Question about Dell Latitude D600 Notebook
No primary harddrive found
I both a dell d600 latitude,just use it just for a month pluse and is tellin me it can find harddrive,i have remove the harddrive and fix it back but it did not work...i have troubleshoot all i can to fix it.later found out that the harddrive has been damage,but my problem is that how can i buy a new laptop and am gettin that can of problem when the laptop did not fall or anything magnetic is around the hardrive to be given me that can of responds.pls is it to retune were i get it from or just to buy another hardrive i will like to know what is the best step i should take.
thank you.
    Problem Solver:
  • 10 Answers
Hi there , this does happen with laptop hard drives they will not spin up or detect its just where & tear , the d600 has been around for a couple of years now , most of the time i just buy a faulty laptop just for the ram & hard drive if you need a cheap option this is better just check the specs on the auction before you bid to get a good size hard drive & format it before you use it .
Posted on Dec 20, 2008
Dell latitude d600 setup screen
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
May 11, 2013 | Computers & Internet
How do i install a new harddrive on my dell latitude d600
See http://support.dell.com/support/edocs/systems/latd600/en/sm/hdd.htm#1123687 which is the Service Manual page for the Latitude D600 with the steps to follow to replace the internal disk drive. . . .See http://accessories.us.dell.com/sna/category.aspx?c=us&category_id=6990&cs=19&l=en&s=dhs&mfgpid=157951&chassisid=8482 for a selection of replacement 2.5inch IDE disk drives recommended by Dell but which you may be able to purchase at lower cost from other places.
Dec 17, 2011 | Dell Latitude D600 Notebook
I have a Dell Latitude D600 laptop. Every time I turn it on, it says that the primary hard disk cannot be found. It is long past its warranty. Solutions?
There's no way you can fix a hard drive unless you're a professional who deals with at on the regular .... Other then that ...what you need is a new hard drive....
Apr 04, 2011 | Dell Latitude D600 Notebook
Dell Inspiron 14R Laptop. Daughter spilled liquid on keyboard and now when i turn on laptop screen says: For Atheros PCIE Ethernet Controller v2.0.2.3 Check Cable Connection! PXE-MOF: Exiting Intel PXE...
Ya sounds like the hard drive has died or there is a interface problem since you suffered from water damage. you may be able to get data off the hard drive by using a external hard drive connector but it may or may not work.
Mar 20, 2011 | Dell Latitude D600 Notebook
I but a dell d600 latitud 60 hdd and 512mb,using it up to a month pluse it was tell me 0 primary hard drive not.
I assume you meant "primary hard disk drive 0 not found"? Have you pressed F12 during bootup and run the HD diagnostics? If you can't run the diags and it does not show up in the BIOS, then you have a bad hard drive.
I've seen this error many, many times on D600s.
Dec 20, 2008 | Dell Latitude D600 Notebook
Primary hard disk drive 0 not found
Hi Kenneth,
If you just bought the laptop, then it is still covered by a warranty. Then all you have to do is contact the seller or directly to dell. This is the fastest and most appropriate way, and usually you will get one-to-one replacement (they will replace your laptop with new one). But, please make sure by contacting Dell.
Regards,
dC
Dec 12, 2008 | Dell Latitude D600 Notebook
Help???
You should try resetting the BIOS back to default - if I remember correctly, the Dells of that time had that option in the BIOS. If you still have issues, it may be a coincidence that the drive encountered problems at the same time as when you changed that setting. The software settings you picked in Windows shouldn't affect the drive being seen in the BIOS.
Mar 11, 2008 | Dell (04U621) for Latitude D600, Inspiron...
Dell latitude d600 video problem
may be a fault of disply connector in motherboard . gave it to a dell laptop service center. dont even think off removing the cover by ur self
Jan 26, 2008 | Dell Latitude D600 Notebook
Dell Latitude D600 Notebook Logo
61 people viewed this question
Alun Cox
