the unit. Brother does no longer offer software updates. You can try and power off the unit, unplug the USb cord from the back of the machine. Wait 1 minute, plug the USB back in and power the unit up. After unit cycles, should be ok. If not, uninstall/reinstall the software///
Jul 22, 2014 | Brother MFC-9840CDW Laser Printer
DVD trays out - Panasonic SA-PM39D
there are very tricky mechanical devices that detect when the trays are closed and in what position they are in
A gear or mechanical piece is not in correct order or not functioning properly and will need intense studying to determine which position they all should be in at door closed , laser mech. position , standby position
can you upload a photo of the inside of the cd mechanism?
Oct 18, 2008 | Panasonic SC-DK10 System
5 cd changer problem
what brand/model number?
Jan 03, 2013 | Audio Players & Recorders
Empty trays message will not go away
The interior sensor is dirty. Turn off power, unplug unit, clean any contacts within the unit. Make sure the tray is also clean, particularly the metal leads at the back of the tray.
Feb 07, 2010 | Bosch Benvenuto B30 Espresso/Coffee Maker
DVD Tray Will Not Open
unplug unit for couple of hours. if that doesnt do it the trays gears are out of alignment
Jul 10, 2009 | Televison & Video
Paper trays do not stay locked in
You need a PIU (paper input unit)...this has catches that lock in the tray. Usually, only one of the trays will not lock shut....but yours is a conicidence. Even if one tray didnt lock in, it is still the PIU.
Dec 27, 2008 | HP LaserJet 5si Printer
Philips CDR796 CD Recorder
You power off then power back on while holding down the fast forward and rewind buttons on the recording side simultaneously. The display moves through a sequence of numbers and the trays will then open.
Sep 18, 2007 | Philips CDR795 2-Disc CD Recorder
FW-R7 displays "Locked" when attempting to open CD Trays
You were close, but didn't explain it very well. If you push on the 'DISPLAY' button (left side of machine as you are facing it, about half way down) when the unit is off, it will say something like "DEALER MODE", push it again to return it to regular mode. You may have to press and hold the button to get it to display 'DEALER MODE', then when everything is normal, "DEALER MODE" just goes off and isn't replaced by anything. Hope I explained it well. nyati585@aol.com
Feb 09, 2007 | Philips FW-R7 CD Shelf System
Locked Cd Tray
The solution is to turn the machine onto standy and then hold the 'display' button for a few seconds, and voila, the trays are unlocked... geni-arse!
Aug 05, 2006 | Philips MC-90 CD Shelf System
Philips CDR795 2-Disc CD Recorder Logo
394 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
