Question about HP Office Equipment & Supplies
Printer does not print second line of mucis
I arrange and print a lot of music. The printer will not print the music staff [the lines and spaces] after the first staff across the page. When I check the print pre-view, it show all the music, but it prints only one staff across the page. It has just started doing that. It has been printing all the music perfectly.My printer is a : HP Photosmart D5460I boutht it new from Office Depot on Tunnel Road in Asheville,NC about 2 weeks ago.Earl R. Rogers
5 Suggested Answers
  • 390 Answers
SOURCE: vertical and horizontal lines when printing photos - HP Photosmar
it sounds as if you may have the picture quality set to draft, its worth a check, especially if printing is ok. Does it print colour writing well too or just black, one of the colour inks may have a block or be low, go into printer settings menu and check what print quality its set for.
Posted on Apr 26, 2009
  • 68 Answers
SOURCE: printing with a black horizontal line across bottom of the page
Wipe the cartridge.Use cotton but dont put water on it only cotton.if you have deiones water its good to use.
Posted on May 20, 2009
57 varieties
  • 1653 Answers
SOURCE: Dell 5100cn printer printing yellow lines across the page.
This can be any of rthe following depending on the position iof the lines on the page. You need to establishe the position of the lines relative to the top of each page and this determines which of the following component will cause the problem
Dirty or damaged developer roller.
Dirty or damaged charging roller.
Dirty or damaged cleaning roller.
Dirty or damaged developer DSD wheels. These wheels are located on the outer ends of the color toner cartridge and appear as a black bushing.
Dirty or damaged transfer roller.
Dirty or damaged transfer drum.
All of them need inspecting and cleaning
Posted on Sep 26, 2009
WCISERVICE
  • 50 Answers
SOURCE: Unit has stopped cooling (6
CONTACT THE MANUFACTURER THEY SOME TIMES WILL PUT YOU IN CONTACT WITH DEALERS OR SERVICE COMPANIES IN YOUR AREA THAT HAVE BOUGHT PARTS FROM THEM OR HAVE WORKED WITH THEIR UNITS
858-566-7473
Posted on Sep 16, 2011
How to change Tally T2240/24 Matrix Printer character and line spacing
This sounds like an Microsoft Excel issue. The Windows printer driver controls how printing is done regardless of your printer settings.
Excel controls the format of your page with column widths and line height. Depending on your version of Excel, after selecting your print range and your margins, you will need to go to Page Setup and select "Fit to" -- select 1 page wide and a larger number of pages tall.
Jul 25, 2014 | Tally T2240/24 Matrix Printer
Line spacing
What brand is your printer?
Jan 09, 2014 | Epson Stylus NX200 Printer
When printing clip art, photos, etc. my graphics constantly have a series of evenly spaced lines crossing the art work. I can't find any printer head cleaning prompts. Even when I replace the ink...
Hmm, nozzles are blocked. Try Isopropyl Alcohol on a cotton tip or better still, a rag piece and run under the print head.
If this doesn't help, maybe this video will -
https://www.youtube.com/watch?v=CspEIN8EsZ4
Lastly, the printer should have come with a program that can clean the print heads.
Dec 24, 2017 | HEWLETT-PACKARD Hewlett Packard Officejet...
I am getting horizontal lines on the printed page. the quality of the print if fine for the exception of the three horizontal lines. The first line is about one inch from the top of the page, the second...
Regularly spaced horizontal lines suggest that there is a defect on the drum in the printer. I would suggest changing the drum to see if that will fix the problem.
Oct 08, 2010 | IBM Network Printer 17 Laser
Printer keeps skipping lines when printing. very annoying
is this a case of the dots are missing for a valid line, or do you mean a line feed is added at the end of a line, ie you get 3 lines of text occupying 4 lines of space , or 4 lines of text occupies 4 lines of space, but one line has no printed dots on it? to make it more obvious, what does a document with say text thats 3cm tall look like? as it sounds to me like contacts need cleaning.. *** note for info: do not rely on printouts from within a BROWSER as that may have unpredictable results. All text will be treated as a large block of PIXELS and Not TEXT. also Non Printer fonts could cause similar issues.
Nov 09, 2017 | HP Photosmart 2710 All-In-One InkJet...
Lines in the printing
Join the Yahoo Group for Alps printers. There is a lot of information there. Have you cleaned the print head? Refer to the Users Guide for how to do it. Lines in the printer output can indicate a bad printer head.
Mar 11, 2009 | Alps MD 1000 Thermal Printer
I have a problem when printing i get lines on my photo ,s
A horizontal black line on the printout is probably the result of a dirty or damaged roller. There are lots of rollers in the printer, and you can use the space between the lines on the page to determine which roller is causing the problem.
If it is vertical line then it indicate an almost empty or faulty toner cartridge or some spilled toner inside the printer.
if you require further help feel free to ask
mention your model no
how old is your printer ?
Thanks for using Fixya
SAM ANDERSON
Sep 13, 2008 | Cannon Office Equipment & Supplies
Spaces in printed lines
then the problem is in cartridge replace them asap, no other way around it,
cheers
Sep 04, 2008 | Dell 922 All-In-One InkJet Printer
Printer Problem
Change the settings in MS word. Your looking for line spacing. Set line spacing to 1. Can't find line spacing? Open Help, type in the search window (line spacing). Try printing now.
Jan 31, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Citizen iDp 3550 prints double-spaced
It is a dip switch setting, on dip switch #6, it needs to be "On" It will then single space the lines. After re-setting the switch under the cover, turn off the printer for 30 seconds to clear the buffer...then holding the "LF" button, turn it back on, until its self test is complete. You problem will be over.
Jan 14, 2008 | Citizen 3550 Matrix Printer
44 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
