Question about Bosch Washing Machines
Water leaking from the pump area
How do we get into the filter to clean it. We've unscrewed the cap on the front right hand side but we can't get any further into it.
  • 1 more comment
  • Chris Ware May 11, 2010
    brand? model? pump leaking?
  • ellieyarr
    ellieyarr Dec 21, 2012
    I have the same problem. I can turn the cap but can't remove. I have been able to do this in the past.
  • tracey110
    tracey110 Jan 06, 2013
    My front knob had come of the filter how can I now get the filter out?
    Problem Solver:
  • 12 Answers
You have to completely remove the filter. twist and shake it until you remove it fully. when removed clean filter thoroughly, also use a long nosed pliers to remove any coins etc from filter aperature. clean the filter regularly
Posted on Dec 20, 2008
Where is the pump filter on an lg washer?
The PRIMARY filter for discharged water in most front loaders is located under the opening of the washer behind a small 'door'. There is usually a small tube which you will need to pull the plug from and drain about 2 cups of water into a bucket BEFORE you remove the filter to clean it.
After you unscrew the filter which is mounted from front-to-back and clean it out, replace both filter piece and plug and replace the small drain tube.
Close the access door and operate your machine.
* Clean this filter every month or especially after washing heavy lint-producing materials.
Jul 21, 2014 | LG WM-2277HW Front Load Washer
WFW9400SW01
Determine first if you hear any noise when it is trying to drain. If you do, the drain pump is getting power. Unplug the washer and remove the access panel below the door. There are screws across the bottom. With the panel removed, you will see the drain pump sitting on the floor on the right side. There is a cap on the front of the pump that can be unscrewed. Be careful as there could be a sunstantial amount of water that drains onto the floor. Have plenty of bath towels ready. Sometimes by tipping the washer back against the wall will cause the water to flow to the back of the tub minimizing the amount of water that will leak onto the floor. Now unscrew the cap and remove it. Look for any debris in the trap and around the impeller area of the pump. After cleaning it, reassemble everything but the front panel and try draining it again. If it works you are all set. If not, you may need to replace the pump as it could have burnt out
Feb 07, 2014 | Washing Machines
My Maytag Ensignia washer is leaking water from the pump area of the washer. I've eliminated the drain hose and I've traced the leak up to the area of the plastic casing around what looks to be the...
Look for broken plastic casing of the pump. A hairline crack would also leak water. Check for proper fitting of flexible hoses to & from pump. Another thing is to check for loose filter cap. A loose filter cap or broken O ring of the filter cap can leak water.
Sep 18, 2011 | Washing Machines
Kenmore Elite HE3 - Washer stopped - door locked - did not drain and spin - Getting error message F02
  1. Unplug the washer.
  2. Remove the 3 Torx head screws (located left, center, and right) from the front bottom kick panel of the washer.
  3. The drain/filter/pump is right in front.
  4. You can see a diagram of the pump at http://www.repairclinic.com/PartDetail/Drain-Pump/1200164.
  5. First remove as much water from the washer as you can. Place a large towel under the pump - a lot of water will come out when you remove the filter cover cap.
  6. Remove the drain filter cover cap by turning the filter cover cap counterclockwise.
  7. Remove the filter and check the housing and pump impeller vanes for debris (see if you can move the pumps impeller by hand).
  8. Clean the cover cap gasket and the gaskets mating surface.
  9. Replace the filter and close the cover cap firmly.
  10. Run a short wash cycle and check for any leaks at the filter cover cap. If the error comes back, you may need to replace your drain pump.
  11. Replace the kick panel if none are found.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Feb 27, 2011 | Kenmore Washing Machines
Lint will not come off clothes when washed in my older whirlpool front load washer
Clean the pump filter screen.... Remove bottom front panel see filter housing located next to pump unscrew cap by turning counter clockwise... Clean/remove debris located inside(place shallow pan under housing and remove cap slowly so you can reinstall if pan get full)... Be prepared for some water to leak out when cap is removed(could be up to several gallons depending on how clogged up it is) .
Nov 03, 2010 | Whirlpool Washing Machines
Spin cycle does not seem to be working properly, clothes very wet after cycle
Welcome to FixYa.
Based on what you`ve described, it sounds like perhaps there is an obstruction or partial obstruction in the pump.
I would first check the pump for obstructions. This is the number one contributor to these machines not spinning properly.
**Unplug the washer or turn off your breaker before servicing the washer...safety first**
To check and clean the pump on your washer, If you direct your attention to the bottom right side of your Bosch you'll see a small round cover like so...
With the aid of a small screw driver, knitting needle, or anything small enough to fit in the small hole in this cover...
It will push in a tab, it doesn't take much force.
Rotate the hole (clockwise) to 6'oclock and it should come free, the edges are extremely sharp so be careful.
Once the door is out of the way you'll be greeted by a 3-4" plastic cap with wings so you can unscrew it by hand. ( you should also see a green or red ring attached to a metal clip on the pump, if you pull this the door should unlatch, but getting the water out first if present, is usually a good plan )
There is a small collector lip at the bottom of the cap, that is where you can hold the wet/dry vac to catch the water. Unscrew slowly so you don't get flooded, until it is unscrewed all the way out. There is potential for a lot of water...even if the washer looks empty.
Now pull out the trap/filter and visually inspect the inside of the pump as well as the filter/trap.
That is how you gain access to and clear the filter on your Bosch washer.
Re-install the filter and run a test with some towels or something to check it`s performance and to insure the filter is tight with no leaks before putting the cover back in place.
If this was the problem, awesome. If not let me know and I`ll try and help further.
Hope you found this helpful. If so please take a moment to write a short testimony and leave a rating.
Thank you for choosing FixYa, good luck.
Regards,
Macmarkus :)
Sep 19, 2010 | Bosch Nexxt 700 Series WFMC6401UC Front...
SAYS EMPTY/CLEAN PUMP
if you remove the bottom panel on the front, there should be 2 screws at the bottom of it, you will see the pump housing. On the front of that housing is a knob. Unscrew it and clean out anything that is in the filter area. *water will come out when you unscrew cap. have a bucket or a few towels ready*
Apr 23, 2010 | Whirlpool LHW0050PQ Front Load Washer
Water is leaking from the bottom and does not discharge from drain hose
Part of the problem is that your filter is clogged. Remove the front bottom panel by unscrewing 3 small screws at the base. At the lower right, there is a filter cap that you need to unscrew by hand. Be sure to put a small pail before you unscrew it because a lot of water will come out. Then clean the filter and screw it back in.
In terms of the leaking, that started with my washer just recently. It's not the filter....think it's the rubber seal in the front. If you pull back the rubber, there are small drainage holes that can get clogged. Cleaning helps, but doesn't solve it.
Feb 25, 2010 | GE WSXH208A Front Load Washer
F04 error message on a bosch exxcel 1400 washing machine, then the water wont drain away
This error indicates an obstruction in the water pump. . Tip machine back so you can fit a bowl under the bottom right hand side. Flip back cover at bottom right to reveal pump filter access - unscrew (quite a bit of water comes out so have the bowl ready).
Sep 26, 2009 | Washing Machines
GE Front Load Washer
Removing the lower front panel (3 screws nearest floor), and opening the round, white water pump filter cap (be ready to catch about 2 gallons of water!) is the best place to start. All you need is a Phillips head screwdriver and a large, flat pan (deep turkey tray works well)!
YOU WILL NOT BELIEVE what I found in my filter housing this morning (see photo below)!
The washer is working fine now, although I may go back and remove the entire water pump so it can be dismantled, thoroughly cleaned, and reinstalled.
Mar 16, 2008 | GE WSXH208A Front Load Washer
Washing Machines Logo
603 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
Craig Butler
Craig Butler
Carmen Mikulic
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
