Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Water stream is down to a trickle
We've changed the filter and we've changed the electrical cylinoid, thinking that was the problem but it still just trickles.
  • lmmckchp Dec 20, 2008
    The line is not kinked, when u activate the valve there is alot of pressure but no flow rate. It just goes to a trickle
  • 2,427 Answers
Check to see if its filling propperly..
is the line filling it clogged or the cut off valve closed ??
its in the filling or the containment holder..
I'm betting its the plumbling leading to the collector (which holds the water) is messed up you need to check this out.
Posted on Dec 20, 2008
    Sergeant:
  • 233 Answers
Do you have good water pressure coming out ot the tap? Have you looked UNDER the refrigerator to make sure the plastic line is not kinked ? what about where the water line goes through to the door?
  • Josh Crager
    Josh Crager Dec 20, 2008
    this is the only thing i can think of, is a kinked water line, since you have already changed the solenoid and the filter
The water dispenser is not working on my kenmore model #795.5132
This probably means you need to change your water filter. That would be your first step. It could be the water valve but I'd change filter first.
Write down this part# for filter: 5231JA2002A and you can purchase here.
Appliance Parts
Feb 08, 2015 | Kenmore Refrigerators
Water does not flow
Sounds like air in the line.....the filter may be cracked/damaged, or not quite seated...?
since you've tried 2 new ones....I'm gonna bet they are not quite the correct ones for your fridge.
Sep 07, 2012 | GE GSHF5KGXBB (254 cu ft) Side by Side...
Whirlpool ES5FHA refrigerator water dispenser is not working properly
Note: Always make sure your filter is current if you have one. Not doing so will cause water to not despence properly
Pull the machine out and remove the lower back cover. Locate the water valve. With the water turned on and connected remove the 5/16" water line (the bigger one) and then have someone else press the water in the door. If the cylinoid is operating correctly it should spray water out.If so, you just verified that the valve and electrical portions are working properly and either the filter is bad or the resevoir, , located inside the lower refrigerator side is frozen. If no water comes out but the valve vibrates, then the valve is bad. If no water and no vibration, continue reading.With the machine plugged in but the wires that go to the valve for the dispenser off take a volt meter and place a lead to each wire and have someone press the panel in the door as if getting water. The reading should go from 0 to around 115-120 a/c.If your not getting electricity down there at anytime than thje door switch is bad.
Testing the ice maker:
As far as the smaller line (1/4") you have to manually advance the ice maker and wait for it to call for water with the 1/4" line disconnected from the valve. You can do this by getting a jumper wire, removing the cover of icemaker, which you jsut grab and pull off, and using the jumper wire insert one end of the wire into the cirle marked m and the other in the cicle marked n. Leave there until you hear a click and sometimes see a little spark behind the modular head wheel. Also if you see ice in the maker that hasn't dumper and the teeth of the icemaker are facing any direction other than two o clock position, the icemaker is bad. Also check the fill tube to be sure the no ice is blocking water from coming in. Check at the bottom front grill for the filter.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 29, 2012 | Whirlpool Refrigerators
Water will not fill in pool pump
main filter blocked (try backwashing) or if using "earth" filter system - wash filters - change earth.
Jun 03, 2009 | Hayward 3/4hp Super Pump Inground Pool...
Water dispenser is just a trickle
the biggest culprit for slow water dispensing aside from the filter is the water supply its self. check to make sure the water line isnt kinked behind the refrig, if thats ok then disconnect the water line from the refrig and run water into a bucket and observe your water flow. good water pressure would basicly fill a 2 gallon bucket in less than a minute. much less than that can cause problems. hope that helps peyton
Jan 29, 2009 | KitchenAid KSRA25CNSS Side by Side...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
23 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
