2004 Ford Explorer Logo
Joan tober Posted on Aug 20, 2012
Turn signals on 2004 Explorer light up but won't flash
Turn signals flash "sometimes" and then just stop. Sometimes won't flash at all. I can see the turn signal light on at the dashboard and the appropriate light in front and back go on but no flashing. The fuse is fine. Checked. The hazards work. Thanks!
Anonymous
Level 1:
New Friend:
  • Contributor 28 Answers
  • Posted on Aug 20, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
28
Questions
Helped
12112
Points
92
Turn signal flasher. check your user manual for location and style
5 Related Answers
Anonymous
  • 18 Answers
  • Posted on May 05, 2011
SOURCE: 2003 ford explorer - sometimes
This is most likely going to be an issue with a relay. The relay on the fords that is tied into the blinker module can go bad is it gets wet or over loaded. Are there any after market things added to your vehichle? This can also be caused by overloading part of your ECU if you have after market headlights, or headlights that carry too high a load. When it blinks for 3-4 times and stops, does it blink faster than normal? This can be a sign of a false connection to the light itself. Such as having the wrong bulb in for the blinker.
Anonymous
  • 74 Answers
  • Posted on May 24, 2009
SOURCE: Turn signals hazards and brake lights are not working fuses good
did u check fuses under the hood on driver side lol yes ford has them thear also
Anonymous
  • 105 Answers
  • Posted on Jun 04, 2009
SOURCE: Left turn signal does not flash, I have changed
the turn signal switch is probably bad remove cover and check out puts with a test light to make sure
Anonymous
  • 82 Answers
  • Posted on Mar 26, 2010
SOURCE: rear turn signal and hazard light don't flash (left side only)
The rear left turn signal bulb must be replaced immediatly before it melts the light socket, if it has'nt yet. Also please verify that the correct light bulb is being installed. because even though many bulbs look the same they are not identical. Installing the wrong bulb can be the begining of many, many problems in the particular circuit
Steve Banks
  • 232 Answers
  • Posted on Aug 17, 2011
SOURCE: The turn signal lights on
Sounds like your flasher relay is broken. A lot of people think that because their hazard flashers work that everything is OK, this isn't so. Hazard flashers are on a seperate system, and as such they have their own relay.
You will need to find where your indicator relay is located and replace it with the correct type.
Electrical problems
have a load test done on the battery for failing cell and have the output of the alternator checked as if the battery is faulty then the alternator has trouble supplying enough current to run every thing electrical
Indicator won't stop flashing
What type of vehicle are you talking about? And does the opposite side operate correctly? What are you referring to when you say stalk returns to off position? If you are talking about the directionals or turn signals of this vehicle as to when you make either a left or right turn and it not shutting off when the steering wheel is turned back after the turn has been made then you're dealing with a canceling function within the directional or multi-function switch.Not sure if this is what you're talking about when you are reffering to indicator flashing.
1helpful
3answers
2004 buick lasabre, right side turn signal blinking fast.
Check the front turn signal bulbs. This will affect the resistance in the circuit and cause the working light to flash at a much faster rate.
2004 chrysler pacific will start sometimes but sometimes won't
I would suspect the fuel pump is the problem, it may be sticking at times and this causes a no start. The pump is located inside the fuel tank and it is electric.
2answers
My right rear turn signal stays solid, won't blink, in the vehicle the right blinker light blinks excessively fast, I have a 1999 surburban
Sounds like a bad ground to me, although i am no expert.
i would be checkinh all connections and take it from there, a little wd40 might just solve it short term.
3answers
1993 plymouth acclaim turn signal flashes rapidly, new flasher didn't work.
bad earth on a back light i suspect providing their europeon standard lights with yellow seperate indicators and not them funny american ones with a stop and tail and indicators all on the one bulb
2001 Dodge Ram 1500 2WD truck. From time to time the turn signals won't blink. They light up but do not flash. They will sometimes begin to blink and then stop blinking. Sometimes they blink,...
check the earths on the lights and the bulb wattage ,it should be 21watt ,but if its the weird funny system on a american car then who knows ,where the stop light is the indicator and it flashes red and cuts out ??
All of the turn signals on 2004 Honda Civic have stopped working. They all still work when my hazard lights are on, but not to signal a turn. Now, sometimes it will work for a few flashes, sometimes only...
You need a new flasher. Go to the parts store and ask for a flasher that fits your car. Also ask them where to find the flasher on your car. It is usually under the dash somewhere, sometimes plugged into the fuse box. My manual does not say where yours is, but it may be next to the hazard flasher. If it is, you could turn the hazard flasher on and trace the sound to find them both. OK?
Have 2000 VW Jetta, turning signal stops working intermittently. starts signal then stops blinking during turn or sometimes it works fine, sometimes won/t. all bulbs working & all other functions on...
I pulled my switch out of the dash and sprayed it with contact cleaner. Air dry and put back in. 2 years without a problem. If you're not electrical savy, I'm pretty sure there was a recall on that, and it should be replaced for free.
2answers
Turn signals flash sometimes other times they just light up
replace flasher, or switch with emergency flasher to test.. Should be in with fuses or in that area.
Top Ford Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Ford Expert? Answer questions, earn points and help others
