Question about AMD Turion 64 Mobile ML-34 1.8GHz 35W 1MB CPU, OEM (CPUAMDAT07)
My processor is half the speed it should be running at about 780 MHz and whenever I am watching anything with a lot of sound or well.. half way through a show when it starts getting good, it skips ALOT and cant keep up please help
  • Garrett Jones Dec 20, 2008
    its an hp pavilion dv8000, how do i do that?
  • rup6 Jan 03, 2009
    I have the same problem, but my bios does not allow me to change the multipler...
  • 341 Answers
Check your settings in your bios.The multiplier could be set too low.What laptop is it?
Posted on Dec 20, 2008
Hi my Latitutude D800 has a Pentium M 1.7 GHz processor but it slows down and runs at 600 MHz. Please Help PS. Am using windows 7
whenever it use on battery power it shows it minimum speed, also it will shows full speed when the processor is processing something.
May 12, 2012 | Dell Latitude D800, PP02X Series Laptop...
For Intel processor "Pentium 4
Dear abhay_patil
It should work but the 667 will throttle itself down to the 533 speed.
Its usually not a good idea to mix different speeds of ram together.
For a lot less headache its better to have same manufacture and speeds of ram together in the same system.
Hope it helps, if it did just give the thumbs up a click
Feb 10, 2011 | Computers & Internet
I have a Syntax K7 SV400 motherboard. The board will post but will not install the os. The bios recognizes the cd drive and the hard drive. When I try to install Windows 2000 Pro the cd drive spins and I...
Nothing, first try the disk in a working pc & see if it auto-runs in windows,if it does then try a different ribbon cable on the cd drive. If it doesn't then the disk is dirty or damaged. Also, not accusing you but windows 2000 is probably the most burned copy of windows around. If this is the case, go to whoever you got the disk from & tell them to re-burn it at 4x if possible but no faster than 6x, then the disk will work. As far as the bus speed is concerned(the jumpers), if the processor is a 100mhz, that's all the faster it will operate. Especially on older pentiums,which it sounds like you have. Now the processors will go to a slower speed, like 166 to 100. Keep in mind when switching cpu's you must set the jumper to the matching or slower speed or it will not post. Also, that speed is half what the actual clock is, meaning, 100 is 200,133 is 266, & 166 is 333 mhz. So if it's a socket 7 or 380 board, you can run an AMD or Cyrix cpu instead of the pentium & use whatever speed you'ld like because AMD products back then didn't lock the multipliers. Also on those older boards, some won't run certain ram speeds, like if the board has 100mhz ram it may not like 133 much. Ram wasn't very backward compatible back then.
May 14, 2010 | Computers & Internet
How to get AMD athlon 3700 socket 754 engineering sample cpu run at proper speed
Here's a little history
http://compreviews.about.com/cs/pchardwarebasics/a/aaBIOS.htm
More advanced stuff
http://compreviews.about.com/gi/dynamic/offsite.htm?zi=1/XJ&sdn=compreviews&cdn=compute&tm=128&gps=215_11_1267_540&f=00&su=p284.9.336.ip_p504.1.336.ip_&tt=2&bt=0&bts=0&zu=http%3A//www.adriansrojakpot.com/Speed_Demonz/BIOS_Guide/BIOS_Guide_Index.htm
Some systems have "bottlenecks," where small overclocking of a component can help realize the full potential of another component to a greater percentage than the limiting hardware is overclocked. For instance, many motherboards with AMD Athlon 64 processors limit the speed of four units of RAM to 333 MHz. However, the memory speed is computed by dividing the processor speed (which is a base number times a CPU multiplier, for instance 1.8 GHz is most likely 9x200 MHz) by a fixed integer such that, at stock speeds, the RAM would run at a clock rate near 333 MHz. Manipulating elements of how the processor speed is set (usually lowering the multiplier), one can often overclock the processor a small amount, around 100-200 MHz (less than 10%), and gain a RAM clock rate of 400 MHz (20% increase), releasing the full potential of the RAM.
AMD also produced x86 designs which competed with Intel on performance rather than price. In January 2002 the Pentium 4 gained a lead in sales and AMD marketing responded by giving their processors numeric suffixes approximating the clock rate that an AMD Thunderbird (and by inference a Pentium processor) would need to give matching performance, openly undermining the "megahertz myth".
May 15, 2009 | Computers & Internet
How to overclock a pentume 4 processor
Increasing of FSB (processor clock) from 10% up to 15%.
from 1700Mhz you can get 1850 Mhz.
from 2400 Mhz you can get 2640 Mhz
from 3000 Mhz you can get 3300 Mhz
but not all mater board allow this do.
Mar 07, 2009 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
2 ghz processor running at 220 mhz
Have you tried right clicking on the desktop (opening Display Properties), clicking on Screen Saver tab, Clicking the Power button, and setting the power schemes to Home/Office Desk? If its set on laptop it will reduce the processor speed when running on battery. I have noticed that even with it plugged in that some times it will run at half processor speed. Try that out.
Have a great day,
Armymason
Mar 02, 2009 | Dell Inspiron 9300 PC Notebook
My laptop is very slow!
uninstall unnecessary program,scan your PC for possible malware with your updated anti virus,expired antivirus can slow your pc to half of it's speed.Manage your start up program only run program that you nid when you open your PC.Last thing is defrag your PC.
Jan 24, 2009 | AMD Sempron 3100+ 1.8GHz 256k Socket 754...
Toshiba Tecra 8000 can running well with Winxp?
This Laptop will just barely run with that speed processor,,and ram,,it would run a little better with a lot more(say twice the amount)of ram, but only barely.
Jan 19, 2009 | Toshiba Tecra 8000 Notebook
Processor speed loss
It's possible that the XP is using the extra resource or processor usage, and there isn't anything that you can do. However, It's also possible that this machine was configurated for 2000, and that it just needs drivers for XP. You can start by going to IBM's support site and doing a bios flash to the most recent bios, and checking for a chip set driver update, patch, or for for XP. Also check for any processor speed stepping drivers or updated drivers. Try this and let me know.
Aug 19, 2008 | IBM ThinkPad A21m 2628 Notebook
I have put a sempron 3.4 processor in but the system only recognises it as 2ghz ?
Your processor speed is actually correct AMD calculate the clock speeds differently from Pentium type processors, a 3400+ is a 2.0 GHZ processor, see the list below for speeds Sempron 2500+ 1.40 GHz 800 MHz 128 KB 754 Sempron 2600+ 1.60 GHz 800 MHz 128 KB 754 Sempron 2800+ 1.60 GHz 800 MHz 256 KB 754 Sempron 3000+ 1.80GHz 800 MHz 128 KB 754 Sempron 3100+ 1.80 GHz 800 MHz 256 KB 754 Sempron 3300+ 2 GHz 800 MHz 256 KB 754 Sempron 3400+ 2 GHz 800 MHz 256 KB 754 Don't worry too much about the proceesor not being recognised as long as you know it is running at the correct speed.
Nov 12, 2006 | Iwill ZPC-SP (ZPCSP) Barebone
AMD Turion 64 Mobile ML-34 1.8GHz 35W 1MB CPU, OEM (CPUAMDAT07) Logo
49 people viewed this question
Top AMD Computers & Internet Experts
Alun Cox
Robert Monigold
Robert Monigold
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
