Question about IBM ThinkPad T40 2373 Notebook
T40 laptop speakers suddenly do not make sound
They were working a few days ago. Now I get no sound. I've checked all the settings and everything there seems OK. I also tried using plug in headphones and got no sound with them either.
  • Anonymous Dec 24, 2008
    no sound
  • Anonymous Mar 08, 2009
    my speeker dont work
    Problem Solver:
  • 12 Answers
Go to
start
all programs
accessories
system restore
restore your computer by selecting a date
that should do it
Posted on Dec 21, 2008
Sound through only one speaker
Check the other speaker which do not work. In most cases, the speaker is found faulty. If so, replace it with a similar one.
May 07, 2013 | Televison & Video
Sound problems with an Onkyo receiver and a FIOS Set Top Box
If you are not hearing dialogue, then check your center speaker. Most voice tracks are routed to the center channel
Apr 06, 2017 | Onkyo Audio Players & Recorders
My laptop dosent sound loud
Good Day!
have you try to set the setting of your speaker laptop?
try to configure the sounds of your laptop first.
Mar 04, 2013 | IBM ThinkPad T40 2373 Notebook
Volume stuck on mute for wireless speakers
After pairing it, have you tried to go to your sound settings in Control Panel and selecting the bluetooth device as your standard sound device?
Oct 25, 2012 | Computers & Internet
My pc left speaker does not work. but in other devices speaker works
click start control panel sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place icon in taskbar for any
further volume control settings you will need to right click on the speaker volume icon system select adjust volume
click start control panel sounds and audio volume advanced speakers select the appropriate speakers
from the drop down list or navigate to the device manager scroll to system devices + to expand system
speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity
clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line or use a can of compressed air specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer
or if its a desktop swap the speakers around if one still does not work its either a faulty speaker or the speaker connection
hope this helps
Aug 21, 2012 | Intel Desktop Board DG41WV Motherboard
I have Harmon Kardon AV140 connected to 6 Klipsch speakers. All of sudden I know longer have any sound coming out of my front speakers. Everything was working fine a few days ago. Did we hit a button in...
Only the front speakers failing? All others ok?
There is NO configuration that would have NO front speakers.
Go back to basics, open the manual and use test tones for speaker verification.
Mar 17, 2011 | Harman Kardon AVR 140 Receiver
My laptop is year and half old and couple of days back suddenly my laptop's speakers stopped working . i tried all option in the laptop to fix it .its not working.please help.
Steps to be followed:
1. check whether audio driver is installed properly ? if not install audio driver & check
2. check audio setting in control panel & confirm
3. connect external speaker in laptop and check whether sound is coming? if sound is coming then ur laptop internal speaker need replacement
4. if there is no sound in external speaker then need to check ur motherboard or sound card.
All the best.
Aug 16, 2010 | Computers & Internet
One speaker no sound
I just want to confirm that the solution on another page from francis 8 works perfectly ( http://www.fixya.com/support/t3709832-speakers_stopped_working_cannot ). We have two sets of Creatures in our offices, one had been shelved (by someone less persevering than me) due to this problem years ago and my set started this trouble a few days ago. Troubleshot everything, every cable, setting, combination, spare speakers etc - nothing worked. Opening the offending speaker and pulling back the metal weight behind the speaker cone was the solution for BOTH of our units.
Big smiles all around :-)
Note - When you've opened the plastic shell and loosened the speaker from its mounting, the the big round metal piece/magnet sits within the actual speaker 'cage', slightly behind the speaker cone. It's tight but movable and can be pulled all the way back as far as it can go inside it's housing, away from the speaker cone.
Not sure why it gets pulled forward, but it isn't fixed in position and so could clearly get bumped by dropping the speaker or a reasonable impact of some sort. Once bumped forward it would severely limit cone movement and therefore volume.
May 07, 2010 | JBL CREATURE II Computer Speakers
No sound is coming out of the laptop.
Opened the unit up recently and saw the problem: detached wire from the speaker. All it needed was a little soldering to attach the wire back to the speaker and presto! The sound was on again.
Oct 07, 2009 | Vtech Disney Princess Magic Wand Laptop
I have no sound when I play a DVD on HP Pavillion laptop..
This could be a codec issue. Try playing a DVD in VLC just be careful that it does not insert itself as the default player for everything.
Jan 23, 2009 | Acer Aspire 5610-4648 Notebook
IBM ThinkPad T40 2373 Notebook Logo
140 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
