Question about Mitsubishi WS-65809 65" Rear Projection Television
Need help hooking up the computer to the tv. - Mitsubishi WS-65809 65" Rear Projection Television
  • 4 Answers
You have to have the right video graphics card for the tv connections (hdmi, s-video/vga/dvi) what video card do you have installed on your cop or do you have one on it at all, or you still using the intergrated graphics card= what came with cop when purchased, attached to the main mobo (some to think about are nvidia, ati.etc.) p.s. the tv has to have one of these in order to get the pix on screen
Posted on Dec 20, 2008
Tv hooked up to computer. connected audio cabe to vga audio in. still no sound. help.
I'll need a bit more information on your issue to help you first:
1.) You said: "trying to get sound on the tv to the computer". -- Did you perhaps mean that you're trying to get the audio which comes out of your computer to "play" on your TV?
2.) If I assume correctly, then you have the audio cable connected to the wrong place on the computer.. and possibly on the wrong place on the TV. If you are indeed trying to get the audio from your computer to play through the speakers on your TV, then you need to:
(this is also assuming you're using a "headphone jack-sized" plug on one end, with the other end being the old-style "RCA" left and right channels.. [Left = white; Red = right])
Firstly, the 'headphone jack"-style end of the audio cable needs to be plugged into the "audio out" or "headphones" jack. Sometimes the audio jacks on a computer are color-coded. If this is the case, the green jack is the one you want.
Next, the other end (which again I'm assuming are the left / right channels -- [white / red plugs]) needs to be plugged into the "audio in" on the TV which matches with the same input as your VGA cable is plugged into. Once the cable is hooked up in this way, you should be able to hear all audio coming from your computer on your TV's speakers.
Please let me know if I'm assuming incorrectly on what you're trying to accomplish with the audio. -- I hope I was helpful! Please let me know if you have any other questions!
Apr 01, 2014 | Proscan Televison & Video
Tip
How To Connect Flat Panel TV to Computer
Hello <br /> First identify your TV's input connections. Most TVs these days have three basic types of inputs. You have your coaxial cable input, the same as your cable box or satellite, an RCA composite input (the yellow, red and white inputs) and an S-video connector. Newer televisions might have Component Video, DVI, VGA or HDMI inputs but the ones listed above are more common. <br /> Identify your computer's outputs. These days computer manufacturers are adding TV compatible outputs on their products so it's easy to have a pc to tv connection when you hook it up. The S-video in particular seems to be popping up on more and more computers, so a PC to TV S video connector might be what you need. You can shop for S-video cables all over the place online. Mostly you will find the usual VGA output that the regular monitor hooks up to (see more later on VGA cables). The newer multimedia computers will probably have all high definition outputs that connect directly to your HDTV, but for now we will deal with what most people have for both computers and televisions. <br /> Find the appropriate adapter for your connections. You may need to get a computer to TV cable so you can hook up your computer to the TV. If you have an HDTV, you may need a VGA to component cable. This VGA to component cable connects your computer to a HDTV and acts as a converter. (And that computer could be either a Mac or a PC.) <br /> A PC to tv connector has a VGA adapter on one end and (usually) a selection of connectors on the other (S-video, RCA composite and Component). The good thing about these is that you can take it from TV to TV and you'll be able to hook up computer to TV for all of them. I highly recommend a wireless adapter. It costs a bit more but wireless is worth not having a big cable mess and not keeping your computer near your TV. <br /> or you can get help from this video <br /><br /><img src="utube.png" /><b><i> You-Tube video "ZCN-nN1orYE" placeholder (do not delete) </i></b><img src="utube.png" /><br /><br />Hope this helps, if so do rate the Tip.<br />
on Jan 25, 2011 | Televison & Video
My TV won't play the sound from my laptop when I hook it up with HDMI cable.
Connect the hdmi (in) to the TV and the computer hdmi. Go into the sound settings (control panel or settings in Windows... preferences on a Mac) and choose the hdmi as the playback device. Also check the volumes on your TV and computer. If you said what OS and what version of that OS you were using, I could be more specific.
Jan 05, 2018 | Gateway Computers & Internet
Need hook up for computer
Hook up to Computer
• Identify ports that you have on your computer , look for Video Out
( read your computer manual )
• Identify Audio and Video inputs of your TV
( read your TV manual )
To hook up ,
• Computer Video Card Out
( set it to use a secondary monitor )
to TV Video In
• Computer Sound Card Spk Out to TV Analog Audio In
Aug 03, 2012 | Hitachi Televison & Video
How do I hook up my hp computer to my lg flat screen tv
You can use the TV's VGA port which needs a VGA cable which you can get from a computer hardware store. It's called RGB in on your TV. This is also called PC input.The max resolution you will get is 1,366x768 off your PC.
Jan 25, 2011 | LG 32LG30 32 in. LCD HDTV
Can a computer be hooked up to this tv, if so how?
A computer can't be connected directly. You will need a video converter of some sort to go from VGA to Component Video. If your computer's video card has TV-out functionality, you just need a VGA to component video cable. Otherwise, you will need a set-top box converter, such as http://www.svideo.com/hiwire.html .
I wish I could be of more help.
Jul 11, 2010 | Akai PT4250A 42" HDTV
I have a dell precision m60 and I want to hook it up to my hitachi 55 plasma tv Ive tried to do this via s-video without success
Trying to hook up your computer to the tv? Or the monitor to the tv? Anyways, you can't hook up the monitor to the tv to see the same thing on both. But for the computer to the tv, connect the s-video cable to the tv from the computer, and you have to press (on the computer) ctrl+alt+F2 or ctrl+alt+F1 it's different for some computers. But if that's what you tried to do, that's the way you do it.
Anyways, hope this helps.
Jul 14, 2009 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Graphics card upgrade
if u have a separate VGA and TV out connector from VGA to TV just u need to set in the computer graphics.set as 1st graphics out TV
May 23, 2009 | Gateway GT5654 Desktop PC
Computer To Tv Problem ''Over Sized''
the tv's setiings need to be set to auto or correct resolution
for the image you display , try going down in res until it looks right then find other ways to make it fill the screen IE stretch etc..
hope this helps
Dec 30, 2008 | Nvidia GeForce 9800 GTX,, PCI Express...
Is it possible to hook this system to my DVD
If you have RCA outputs on the Logitech Z-5300 then just plug the rca leads into your video or tv's audio out's
Apr 18, 2007 | Logitech Z-5300 Computer Speakers
Mitsubishi WS-65809 65" Rear Projection Television Logo
43 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
