Rear bumper of my car has been knocked in. Need to fix it.
My car's rear bumper has been knocked in. Need to remove it repair the dent and fix it back. Can't find the screws to dismantle it. Please help. Mine is a Nissan Laurel medalist 1991 model.
Thanks
    Problem Solver:
  • 11 Answers
Hi
Is the bumper metal or plastic? If plastic there is a Styrofoam filler behind the bumper to absorb most of the impact and you need to change that as well.. If Metal then you have 2 shock absorbers that is what keeps the bumper in place, there are 4 screws per shock total of 8 and the shocks need to be replaced also, as they are collapsible shocks that after a hit they go in to take up most of the hit and do not come back out, do not leave them change them for safety, as if someone else hits you the damage will be far greater than with new bumper shocks.
With plastic follow the lines of the bumper and when it joins the body of the car there should be some fasteners and at times clips also, and most are used under the car and where the bumper joins the body. Or if you want to fix just the bump, depending on how deep it is MAACO in the USA can do it for you, or if you want to tackle it then you need to sand down the bump to the plastic, use bondo made for plastic bumpers and fix the dent in layers, 1/4" at a time, and allow to harden before you body file the bondo and add another 1/4" till you have fixed the dent. Or get a new bumper from the web and some places even paint then for you as long as you can get the paint code, that they might know by the VIN, or just ask a dealer they will give you the paint code and you get an aftermarket bumper that you swap out. BUT CARE SHOULD BE TAKEN WITH WHAT IS UNDER THE BUMPER, for your safety don't leave damaged or bent supports etc.
HTH
Zues
HTH
Zues
Posted on Dec 21, 2008
How do I repair a dent in the rear bumper of my 2004 Honda pilot? Do I have to remove the bumper and if so how is that done?
depending if its plastic you can remove the dent using a heat gun and a tap around the bump usually pop out. removing the bumper there are screws on the sides behind the wheel arch covers and 4 bolts around 1 foot away from the corners, if your model has sensors in the bumper they will need to be discounted. also any other wires that are they before you pull off the bumper.
Jun 20, 2017 | Honda Cars & Trucks
Removing rear bumper cover on 2007 Chevrolet Impala?
Most dents can be popped or tapped back out, provided it has not crumpled or creased the metal.
---------------------------obd2express.co.uk
Dec 07, 2012 | 2007 Chevrolet Impala LS Sedan New Cars
Rear bumper removel
No need to remove it just fill the dent and repaint it.
Aug 20, 2012 | 2004 Ford Freestar
Toyota Sienna bumper dent
These vans have a styrofoam bumper wrapped in semi-rigid plastic. When you dented the bumper you probably dented the styrofoam as well, so depending on how deep the dent is you may not be able to bring it back to normal.
The surest way to fix the dent would be to remove the bumper by unbolting it, then taking out the styrofoam and pushing out the dent.
Apr 03, 2009 | 2006 Toyota Sienna
How do I remove the back bumper (plastic) on a 2003 toyota camry?
you can heat the bumper heat gun ( you can rent one i think?)
this will soft the bumper so you push it out easily on the car
1. inside your trunk remove small back clips in trim panel
2. remove tail lamp four 8mm nut perside unplug wires
3. remove black clips under tail lamps ( flat head screwdriver to pull center of the clip up slowly then remove the hole clip)
4. three if the some clips are bottom if the bumper
5. three or four 10mm nuts in side the quarter panel on the right and left side
6.four s shape clips are top bumper that will pull loose
7. with some help slide bumper by pulling it off it
8. when you reinstall the bumper you may need to tape the strophe reinforcement in place
Feb 24, 2009 | 2003 Toyota Camry
Rear bumper on mazda mpv
Removal of the rear bumper on an Mazda 2004 to 2006 MPV.
It's afairly simple task: 1) Open the rear hatch or (door) remove the torx screws at the bottom of the weather strip. 2) Remove both tail lights by unscrewing the two phillip screws on each light, once removed the lights pulling toward the side of the van. Let them hang from the wires. You will see a clip (white in color),pry it out from behind the bumper material and go to the next step. 3) Remove three 8mm head screws in each fender well and three plastic clips. Then remove an 8mm screw at the top corner of the bumper against the rear fender. If your car has splash guards remove them as well. 4) Remove the two clips at the bottom of the bumper attached to the under carriage. 5) Pull the bumper toward the back of the vehicle be careful with the tail lights. Remember, they are hanging loose.
And that's it, you have done it.
Ferni
Oct 07, 2008 | 2005 Mazda MPV
2000 Infiniti I30
Sure! pop the trunk and remove screws and screw covers inside, then look in the wheel wells for the remaining screw/clips. Lastly underneath, near exhaust may be a few last screws to keep from flapping. Just make sure to watch for any wires from rear cameras, or reverse sensors. You will not need to remove any of the foam behind bumper.
Jul 28, 2008 | 2004 Infiniti I35
2004 toyota rav4 rear bumper assembly guide
there are two bolts to the center and two around the corner on at the edge up high and one at the bottom of the bumper/ Please rate my response thank you very much
Jun 16, 2008 | 2004 Toyota RAV4
Rear Bumper Cover
you would need to heat it up from behind to remove the dent and the rubbing compound should work as long as it hasnt penetrated your paint layer
Jun 07, 2008 | 2001 Ford Taurus
Computers & Internet Logo
315 people viewed this question
Alun Cox
David Payne
David Payne
