Question about Sharp Aquos LC-13E1U 13 in. EDTV LCD Television
Does the Sharp Aquous LC-13E1U receive digital or analog broadcas
I have the Sharp Aquous and when a local television station did an on the air test to see if your TV needed a digital converter box this television did not pass the test. I thought it received digital signals and now I'm confused. Do I need another box on the last TV in the house that doesn't have a box of some sort when the digital transition occurs?
  • 1 more comment
  • jbeck134 Dec 20, 2008
    The manual indiactes that the tuning system is PLL which i thiought was digital. this is the one tv in the house that isn't connected to the satellite dish. its connected to the coax that was from our old cable company. i thought they just didn't disconnect the signal.
  • jbeck134 Dec 22, 2008
    I sense a bit of hostility. Look I am new here so i don't understand the etiquette. I appreciated your attempt but you only stated the obvious.
    Yes, I agree it looks like the TV is not HDTV capable, however, I never questioned anything with regard to HD. I would also say that the TV doesn't appear to have a digital tuner which is more to the point of the original question. In either case you simply stated the obvious. I was looking for a more difinitive answer than "looks like". It a bit hard to hang ones hat on that type of answer.
    In the future I would suggest you answer something in a more definitive refrain and if you don't know definitively, perhaps you shouldn't answer.
    I promise next time if I ever decide to ask a question again (not very likely given the perceived hostility) I will not respond to the rating of an answer. Is that what you would like? Seems so.
  • Prego1 May 11, 2010
    What was the part you did not understand about your TV if that one has a digital tuner or not?
    I've answer your question and you are rating it as thanks for trying???
  • 2,326 Answers
It looks like your TV is not HDTV capable, so you will need a box when the conversion takes place next year unless you have cable box or satellite TV receiver.
Posted on Dec 20, 2008
I have a sharp LC-37G4U and can not get it to load over air channels. this a digital tv but the only way they would load is with a converter. how can I download over the air channels on the tv
Unfortunately, the Sharp Aquos LC-37G4U TV is an HDTV-ready monitor. It does not have an ATSC (digital OTA) tuner. The A/V Center box (TU-GA1U-S) that came with the TV has two NTSC tuners. You'll need the over-the-air ATSC to NTSC (analog) converter box or a stand-alone ATSC tuner DVR set-top box to get most OTA channels. There are only low power NTSC tuners that continue to broadcast; you will only receive those stations if you are close to their transmitters.
Crutchfield has a nice list of the specifications for the TV here: . The manual has the full specifications for the TV on page 100. Crutchfield has the manual here: .
I wish that I had better news for you.
Oct 21, 2016 | Sharp Televison & Video
Sharp Aquos LC-52D92U static on display
if your seeing static on a digital tv , your problem is "Not" in the tv its in the signal source (cable box, sat scram,Etc)
digital tvs cant produce "static" displays because they don't receive wide spectrum signals like analog TV's did (carol-ann knows this!) there "filters" are very narrow and specific , this is also why there range is dramatically smaller than analog tvs
also everyone by now knows that tv stations can no longer transmit in analog format (in Usa), G4 cell phones got there band space
Jun 29, 2015 | Sharp Televison & Video
Have lost satellite coverage due to money restraints, How to connect antenna to tv.
Please provide the following information.
1. what country are you in
2. does your country have digital or analog air television stations.
if your country does not have analog television you may not have options for a clear signal, you need an antena outside the house if you do not have a clear line of sight to the tv transmitter for analog television.
Also it may be a good idea to do a channel search from within the television menue.
Oct 05, 2014 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
How do I attach an antennna?
On the back of the TV look for the connector marked Ant/cable. This is a silver connection with threads on it. If you have a digital indoor antenna, connect it there. Same goes if you have an outdoor antenna. Now go to the setup screen and select AIR for antenna type. After that do a channel search and select digital and analog channels. Let the TV find all the stations it can. When it's done searching, it will show a picture. You may need to aim the antenna to get a better picture .
Sep 05, 2013 | Sharp Aquos LC-13E1U 13 in. EDTV LCD...
How do I connect an analog antenna to a 32 inch sharp aquos tv? and do I need a specific input setting?
antennas are not analog or digital, just VHF, UHF and they typically connect to a RF coaxial jack on the TVs rear panel. 75ohm silver round jack. Select in your TVs menus, AIR when you want over-the-air TV stations and do a new channel scan to pick up local channels.
May 06, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Analog to digital convertion
Yes,LCD tv have digital tuner inside.Just buy a digital antena.Plug it in the antena analog whole.Go to menu setup go down to ch.rescan should have all free air channels.
Jan 16, 2010 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Sharp Aquos LC 32G4U not receiving any channels-
Most locations are real hard to get local stations using indoor antennas. If you are in a location where you do not have cable, I would try either a outside antenna on the roof or go with Direct TV Dish / Dish Network system.
I hope this helps,
Jan 04, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
TV somehow switched to analog even though it is a new digital TV. How do I switch it back on the remote?
It most likely has the capability to tune analog stations in as well. To get to a digital station you should just have to punch the numbers in on the remote IE: 5-1 or 5.1
Oct 17, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Sharp Aquous Remote Codes
You can download the manual for the TV. It has all the code for the remote on page 90.
Here's the link:
LC-37G4U | LC-32G4U & AVC System Operation Manual (3900K)
Mar 31, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Sharp Aquos LC-13E1U 13 in. EDTV LCD Television Logo
452 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
