Question about Pentax Optio M20 Digital Camera
My lcd screen is cracked !
My LCD screen is cracked, i do believe. the screen is mostly black and white with crack lines. I can only see a small part out of the bottom left side of the screen. Since I can't see, I haven't used it and I'm not sure if that is the only thing broken. Thanks for the concern !
  • scaryshroud Feb 04, 2009
    My Optio M20 has the same problem, it seems that the "protective" carry case that was a £20 extra isnt as "protective" as it should be and the warranty doesnt cover that kind of damage.
    it actually quite annoying. im wondering is it worth it getting the thing repaired or just buy a new one?
advance
  • 107 Answers
SOURCE: cracked lcd
In most cases the LCD is slightly different on most models of cameras. If there are only slight differences between models in the same line such as the megapixel rating or the internal memory the part may cross over. Models of the same camera from different production years also usually cross. I would say that VERY rarely does an LCD part cross over between model lines. Search online for a camera repair facility, you may be able to find one who would be willing to sell you the part. Be forewarned that replaceing the LCD is not always a straight forward process and there is always a chance of harming the camera in other ways while you try to fix it. David Millier Advance Camera Repair
Posted on Feb 25, 2007
SOURCE: lcd all white
okay, so i had this same problem..
it can only be fixed by pentax so hopefully youre camara is under warrenty. its a software error and your camara is defective.
Posted on Dec 30, 2007
  • 4 Answers
SOURCE: pentax a10
Ok here it is open the camera and re insert the fine lcd ribbon into is holder problem solved. Your camera must have had a sharp knock to dislodge the lcd screen and pulling out the ribbon. Worked for me.
Cheers
Posted on Jul 03, 2008
  • 14 Answers
SOURCE: LCD screen flashing
Hi!
This is a feature and not a defect of the K100D. You can turn this off by going to the menu and going into the second tab (playback menu). Once there, go to preview display, where you will have 3 options - off, histogram and brighten areas. Set this to off (your camera is set to brighten areas, that is why the white parts of your photos appear to be blinking).
Hope this helps!
Posted on Nov 14, 2008
  • 30 Answers
SOURCE: cracked lcd optio a10
It is tricky to open this case without breaking it. I repair these for $55.00 e-bay store camerashyanna
Posted on May 09, 2009
Is my Android tablet LCD screen cracked as well as the digital screen?
and you just learned a 45 dollar lesson . they are not made to sit on .
Aug 06, 2015 | Xelio P1001A-BK 10.1" 4 GB Black Tablet...
Black line or crack
Most likely LCD Panel & not economical to repair: See this site for part#, price & availability:
http://www.shopjimmy.com/catalogsearch/result/?q=Vizio+E421VA&restrictBy[master+part+type]=Panel
Nov 24, 2013 | Vizio E421VA 42-Inch 1080p LCD HDTV, Black
Cracked screen on lg lcd tv small crack 6in up an 8in from right can still see picture ok but have a 1in white line running down from small impact area and a light grey 1in line across from impact area...
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jul 22, 2017 | LG 32LD450 32 In. LCD HDTV
KDL46W4100 no picture small white crack is visible when turned on. Crack got longer and eventually went across entire screen. People have told me the lcd is broken and it's not worth fixing - ie the part...
Yes, thats correct.
If lcd tv screen got hit by some thing then lcd panel got cracked and does show distorted lines or cracks instead of picture and lcd panel have to be replaced that would cost you 70% to 80% of new tv price.
New TV is better option.
Dec 16, 2009 | Televison & Video
I think the inside panel is cracked
Yes lcd screen is cracked. No way to repair, other than changing screen. Cheaper to buy new tv.
Jul 20, 2009 | Vizio L32 32 in. LCD HDTV
MY SCREEN IS WHITE
Your LCD screens are cracked. Almost any significant crack will make the entire screen "go white". If you LIGHTLY press on the screen you'll probably see where the crack is (appears as a small black or multicolor line and may or may not "bleed"). You need to replace the screen (at a repair shop, mail in service, or DYI with a replacement screen) or get a new phone. Sorry.
Nov 21, 2008 | Samsung SGH-d807 Cellular Phone
LCD SCREEN
Cracked your LCD screen, the black lines are where it broke.
Nov 03, 2008 | Sanyo Xacti VPC-T700 Digital Camera
Kodak EasyShare C743 Digital camra has cracked LCD
Hey iheartcheer,
If you intend on paying someone to replace your lcd screen the repair will most likely cost more than the value of the camera, but you could have an estimate done at an authorized service center.
Sincerely,
Allan
Go Ahead. Use Us.
Apr 18, 2008 | Kodak EasyShare C513 Digital Camera
You can find a replacement LCD for Kodak EasyShare C743 in this link:
http://www.pantallas.biz/epages/wwwpantallasbiz.sf/secFpd27LFqGPg/?ObjectPath=/Shops/160419/Products/%22Kodak%20C743%20713%22
Jan 08, 2008 | Kodak EasyShare CX7430 Digital Camera
Vertical line on LCD screen
hi unfortunately you'll have to replace the lcd display
Aug 09, 2007 | HP Compaq nc6000 Notebook
Pentax Optio M20 Digital Camera Logo
21 people viewed this question
Top Pentax Cameras Experts
mohamed salim shaikh
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
