Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Replacement Caps for Power board WD-52525
Okay I see 2 blown cap on my power board. C9A37 and C9A38 as other have previously stated this is what I was looking for. Besides ordering these caps from Mits who doesn't have them "in stock" has anyone found another supplier to order these from?
Any help can be sent to Skoobie1515@yahoo.com thanks a ton.
  • 41 Answers
You can check out www.tritronicsinc.com just look for correct values VOLTAGE, VALUE, TEMP 100C or call 800-638-3328
Posted on Dec 21, 2008
3-5 error code on mitsu wd-52725(chassis fan failure)
Check the power PWB pico fuse F9A09 and if thats good check the following capacitors all on the power pwb.
Power Supply
C9A52 1000uF 16V
C9A59 1000uF 16V
C9A61 1000uF 16V
C9A62 1000uF 16V
C9A39 2200uF 35V only some versions
have this cap.
C9A40 2200uF 35V
C9A37 3300uF 16V
C9A38 3300uF 16V
Feb 28, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Faded pictures it is caused by leaky or short capacitor it could also be power supply problem causing the optic engine and light not to work correctly, or you could have a bad DM board, or a bad light engine sounds like a bad DM board find six of the fourteen known-problem caps to be visibly bulging -- both 3300s and two of the four 1000s on the PWR PWB plus two of the four 1000s on the FMT PWB (see photos below). Ironically of the four 1000s on the DM PWB, which I have heard are the most common to go bad, were bulging and I considered skipping these as the DM it is the toughest board to extricate from the chassis, however I figured I had come this far and I would just as soon replace all twelve 1000 uFs as the parts cost $0.23 and I really never want to have to do this again.
If I had to bet, the two 10V 3300uF caps on POWER board, which were actually leaking black goo, are the actual culprits, but with four of the 1000 uFs also bulging it is probable only a matter of time until they failed as well.
Here is the POWER PWB with the known-problem caps (C9A37, C9A38, C9A51, C9A52, C9A61 and C9A62) highlighted:
here's the FMT PWB with the known-problem caps (C8F19, C8F21, C8F22 and C8F27) highlighted:
and the DM PWB with the known-problem caps (C81A2, C81A3, C81B3 and C81B4) highlighted:
Here are close-ups of the bulging caps (C9A37, C9A38, C9A52 and C9A62) on the POWER PWB:
And here are close-ups of the bulging caps (C8F19 and C8F27) on the FMT PWB:
Hope it may help you; Regards;
VOTIT
Jan 29, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-62525 Red Status Light After Cap Replacement
A steady red light: there is a short on the DVI cable from FMT to DMD disconnected
Sep 09, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Continuous blinking light
Good Day, mossberg142;
No, replace those CAP's with original value. Good Luck,
big IRISH.
Sep 06, 2008 | Televison & Video
Air flow blockage
Take care of it NOW. We ignored the error (knowing we're under a service plan so we'd get to it eventually). Then last week the TV just cut out and we got no picture and the red lamp light came on. Service guy came out today and replaced the lamp and it didn't work and then called Mitsubishi. They said it is probably a very common capacitor problem on the power supply board. If you open the back and take a look you are likely to see bulging caps. Parts C9A37 and C9A38. The caps are cheap if you can find them, but the parts are really hard to find right now so Best Buy is actually replacing these for people under service plans rather than fixing them. The message you are getting is a sign that the caps are getting too hot and need to shut down to cool off... It will eventually ruin your lamp if you let it go on.
Good luck! BTW, our guy said the repair will run you about $200 if you can't do it yourself, but someone else on this board with guru status recommends a kit that comes with a CD and a manual that will help you fix this. They even give a web address to order it. If we weren't under a service plan I would be going this route...
Aug 10, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi Proj TV WD-52825 will not turn on. Continuous blinking green light...reset and unplug no help...HELP!
Good Day, Markes;
You and a million others are having this problem. Are you handy? Did you say; yes/kind of?
HERE IS THE SOLUTION FOR THAT PROBLEM AND THE ONES YOU WILL HAVE IN FUTURE:
Replace C81A2,C81A3, C81B3 AND C81B4 (1000uFD, 16 V) On DM PCB.
Replace C8F19, C8F21, C8F22 and C8F27 (1000uFD, 16 V) On FMT PCB.
Replace C9A51, C9A52, C9A61, C9A62 On power PCB.
REPLACE ALL WITH (680uFD, 16V, 105c), part number 181P734030.
Replace C9A37 and C9A38 ON POWER PCB. (3300uFD, 16 V).
Good Luck, big IRISH.
ps; Three boards on left side of TV and about 2.5 to 3 hours of repair time.
Aug 05, 2008 | Televison & Video
Mitsubishi DLP WD - 62525 TV not working
if the lamp led is on you need the lamp, also could be bad ballast
Aug 04, 2008 | Televison & Video
Mitsubishi WD-52525 Capacitors
Try MCM electronics. You need two 3300mf/25 capacitors. C9A37 and C9A38. Get the high temp caps 105 C
Dec 19, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Blue screen with white snowy circle in the middle of screen
Sounds like bad capacitors
Replacing the C9A37 & C9A38 caps or
problems with some capacitors on the pwd power board, and that it would be good to change them if they were swollen
Oct 20, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
83 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
