Question about Dell 1700 Laser Printer
IMAGE SHIFT THE IMAGE HAS SHIFTED 3/8 OF AN INCH TO THE RIGHT OF THE PRINTER. IS THERE ANY FIX (TO THE RIGHT FACING THE PRINTER) I DON'T SEE ANY WAY TO SHIFT THE IMAGE BACK.
  • 10 more comments
  • epsjr Dec 20, 2008
    "IT SOUNDS LIKE THE ION THE DOCUMENT PROGRAMS HAVE BEEN ADJUSTED" MEAN. I DON'T HAVE A CLUE!
    THE PAPER IS PROPERLY SET.
    MARGIN ADJUSTMENTS ARE OK.
    DID NOT FIX. ANY OTHER SUGGESTIONS
    HELP
    STILL NO SOLUTION. WILL CHECK BACK LATER. IT IS NOW 11;00.
    WILL SEE
    All the suggestions do not apply. Is there a way to shift the image?
    ALL THE SUGGESTIONS ARE OF NO USE. IS THERE ANY WAY TO SHIFT THE IMAGE BACK TO THE ORIGINAL. THE PROGRAM I'M USING IS USING A FIXED IMAGE AND DOES NOT PERMIT ANY MARGIN SETTINGS.
  • epsjr Dec 31, 2008
    I'm using Insta-Pay form Cheque-Mate.
    Correction: change "form" to "from"
    I'v changed both the drum and cartridge. I then replaced the original, changed to a new cartridge. No luck.
  • Dell Master
  • 2,386 Answers
This can only happend because of two factors:-
either the printer drivers not installed properly or
the paper does not match with the printers properties paper.
Posted on Dec 20, 2008
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Your comment "MARGIN ADJUSTMENTS ARE OK" would be referring to the Page Setup inside the application itself. Please verify the Paper Size inside the Printing Preferences of the Dell 1700N Properties. Open your Printer, right click on the icon of Dell 1700N, click on Properties.
Good luck and Thank you for using FixYa. Happy Holidays.
  • 405 Answers
I honestly just had this problem printing business cards, Be glad to help if I can, it's free unless you want to donate, I have never made a dime on this site but have helped lots of people and I will try to help you.
  • 7 more comments
  • David Johnson
    David Johnson Dec 20, 2008
    I personally agree with others suggestions about setting you margins. I fyou do not understand, please post?
  • David Johnson
    You must be a late night owl too, When you run your pint setup, do you know how to adjust you page settings?
  • David Johnson
    Thank you for your generousity, I will do everything I can to help you, Your my first real dollar, and I will do my best to help you find a solution to your problem. Just, remember it is the holidays, and it is family time, I have three Christmas parties this weekend, but i promise I will get back with you, I am tired but I do appreciate your vote of confidence, God bless you and your family, and Merry CHRISTmas
  • David Johnson
    David Johnson Dec 30, 2008
    Could you tell me which program you are using so that I can research this this evening! I'll get to the bottom of it for you, I am sorry I have been away from the computer,
  • David Johnson
    Sir from the little research I've done the only thing that seems to work is to replace the drum. I have read at other sites that is is a tipical problem with this printer. But please let me know what software your using so I can delve further. This is a place that sells them online! http://www.officesupplyoutfitters.com/17...
  • David Johnson
    David Johnson Dec 31, 2008
    Do you have a spare toner cartridge you could try, and have you tried un installing and reinstalling the one you have? The only reason I ask is I read somewhere that these particular printers are prone to doing this, and have also read that if you replace the toner and drum it will fix it. I am thinking that maybe this may be your particular problem. You will need a new one at some point any way so I think it would be worth a shot before you blame the program, I will do some more research and get back to you, but if in the mean time you would try that I think it might actually fix the problem.
  • David Johnson
    I will research further right now!
  • David Johnson
    I found this another website :
    I had a paper jam this afternoon and since then when trying to print an e-mail the left margin measures the .250 it is supposed to but thefirst character in the lines is only about 1/2 there. An 8 looks like a 3 for example. Did something get knocked askew?
    did the paper come out all in one piece when the jam occured, or did it come out in pieces?
    one thing I would suggest is, try setting the margins over in word by 1/4 inch, see if it keep happening, and if it doesn't, try setting it back.
    if it does, then probably that paper jam knocked out the alignment sensor. in which case, I would suggest calling Dell.
    This guy supposed services these machines, there were other comments about paper pieces causing the problem, one person wrote in and said he found a business card stuck inside causeing his problem.
    I also read in the owners manual the following, and I think may be your problem, please try this
    Dell Local Printer Settings Utility
    This application is not available when the printer is connected to a network.
    Use the Dell Local Printer Settings Utility to change and save printer settings not available
    from the printer driver. When you change these settings, they remain in effect until you
    make another selection and apply it, or until you restore the original printer settings (called
    factory default settings). The settings are organized by menu, much like a printer operator
    panel.
    The Dell Local Printer Settings Utility is installed automatically on your computer when
    you install the Dell printer driver. Click StartPrograms or All ProgramsDell
    Printers
    Dell Laser Printer 1700Dell Local Printer Settings Utility. The Dell Local Printer
    Settings Utility only functions with printers connected directly to the computer.
  • David Johnson
    Please notice in your owners manual it says the printer cannot be on a network when you use this utility.
  • 2,427 Answers
Ok here are the possible causes
1.) the print margin on the program you are using must have been mssed up. go to the print preview on the program to verify this.. you will see where its out and you can move it back into place.
The printing preferences on the printer setup is off. slick start, printers and faxes, right click on your printer and click properties,, you can adjust it there.
I'm betting its the program your using, the ruler tab adjustment must have been accidently moved. The ruler is displayed above the work area with a notch where the current margin is. just move it back into place and your done. you can verify this using the print previes function. Its located under print in the file menu.
  • Rishi Roshan Ali Dec 20, 2008
    when you click print preview you can move it back into place by clicking and dragging.
  • 837 Answers
Check to make sure that the paper in the tray is properly set
  • 6 more comments
  • Jay Glendenning
    Jay Glendenning Dec 20, 2008
    i think thomas_heime meant icon
  • Jay Glendenning
    margin adjustments should be checked
  • Jay Glendenning
    Try resetting the printer as follows:
    1.1. Reset Dell 1700n Memory
    To factory reset your Dell 1700 series printer follow these steps.
    1. Turn off your printer
    2. Open the front cover (push the button on the left side)
    3. Hold down the "Continue" and "Cancel" buttons and turn the power back on.
    4. When the "Error LED" light on the control panel is solid, close the cover and release the "Continue" and "Cancel" buttons.
    Tip: To print a configuratoin sheet push the "Continue" button twice. This will give your printers IP Address.
  • Jay Glendenning
    Did you try the reset yet?
  • Jay Glendenning
    At this point I would remove the print drivers and reinstall, it may be coming from a registry or printer setting that "you" my not be seeing. Be sure to remove all printer folders (if uninstall doesn't).
  • Jay Glendenning
    As an additional idea .. Can you test this printer with another computer? If it works using another computer then we know where the problem is coming from .. Otherwise it is the printer itself
  • Jay Glendenning
    Jay Glendenning Dec 21, 2008
    EPSJR,
    Have you tried using this printer connected to another computer yet?
    Crayz
  • Jay Glendenning
    Jay Glendenning Jan 01, 2009
    Just out of curiosity .. When are you going to try this printer with another computer?
    Sergeant:
    Champion:
  • 247 Answers
Welcome-
it sounds like the margins ion the document programs have been adjusted.
tom
  • 2 more comments
  • Thomas Dec 20, 2008
    here is a suggestion for you:
    how to adjust margin on printer
    In the case of some printers there is no margin requirement, however generally a margin of around 0.25 of an inch is left around the perimeter in which no images, coloring and text will be placed. This area of a print-out is called the unprintable area and some printers require that there be an unprintable area in order to function correctly. One way of checking the unprintable area on your printer is to open an application, such as WordPad for example, and from the page setup option, within file menu, you can see the size of the margin that is being selected automatically for your print-outs. When you type zero, or any lesser number, you may notice that the application automatically changes this to a higher value. If this occurs, it is because your operating system believes that the printer is not capable of printing with a margin that small. Once you are aware of the limitations of your printer you can now select the margin which you feel is most appropriate to your needs.
    here is a link to a website that talks about different problems with dell printers and on page 8 it talks about how to set the margins in the printer.
    ftp://ftp.lexmark.com/depot/Dell/Dell_1720_Depot_rev061807.pdf
    i really hope i am helping you out.
    tom
    i feel that miss rated this solution. the person you gave fixya to didnt even give advice and here i gave you advice and a website to go to to fix your porblem but yet i don't the top rating. i think that i miss use of the website. i know that it is 6.00 but we as technician do alot of searching to give you a solution to your problem and then we dont even get what we earn thats abuse.
    tom
    did you try the website that i sent you? if not here it is again.
    this website tells you how to reset the margins for your printer.
    tom
    on page 7 of the website i sent you it tells you how to reset the margins using the program that came with the printer. i think it is done through the printer properties option. and just so that i know, what is the program that your using that you can't change the margins? maybe the problem lies in that program not the printer.
    i'm sorry for the confusing but i'm just trying to understanding what is happening so i can help you out.
    thanks
    tom
Compute the nth root
The nth-root function is the right-shifted function of the square-root key, second column from the left, fifth row from the top.
In RPL mode, to calculate the third root of eight, press 8 ENTER 3 right-shift [nth-root] and get 2.
In algebraic mode, press right-shift [nth-root] 3 right-shift [,] 8 ENTER and get 2. (The comma is the right-shifted function of the SPC key on the bottom row.)
Oct 01, 2012 | HP 50g Graphic Calculator
HP Deskjet 5650 is printing off-center. The printing field is shifted to the right, so the right margin is non-existent and I lose a bit of the printing. How can I fix it?
I think the horizontal printing starting point can be adjusted by holding down buttons (??) when powering up. Right now my left margin is 3/8 inch too big -- photos have that much white space on left margin with borderless printing. I am trying to figure out the key combination.
Jul 27, 2010 | HP DeskJet 5650 InkJet Printer
Driving for 15 miles the transmission shifted to second gear and would not shift bact to drive. Two day later i drove 3 miles and every thing was find.
Had same problem with my '96 Windstar. Standing in front of the car and facing the engine, found that the vacumn hose coming from the rear to the upper right side of the engine top cover had swollen and was loose enough to allow air to flow in reducing the vacumn enough to affect the transmission shifting. The warmer the transmission fluid got the more it wanted to down shift and stay in the lower gear. Have your vacuum system checked, it could be leaking at any number of places. Hope this helps.
Mar 29, 2010 | 1996 Ford Windstar
Bad Printing and Stripes on Printed Sheets on HP 1100A
It isn't a fuzer problem it is most likly a image drum problem. To fix you have two choices replace the image drum with a oem part or a refurbished part or replace the printer. sometimes it is cheaper to get a replacement printer than to replace this part.
Dec 30, 2009 | HP LaserJet 1100 Printer
Code bar print are shifted one of 3 are correct
To reset the printer to its factory default settings, hold down the FEED button until the error LED has completed its FOURTH set of flashes. You can the reset any changes that you had to make initially when first using the printer.
Dec 29, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Tv image shifted right
Horizontal hold IC and circuit is failing The remote signal will cause it to spasm because of this faulty set of parts. It needs professional intervention to fix this properly
Sep 25, 2009 | Sony FD Trinitron WEGA KV-27FV310 27" TV
Picture not centered on my philips 47'' lcd tv
NOTE:(Edited and copied from another thread on Fixya.com, c7carl)
Picture is not centered on monitor leaving a 2 1/2 inch; black border on Philips LCD
By dmorrow54 on Nov 13, 2007
Again, nothing in manual for Philips LCD will correct the fact that the picture in HD-D mode will not center. The picture runs off the monitor on the left (facing the monitor) with a 2 1/2" black border on the right (facing the monitor). Using the format button on the remote of directional arrows will not correct the issue. The wide-screen/ full-screen function with format does nothing. Moving into TV mode, the format function works to display screen in several ways 4:3, 19:2, super-zoom, wide-screen, full-screen. Help, please. posted 3 years ago
Guest
  • Rank: Guide
  • Rating: 0%, 0 Votes
I have a Philips 30 inch LCD and solved the problem by using the circular arrow button on the TV remote. Pointing it at the TV and clicking "right" (3 o'clock on the button), the picture moved right. Same thing on for "left". Worked for me.
Add a comment
    • c7carl
    • 5 minutes ago
    WOW! It works!! The picture on my Magnavox (aka Philips) 37MF321D had shifted to the right. I figured I had a big repair bill coming up soon. But hey! Just used the TV remote as described by "Guest', and re-centered the picture to the left. Wallah! Thanks ""Guest" whomever you are! Reply
    Posting advertisements, profanity, or personal attacks is prohibited. Click here to review our Terms of Use.
    Comment:
Feb 05, 2009 | Philips 47PFL5603D 47 in. LCD HDTV
Printer problem -Dell Laser printer model 1700.
make sure the side guides in your paper tray are tight against the paper.
Dec 19, 2008 | Dell 1700n Laser Printer
Entire image shifted
Press the Select/Auto button. The monitor will then automatically adjust to match the incoming signal and will save that setting in the internal memory of the monitor.
Nov 06, 2008 | Hyundai L90D+ 19" LCD Monitor
Margin problem???
I can just guess it has to do with the paper being fed. either you have the paper wrong or the paper settings to a different size then the actual dimensions of your print material.
Oct 24, 2007 | Dell 3100cn Laser Printer
Dell 1700 Laser Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
