Question about Minn Kota Maxxum 70 Freshwater Bow Mount Trolling Motor
Cannot get the throug bolts in the lower unit started.
I had to replace the pole on my Minnkota Maxxum 65lb thrust motor and when I did the wires got twisted inside the lower unit and then came unplugged inside the lower unit. I had to take it apart to get the wire plug back in and now I cannot get the lower unit bolts back in. It is like the two bolts are two short. I am very frustrated.
  • 1 more comment
  • jscottjolley Dec 20, 2008
    to get the thru bolts started in the lower unit what do you have to do first?
    the long thrugh bolts dont seem to be long enough to put my lower unit back togather what is the trick to get the bolts started?
    thank you so much i got it >thanks to your advice
    Sergeant:
    Champion:
  • 247 Answers
Welcome=
here is a exploded view of the trolling motor i dont know if it will help you or not:
http://www.northlandmarine.com/MinnkotaMaxxumTransomMnt.html
hope this helps you
tom
Posted on Dec 20, 2008
  • 199 Answers
Might this give you idea.
hope this helps.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, the reason is the 2 brushes are not resting against/on top the commutator segments of the armature. The commutator segments are the thin slivers of brass (narrow, long) cut in rectangular strips encircling the lower part of the armature. Rather, the brushes are blocking the armature from settling down towards the rear end part of the housing.
There is a technique - the carbon brushes have to be squeezed back into its recesses before sliding into the armature affording the brush holder/plate to mount. One trick is to use stiff wires to act as opposing prongs holding the brushes back while inserting the armature. In some designs, there are "peep holes" with rubber cover allowing the insertion of hooked wires to pull the brushes back.
Good luck and Thank you for using FixYa. Happy Holidays.
  • Louie  Role
    Louie Role Dec 20, 2008
    Glad to be of assistance and appreciate the rating too.
    Tight lines.
  • 365 Answers
Try to cut some part of the wire which may be safe and try .thank you
  • 2,427 Answers
You must have mixed up the bolts,, or didnt mount it back up correctly,, You took it apart you can put it back together,, If you want a short cut ,, go a hardware store and but bigger bolts with the same threading,, cut them to the size you need and put them it..
  • 1 more comment
  • Rishi Roshan Ali Dec 20, 2008
    I'm preety sure you assembled it wrong or didnt line it up correctly.
    oh that you mean.. Sorry,, ok first thing is you need to line it up propperly, there are notches where its supposed to pass through. :) Its all in the line up.
    squeeze the pins in with a pliers !!!!!!!
I have a minnkota maxxum 74lb thrust trolling motor. The pedal pin in the foot control keeps sliding out on one side and I have to push this back in to stabilize the pedal. Is there something...
Good day ,
The next time the pin comes out have a close look at it if it has little raised grooves in it that is what is supposed to hold it in.
if so put a little lock tight on the pin and push it back in it should hold again
good luck
Gordy
Nov 03, 2017 | Minn Kota Maxxum 70 Freshwater Bow Mount...
Can you change a motorguide 65lb thrust foot control model with fix speed settings to a variable speed
well a "Speed Controller" can usually be used on ANY DC/AC motor, depending on type, some motors just will not work, with a speed controller... Think of it a bit like a "Light Dimmer", with the "Bulb" being the "Motor"
Have a look below for info. www.stefanv.com/electronics/escprimer.html
Mar 05, 2010 | MotorGuide STANDARD MOTOR REPLACEMENT...
Looking for parts brakesdown minnkota 101
Google the Make and model...dozens of web sites, including MinnKota,
Dec 16, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
Minn Kota 65lb thrust 24v
Hello!
Your unit was desined to run on 24 Volts.
The control unit (electronics) will not run below 19 Volts (19 or 20, I can't remember) and the armature windings and magnets are designed for 24V as well. So, an easy answer is no your unit will not operate in 12volts.
Hope this helps out!
Mike
Sep 26, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
Minnkota maxxum 70 has half the thrust is had before
Sounds like a bad connection somewhere. I would take it to a authorized dealer for repair if it's still under warranty. Can get a bit tricky to repair yourself unless you're comfortable with soldering.
Aug 18, 2009 | Minn Kota Maxxum 70 Freshwater Bow Mount...
I need to replace the bearings in my Maxxum 65lb Thrust trolling motor.
If you never did this before , I strongly advise take it to a local shop....if you don't seal it correctly, you will end up buying a new one for water getting in.... I fix alot of things on my boat but not the trolling motor....your choice....GL
Jul 10, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
TOOK THE BOLTS OUT OF MINN KOTA AND CANT GET THEM IN. 2 SHORT.
Hi!
Here's a schematic:
Max 74 Bowmount
Make sure the end housing #7has a small mark in it pointed to the bottom (towards the skeg). The bolts can be a pain to line up!
Also make sure the armature is all the way forward it can go....past the brushes is the toughest part to get through and lined up. Keep it up, you'll get it!
Best of luck
Mike
Jul 05, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
Looking 4 a manual on a minnkota turbo pro 824 48 lbs thrust motor
This isn't my usual area of expertize, but is this what your looking for?
Minnkota 824 Motor Diagram
Mar 20, 2009 | Computers & Internet
Minn Kota Maxxum 70 Freshwater Bow Mount Trolling Motor Logo
79 people viewed this question
Top Minn Kota Boating Experts
Mike Marcotte
Mike Marcotte
Andrew Taylor
Andrew Taylor
Colin Stickland
Colin Stickland
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
