Question about Maytag Neptune MAH5500B Front Load Washer
Maytage neptune the washer reads nd an the front load is not rinsing the clothes it is full of water
  • lorraine guenther Dec 27, 2008
    it was a bad pump
  • Anonymous Jan 02, 2009
    I have the same problem: display reads nd and the washer is full of sudsy water.
    President:
  • 373 Answers
"nd" refers to a No Drain issue .check for restriction in pump, restricted drain hose loose wire at pump, bad pump.
The pump had a suds lock. Unplug the machine for a minute. Plug it back in and run a cycle on hot to get rid of the excess soap.
Posted on Dec 20, 2008
  • Suresh Thrithandam Venkata Lakshmi Narayana
    please do rate my answer if the solution was right. thank you. and happy holidays
Put detergent
MLG2000A - Maytag Neptune Super Stack SL-3
1 - Select Wash/Rinse Water Temperature
2 - Select Options (Max Extract, Extra Rinse, Signa)
3 - Select Cycle
4 - Load the Clothes Washer (add detergent on top of the load in the tub, and additives [fabric softener, bleach] in their dispensers).
5 - Start the washer.
This is according to the owner's manual I have. Has worked for 14 years for me.
Jan 14, 2014 | Maytag Neptune MLG2000A Front Load Stacked...
Maytag Neptune "nd" code
It is a drain pump issue, it is either a blocked or faulty pump or a fault in the electronic controller.
Mar 12, 2012 | Maytag Neptune MAH6500A Front Load Washer
Is there any kind of recall on a Maytay front loading washer, model #MAH6500AWW? I am having problems with mildew in the rubber part and terrible smelling water in the bottom.
The cleaning process for your Maytag Neptune front-loading washer, for example, requires some time and patience. Over time, your washing machine will need to be cleaned. It can develop offensive odors through multiple wash cycles. This makes the washing machine less effective at cleaning the clothes you put into it. Maytag offers some sound advice for cleaning your front-loading washing machine.
  • Pour 2/3 cup of liquid chlorine bleach into the bleach compartment of the dispenser drawer of your Maytag Neptune front-loading washer.
  • 2
    Run your Maytag Neptune front-loading washer on the "Clean Washer" setting. Press "Start" to start the cycle.
  • 3
    Leave the door open once the cycle is complete to allow the inside of your Maytag Neptune front-loading washer to ventilate and air dry.
  • 4
    Look closely at the gray seal of the Maytag Neptune front-loading washer's door opening. This seal can have a buildup of debris or detergent residue.
  • 5
    Spray the seal with an all-purpose appliance cleaner and scrub away any debris or residue with a cloth or scrubbing pad. Dry with a clean cloth.
  • 6
    Remove the soap dispenser drawer. Press the release lever and lift it out to clean.
  • 7
    Take out the inserts and rinse them and the drawer thoroughly.
  • 8
    Wash with a mild soap and cloth to remove any residue. Dry thoroughly before replacing.
  • ALWAYS LEAVE THE DOOR OPEN WHEN NOT IN USE! This prevents the mold and mildew from forming once you get it cleaned.
    Aug 20, 2011 | Washing Machines
    Someone put some heavy things in it and it stopped mid-cycle. We removed the heavy objects, and then attempted to drain the leftover water by putting it on "rinse and spin." It never really...
    The ND error code on a digital Neptune front load washer. The ND code means 'No Drain' and it is probably just something caught in the pump. Sometimes this is a early sign of the pump going out or a control board issue.
    Nov 23, 2010 | Maytag Neptune MAH5500B Front Load Washer
    Stops in the middle of rinse and says nd on the screen
    Is it rinse or pump out. Make sure the water is filling properly. Lot of times the water valve screen where the hose connects to the washer can get clogged with sand and not let the water enter properly causing this code.
    Feb 11, 2010 | Maytag Neptune MAH5500B Front Load Washer
    My Maytag Neptune front load washer displayed ND with 19 left in wash cycle. Door won't open, what can I do?
    Not draining,throw rugs tend to clog this unit as do bobby pins and under wires I'm giving you a link to the repair manual it covers the 3000 through 5500 it will help you get the door open and the clothes out so you can start bailing...
    http://www.servicematters.com/maytag_library/docs/16010061.pdf
    Sep 13, 2009 | Maytag Neptune MAH5500B Front Load Washer
    Maytag neptune washer washes, drains but doesn't spin or rinse. open door to find wet, soapy clothes. Thanks
    Read along in the threads/posts on the same topics. I posted a lengthy reply that has worked for me numerous times
    Dec 08, 2008 | Maytag Neptune MAH5500B Front Load Washer
    check your cold water filter at the valve where it enters the back of the machine make sure cold water enters the machine.take the cold hose of and make sure it is clear.
    Oct 30, 2008 | Maytag Neptune MAH5500B Front Load Washer
    Maytag Neptune rinse cycle doesn't start.
    cold water valve screen plugged or bad valve, just check it!
    Aug 06, 2008 | Maytag Neptune MAH6500A Front Load Washer
    Washer wont rinse
    we had the same problem with ours....nd means not draining and that means that there is something, probably coins stuck in your drain hose. pull the drain hose out and check it for change and make sure something isn't stuck.
    Jul 21, 2008 | Maytag Neptune MAH9700 Front Load Washer
    Maytag Neptune MAH5500B Front Load Washer Logo
    141 people viewed this question
    Top Maytag Washing Machines Experts
    Bill Long
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    John Tripp
    John Tripp
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
