Question about Nintendo GameCube Console
Gamecube console GC cannot read the disc(no disc), and disc is not spinning when cover is closed. What is wrong with this console and what does it cost to fix it?
  • 2 more comments
  • Anonymous Jan 26, 2009
    my system will not spin the disc at all. i clean the discs but nothing works i dont know if i should repair it or just buy another cube.
  • Anonymous Jan 31, 2009
    When i try to play ANY game on my gamecube, I almost never get past the menu. It always says no disk but its in every time, what do i need to repair it
  • bobby johnson Apr 27, 2009
    the disk wont spin and when it stops it says turn power off and read instruction booklet
  • Shane B Sep 03, 2012
    Its probably a bad moter. If so, you will have to open the system its self up and replace the moter.
    Problem Solver:
  • 14 Answers
You may have to adjust the POT of the GameCube lens... The POT is basically the power and spread the lens uses to read discs... the problem is, over a long period of time, the POT figure drops down, and if it drops too low, you will need to replace the lens.. The machine could still be salvageable, and play games and load them faster than before if you adjust the POT on the machine.. Here is a guide on what is required to open up the machine and do it, if you feel it necessary.... http://modthatcube.pxn-os.com/content/pot.htm
Posted on Apr 30, 2007
Posted on Sep 03, 2012
My gamecube wont read disc
Posted on Apr 27, 2007
    Problem Solver:
  • 8 Answers
Mine had the same problem. the tech support guy told me to clean my disks. It wasn't spinning, the disk wasn't dirty, and it didn't work for other disks but after I cleaned them, the system worked fine.
Posted on Apr 25, 2007
    Problem Solver:
  • 46 Answers
Http://www.techspot.com/vb/all/windows/t-15386-GameCube-repair.html go to that link sir!
Posted on Apr 06, 2007
Turns on but wont spin disk
Well we think that the motor inside of the console that spins the disc's is shot now so you should buy a wii because wii's are better than gamecubes are and you can still play gamecube games on a wii too. Because i play gc games on a wii then.
Aug 03, 2011 | Nintendo GameCube Console
My Nintendo Gamecube sometimes will only read discs. Most of the time it will spin for about 5 seconds, then stop. When I went to my friend's house, his Wii read my discs totally fine. Also, some of my...
Well its because that there is something wrong with you v cube like the part that reads the disc's are gone now or is weak so it would need a new reading laser.
9k=
Jun 27, 2011 | Nintendo GameCube Console
My gamecube does not spin the discs that i put into it and does not read them. Is there something i can do to fix this without having to buy a new one?
One time I ccidently touched the lens in my 10 year old gamecube so now the lens and the laser dont read the discs anymore because it is knocked out of anglement so you could buy a new gamecube now or buy a wii because wii's can still play gamecube disc's too.
default.jpgGame Cube Disk Read Error Fix (Advanced Skill)
May 19, 2010 | Nintendo GameCube Console
Disc Doesn't Spin. 'No Disc' Appears.
Try cleaning the laser with a Q-tip.
Apr 11, 2010 | Nintendo GameCube Console
The game disk could not be read.
It sounds like the disc reader is dirty, it's the little clear circle right under where a disc would go, closest to the back of the unit.
To clean, open disc cover, locate the disc reader, use a dry soft towel or some toilet paper and gently wipe it off, sometimes even a little dust can cause a problem. This should do the trick. If it doesn't, then either the disc is scratched or the Game Cube has something wrong with it.
hope this helps!
Sep 20, 2009 | Nintendo GameCube Console
I bought a gamecube online and it wont spin the disk
Sounds like you need the Gamecube sensor switch replaced. That is a small door device for detecting when the Gamecube DVD door or lid is closed allowing disc initiation to begin. When your Gamecube doesn't detect disk at all and simply continues the message: "Please insert a NINTENDO GAMECUBE DISC," this is the problem. You can test this by inserting a game disc, opening the Gamecube door, and then closing it. If the message "Please insert a NINTENDO GAMECUBE DISC" remains unchanged, and there is no spinning of the disk, then your GameCube lid closed door sensor is probably broken and should be replaced. You can search Google for Part GCPT032, or for GameCube Lid Closed Door Sensor.
An easy fix if you know how to open the Cube. It's cable simply plugs in, and it is held by one tiny screw.
Sep 05, 2009 | Nintendo GameCube Console
Wii unable to read gamecube disc... :(
If Wii gives Disc Read Error, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Mar 23, 2009 | Nintendo Wii Console
My gamecube problems.
If the disc does not spin or spins strangely, it is almost always because the gamecube is having problems reading the disc, and not a problem with the motor. The laser can be adjusted to a higher power, but you will need several special tools to do so. You should be able to find a guide by googling for gamecube laser adjust. If that doesn't solve the problem, you either need to replace the laser or the laser control board.
Mar 19, 2008 | Nintendo GameCube Console
Nintendo GameCube Console Logo
557 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
juanmireles1
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
