Question about HP LaserJet 3330 All-In-One Printer
Need to fax over internet and be able to scan. What do I need???
Somewhere along the lind I lost the disc for this all in one. I have the print driver and it copies just fine. I need to fax docs over the internet, with out a phone line and I need to be able to scan docs for disc burning.
  • max5101 Dec 20, 2008
    I normally use winfax. Right now I am just getting it set up after a software rebuild. I need the software that it came with so that I can reinstall everything, instead of just the print driver,(I had a back-up of that on another disc).
  • Jay Glendenning
    Jay Glendenning May 11, 2010
    So if I understand you properly .. You are using an on-line fax service (i.e. efax, myfax, etc) and want to be able to send thru to that?
  • 837 Answers
PRINTER WILL NOT PRINT
you need to assign an ip address most likely to the printer and hook it up to your wi fi, it will need to know the encryption code for your wi fi router or ethernet and then you need to set it up most likely with the driver setup disc to allocate it an ip address from your network. then each p.c will need to have driver disk run and driver should detect printer on network.
Apr 15, 2014 | Lexmark Pro915 All-In-One...
The Fax driver was not installed when I installed the Lexmark X2500 all in one from online
If you still have the installation disc that came with your printer, please insert it in your computer hard drive to install the Lexmark fax software.
If you don't have the disc, please contact Lexmark Technical Support Center for additional assistance. Thanks.
Nov 11, 2011 | Lexmark X2500 All-In-One Printer
I cannot able to print ,scan and copy.the machine says to see troubleshooting user'guide.
you can fix it by doing this
Don't connect the printer usb cable first
1st you install the driver disc which is come along with the printer and when the software prompt you to connect the cable then plug the usb cable and follow the instruction.
Go to printer and faxes option and choose the printer model which you installed just right click on it you will see the option of use printer online.
first you make sure your printer is working fine just remove the test print form going to printer and faxes option just right click on it and give test print if it is print that means your application have some problem from where you removing print out if test page is not coming then you need to reinstall the drive of printer.
Hope this helps. Please rate my response.
Thanks.
Have a good day
Dec 18, 2010 | Computers & Internet
I am not able to print a doc. from my computer.
for trouble shooting follow this steps,
Don’t connect the printer usb cable first
1st you install the driver disc which is come along with the printer and when the software prompt you to connect the cable then plug the usb cable and follow the instruction.if still fails then r
ight click on my computer and go to properties then hardware in that click on device manger and check there is any other device is listed if it is there just remove it and click for scan for hardware changes when he prompt for driver reinstall the printer driver .
Jan 19, 2010 | Epson Stylus Photo R300 InkJet Printer
Brother MFC 8220 all-in-one fax prints with a vertical line
First guess is you have a bit of dirt (often white-out from people scanning corrected paper that's not quite dry) stuck on the fax scan window. This should be described pretty well in your user manual (which you can download online from brother.com).
Its also possible that there is dirt (typically loose toner) on the laser scan window (there's a laser that shines through it to get the image pattern on the drum). That window is often along the bottom of the unit under the drum/cartridge (take the cartridge out and look). The Brother manual I've seen seems to ignore this possibility.
Print streaks DO NOT mean cartridge drum replacement in many cases !! On brother Intellifax or MFC or other laser copier/printer/fax, keep in mind that either the fax/copy scan window OR the laser scan window can get dirty. If the fax scan window is dirty, you see streaks on outgoing faxes and copies (but NOT incoming faxes). If the laser scan window is dirty, you see streaks on all prints (copies, faxes, print-from-computer).
Note also that when transporting/moving some laser copier with the toner cartridge inside, the toner can get out and make a big mess inside (including getting the laser scan window dirty). An air compressor can be usefull to blow it out. And sometimes using alcohol to clean is a BAD idea (maybe incompatible with plastic and rubber parts). A damp rag is probably fine.
Nov 21, 2009 | Brother Office Equipment & Supplies
Lexmark X83500
Check on Lexmark website and downloads your printer drivers and software.
Sep 24, 2008 | Lexmark X8350 Print, Scan, Copy and Fax...
Lost installation cd
Sure you can, you'll find them at this address:
http://downloads.lexmark.com/cgi-perl/downloads.cgi?lxkprod=Z13+Color+Jetprinter
Hope that helps,
erch.
Mar 15, 2008 | Lexmark X8350 Print, Scan, Copy and Fax...
HP LaserJet 3330 All-In-One Printer Logo
57 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
