Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
I installed a new garbage disposal and then connected the dishwasher hose--BUT--I guess I was to remove a plug so that the water can get through. How do I remove the plug?
  • 218 Answers
Knock out the plug with a big screwdriver. Lay the unit on its side and insert a big screwdriver. Drive it with a hammer if necessary, using short sharp, controlled strokes to avoid damaging the parts inside. See step 15 of the installation instructions here:
http://www.homedepot.com/catalog/pdfimages/9e/9e94bfdc-6790-464e-aade-a6dc588dd524.pdf
Posted on Dec 20, 2008
  • Lee2fixit Dec 20, 2008
    The plug is not a separate part, but a round piece of plastic that's designed to break away when you whack the screwdriver. Then turn the unit upside down to dump out the loose plug. Now you're ready to mount it under the sink and hook up the dishwasher drain.
Dishwasher DW60CEX1 has E4 sign come up but the hose is ok, but dishwasher wont drain or work at all?
Is this a new installation or have you been using the dishwasher?
If it is a new installation have you connected the hose to a garbage disposer fitting? Garbage disposes have a fitting to attach a dishwasher to them but you must first remove the knockout plug with a screw driver and hammer to allow water to drain into disposer unit. Failure to do this will cause the dishwasher to back up with water. Also check the float in the dishwasher to make sure it is not stuck.
Here is a link to the manual if you need it. https://www.google.com/url?sa=t&source=web&rct=j&ei=4oeoVIq2LMOdNuGThLgH&url=https://www.fisherpaykel.com/vault/pdfs/pdf_usecares/590113C_DW60CE%26CC_userguide_NZAUGBIEw.pdf&ved=0CC0QFjAF&usg=AFQjCNHZ00NKBFt19n9v21e105rsK8c8qw&sig2=m-FJir2-XSiYUCCh6qOpnw
Hope this helps.
Bob
Jan 03, 2015 | Dishwashers
Whirpool built-in puddle of water in bottom, food on drain
see this causes and proceed according. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher.
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Oct 16, 2012 | Whirlpool Dishwashers
I bought dishwasher kenmore13443 water will not drain out of dishwasher
Hello. Don't know all the details and this may seem like a simple solution but if this was a new installation and you have it connected to a garbage disposal, check to make sure the knock out plug on the disposal is removed. It will be where the discharge hose connects to the disposal.
Apr 05, 2011 | Kenmore Dishwashers
We bought a new dishwasher because the old one wasn't draining all the way. Same problem with the new one?
The pump is a motor which runs in one direction to spray water in the dishwasher to clean and the opposite direction to drain the water. The problem could be from a clog or kink in the drain hose. Several years ago the drain line would connect to the sink garbage disposal. If the garbage disposal is not draining or the dishwasher connection to the garbage disposal is restricted or clogged the dishwasher will not drain. Under the sink, look at the garbage disposal to see if a rubber hose is connected at the side of the disposal unit. If a hose is connected to the side of the disposal, remove the hose clamp and check for any restrictions from garbage in the inlet or hose. You can use a screwdriver to clean the fitting to the garbage disposal and a wire hanger to free any restrictions in the hose. If the dishwasher does not connect to the garbage disposal it should connect to the sink trap. This is more common with new dishwashers because they have built-in disposals. Disconnect the drain hose from the sink trap and the dishwasher and look for a clog at the sink connection. The dishwasher inlet should have an angled piece of plastic or metal facing downward to prevent the waste from the dishwasher from spraying up into the sink. Do not get to aggressive with the cleaning in order to prevent breaking the angled piece of plastic or metal. Look for any kinks in the hose and try to run water through the hose, but do not use the sink which you removed the drain line from or it could leak under the cabinet. If you see a bad kink replace the hose with a new one. I hope this works and you find the problem without a great deal of time or trouble.
Nov 22, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
I installed a new food grinder under the sink. I also replaced the dried out rubber hoses that connect the food grinder to the dishwasher. But no matter what program I use, the dishwasher refuses to drain...
Check to make sure you removed the plug inside the garbage disposal inlet where the dishwasher drain hose connects. This is a common mistake installers make when installing a new garbage disposal. Make sure the power the the disposal is secured and remove the drain hose. Place your finger inside the inlet on the side of the disposal. The opening should be clear. If not, you simply need to insert a flat blade scewdriver through the inlet connection and tap out the plug with a hammer. The plug will pop out inside the disposal, so you will need to reach inside and retrieve it before attempting to use it. Once the plug is removed, reinstall the drain line and test operate your dishwasher by starting a cycle. Once the dishwasher fills and begins the wash cycle, press the STOP/CANCEL button to initiate a drain cycle. Your dishwasher should drain with no problems. If you have any questions, please post back and let me know. I hope this helps you.
Nov 19, 2010 | Whirlpool Dishwashers
Remodeled kithen; when dishwasher reinstalled, water backs up
OK, I have made this error before.
When you install a new garbage disposal, it comes with a "plug" that fills the hole of the little pipe that the dishwasher drain hose connects to (if there is a dishwasher.)
Remove that plug (see instructions for the disposal) and you should be all set.
Also, if you ever get the chance, consider installing a dishwasher AirGap valve between your dishwasher and garbage disposal. They are almost free at any hardware store.
Good Luck! Please report back with what you find.
Apr 06, 2009 | Dishwashers
GE Dishwasher 2200 series - water comes out airgap
take the air gap apart and clean it out. also clean hose from air gap to garbage disposal.. if the garbage disposal is new take it down and remove the plug where the drain hose from the air gap connects to it..
Feb 13, 2009 | GE 24 in. GSD2230Z Built-in Dishwasher
Dishwasher/garbage disposal problem
You probably forgot to knock out the plug in the disposer for the dishwasher.
Aug 25, 2008 | Dishwashers
Dish washer
The drain in to the garbage diposal is clogged.  Remove the drain hose from the dishwasher and clean the hose.  Also check the inlet to the garbage disposer and clena it.
Oct 28, 2007 | Dishwashers
Installation
It sounds like you have connected your dishwasher to a garbage disposal.
  1. The 2 hoses provided with your dishwasher connect together.
  2. You run the drain hose through a hole in the bottom/back of your cabinet, then up to the top of the cabinet, then connect it to the drain on the garbage disposal. (The reason that you run your drain up to the top of the cabinet is: This is called an air gap, and helps keep a little water in the drain line, which will prevent sewer gases from entering your dishwasher.)
  3. Be sure to knock the plug out of the drain of the garbage disposal. A garbage disposal is designed to work with or without a dishwasher. The plug is in the center of the drain. The best way to knock this plug out is to pull the garbage disposal, and with a flat screwdriver, knock the plug out.
  4. Then remove the plug from the disposal. Reinstall the disposal.
  5. Install the drain hose. The drain hose will connect right up to the disposal using the clamp provided with the dishwasher.
This should help you. If not please attach more info.
Please rate this solution
Sep 09, 2007 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
433 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Craig Butler
Craig Butler
Mike
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
