Question about Asko W6221 Front Load Washer
Asko w6221 front load washer stops after wash cycle
A couple of weeks ago i cleaned under my washer with a brush designed to clean out under major appliances. Ever since that time my washer has stopped after the wash cycle. I have to manually change the dial to the rinse cycle in order to get my clothes rinsed. This works just fine but my clothes are not getting the highest quality rinse they get with the regular rinse cycle. I didn't know if there was some switch on the bottom of the machine i possible messed up and I need to get some muscle in to tilt the machine so I can flip this switch??? I need some guidance please
    Problem Solver:
  • 18 Answers
Do all of your cycles work when you turn them manually? If one cycle does not work when you turn the dial on it then it will be your timer (The dial assembly $100-up) If all your cycles work manually, then it could be your timer motor which is attached to your timer assembly. If you turn the dial pass the wash, on to the rinse, does the dial automaticly move (when finishng the rinse cycle)to the spin cycle? If so then your timer motor is ok. The only wires close to the bottom are the motor, but these should be high enough out of the way.
Posted on Apr 02, 2007
SOURCE:
Asko 6221 washer. push start button and here the click but the washer does not fill. Cleaned coin trap and cleared a dime from one of the lines
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Aug 13, 2011 | Asko W6221 Front Load Washer
Why is it not spinning out completely in spin cycle?
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 28, 2010 | Asko W6221 Front Load Washer
I have an Asko front load washer W6221. I have
I had identical problem. I diagnosed it to be the motor brushes on the front of the motor. They have an off switch in them when they get worn out. Easy to check and replace. Remove front lower panel (two torx 20 screws). Brushes are visible and are held with two screws each. One on each side of motor. Remove two screws on each brush and unattach wire. Two new motor brushes were around $75. Literally tooke 30 minutes to replace. Hope this is your issue!
Oct 14, 2009 | Asko W6221 Front Load Washer
Asko w6221 washer won't start
first I would check you drain pump ... make sure it is clear and clean.. next if you have a meter be sure it is getting power and that it is not shorted ...if it is not getting power then I would check the wires first then check your control.
Hope it helps if Not let me know more about you problem..I can help
Aug 02, 2009 | Asko W6221 Front Load Washer
Clothes smell.
Mold, mildew and other fun things use washers as a breeding ground. Clean your machine with a generous amount of white vinegar run through a cycle. Or there is a product called Affresh you can buy at Lowes or Home Depot.
Jun 21, 2008 | Asko W6221 Front Load Washer
Machine wont drain and the door wont open
The solution worked thank you, drained machine and cleaned out trap as per chapter 10 of user manual and all working fine now. Note: ensure to check up the inlet line in the trap with your finger as there could be some items in there, also check fan/prop to ensure it turns freely. Was amazed of what I found in the trap see picture below, pays to check pockets prior to washing.
Jan 20, 2008 | Asko W6221 Front Load Washer
Asko W620 washing machine not spinning
Sounds like the motor brushes need to be cleaned or replaced. Take the back off the washer, remove the motor and gently scrape the excess carbon or debris off the brushes with a pocket knife. I did this and it ran well for about 50 loads before building back up. I am ordering new brushes now because when I checked the brushes last week they were obviously worn more than 4 weeks ago.
Dec 11, 2007 | Asko W620
Asko w6221 washer
Try to replace the motor brushes. This is the most usual problem on these machines.
Good Luck
Nov 21, 2007 | Asko W6221 Front Load Washer
Asko W6221 Front Load Washer Logo
410 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Joseph Hoffmann
Lollo Pop
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
