Question about Sony KV-32V35 TV
Is the sony kv-32v35 digital ready?
Is the sony kv32v35 digital ready?
  • 4,234 Answers
I believe that the tuner on this set assumes an analog signal. The tuner itself is a digital one, in other words handles tuning in a digital fashion. If you have cable or satelite service, the changeover in February 2009 will have no effect on your set. The changeover will only effect those that use rabbit ears or a rooftop antenna.
Dan
Posted on Dec 29, 2008
    Sergeant:
    Champion:
  • 247 Answers
If the tv is less than two yrs old than yes.
Posted on Dec 20, 2008
My t.v.keeps blinking on and off
check horizontal output (transistor near flyback) for leakage...
May 08, 2010 | Sony KV-32V35 TV
My TV does not have an image, does not turn on, what might be the problem?
The power supply is evetually the problem. Which is not recommanded to customer to fix. because of danger.Make sure your outlet has power comes to it or move the TV to another outlet, and try it.
Otherwise you may see a qualified technician
Oct 09, 2009 | Sony KV-32V35 TV
Please tell me if model #kv32fs100 is digital ready (sony trinitron)
Your set has a NTSC or standard anolog tunner. To watch digital programs you must have a catv box or a DTV converter.
Apr 17, 2009 | Sony FD Trinitron WEGA KV-32FS100 32" TV
I don't know if my sony trinitron kv-2742 27" tv needs a box
Given the history of the aquirement, I checked the model number and there is no reference to be able to receive digital. You can buy a convertor box anytime they are available to use on the set. There is no deadline to hook it up.
Feb 15, 2009 | Sony KV-27V42 27" TV
Is a Sony model kv-27s20 digitally ready
its only the one that have the code 4674w on the back and cover
Jan 26, 2009 | Sony KV-27S20 27" TV
Digital tuner?
Good question, Mike. I wondered about my fs210 model, too, and I found the answer at a Sony tech-support site.
1. Go to: http://esupport.sony.com/US/perl/select-system.pl?DIRECTOR=DOCS
2. Enter your TV's model number, which, in this case, is: kv-32fs100 (and then click on Continue).
3. At the resulting page, under "Support by Type" in the left margin, click on "News & Alerts."
4. At the next page, click on: 04/02/2008: Critical: Is my Sony® television ready for the Digital TV (DTV) transition?
5. Your TV and mine are analog, but scroll down the page mentioned in #4, above, to see all of your options.
Consumers can determine whether any Sony TV is digital, just by entering the model number and following the steps listed above. ~ Kind regards, Gilda M. (replied 1/23/09)
Nov 11, 2008 | Sony FD Trinitron WEGA KV-32FS16 32" TV
Sony KV- 32V35 Front Jacks
Yes, the front RCA jacks on the Sony sets always seem to crack loose. I have seen that many, many times. To get to those jacks, you will have to remove the back of the TV and carefully pull out the main chassis, taking care not to pull out any wires or jacks. When the main chassis slides back, there is a smaller board in front of the main board, and the pushbuttons and RCA jacks are on that smaller board. The connectors to that board usually come off when you slide the main chassis back, so you will need to put those jacks back in place when reassembling. Slide the smaller board back, flip it over and resolder the connections on the RCA jacks. Sometimes I find that the copper trace to the center pin of the video (yellow) RCA jack is broken, so test for continuity and solder a small jumper wire to take the place of the cracked copper trace if necessary. Reassembnle the set and your jacks should be working fine.
Aug 31, 2007 | Sony KV-32V35 TV
No power.
Usually, in those Sony sets, a crack developes on a small transformer in the horizontal drive circuit, which causes the horizontal output transistor to short. This immediately shorts out the switching transistors in the power supply and blows the Sony 0.1 ohm resistor fuse. A shorted flyback (high voltage) transformer will also have the same result. The power supply does NOT need to be replaced. The parts should be replaced, the flyback checked and the board resoldered by a qualified tech familiar with Sony sets.
Aug 23, 2007 | Sony KV-32V35 TV
Sony KV-32V35
Could be a problem in the shutdown circuit,in the HI Voltage detection circuit,or the flyback transformer. If your not a tech, you shouldnt be experimenting by adding parts as its going to knock you against the wall if it bites you. You should start out with a service manual and check the voiltages as now thinking it could be the power supply voltage regulator also. Please call a pro to assist you with this repair. Good Luck
Aug 02, 2006 | Sony KV-32V35 TV
Televison & Video Logo
127 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
