Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
Dishwaher connection plug
How do I get the plug out of my disposal so that I can connect the dishwasher hose
  • alan1414 Jan 12, 2009
    I took out the plug while conected and now I have a noicy disposal, I had allready installed and did not know about the plug until my dishwasher would not drain....
    how do I get the piece of plastic out?
  • 334 Answers
From the dishwasher hose end of the nipple, insert a large flathead screwdriver or nutdriver and tap it with a hammer. They sometimes take a moderatly strong hit. It is litterally nothing but a plastic plug.
You will want to do this with the disposal uninstalled and the power disconected.
(doing it installed can potentially cause leaks.)
Make sure that you remove the little plastic plug that was knocked out from the inside of the disposal.
Posted on Dec 20, 2008
We bought a new dishwasher because the old one wasn't draining all the way. Same problem with the new one?
The pump is a motor which runs in one direction to spray water in the dishwasher to clean and the opposite direction to drain the water. The problem could be from a clog or kink in the drain hose. Several years ago the drain line would connect to the sink garbage disposal. If the garbage disposal is not draining or the dishwasher connection to the garbage disposal is restricted or clogged the dishwasher will not drain. Under the sink, look at the garbage disposal to see if a rubber hose is connected at the side of the disposal unit. If a hose is connected to the side of the disposal, remove the hose clamp and check for any restrictions from garbage in the inlet or hose. You can use a screwdriver to clean the fitting to the garbage disposal and a wire hanger to free any restrictions in the hose. If the dishwasher does not connect to the garbage disposal it should connect to the sink trap. This is more common with new dishwashers because they have built-in disposals. Disconnect the drain hose from the sink trap and the dishwasher and look for a clog at the sink connection. The dishwasher inlet should have an angled piece of plastic or metal facing downward to prevent the waste from the dishwasher from spraying up into the sink. Do not get to aggressive with the cleaning in order to prevent breaking the angled piece of plastic or metal. Look for any kinks in the hose and try to run water through the hose, but do not use the sink which you removed the drain line from or it could leak under the cabinet. If you see a bad kink replace the hose with a new one. I hope this works and you find the problem without a great deal of time or trouble.
Nov 22, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
What can I use to plug the dishwasher drain connection I no longer need?
Push a cork into the hole.
Garbage disposal doesn't have a lot of pressure pushing water out dishwaher tube until full sink of water is drained.
You might put gorilla glue or caulk on the cork to keep it in place.
Nov 19, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Water in the bottom and not working
Check for a clogged drain (e.g.: via drain hose), or a water pump malfunction due to foreign obstruction (e.g.: glass, etc).
Note: If you changed a food waste disposer (kitchen sink area) and did not remove "plug" from disposer for dishwasher drain hose (assuming dishwasher drain hose connected to food waste disposer), then water cannot drain from dishwasher.
Apr 14, 2010 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Water will dot drain, washer overflows and leaks. new drain hose and new garbage disposal was installed.
Did you knock out the plug where the dishwasher drain hose connects to the disposal. If you did not that is the problem. Plumbers will even forget the plug every once in a while. In side the spot that the hose connects to the disposal there is a plug. Knock it out and make sure you do not leave it inside the disposal or it will jam it. Hope this helps. Rick
Mar 07, 2010 | Dishwashers
My water is not draining from my dishwasher. it has 2 inches of water in the bottom after my wash cycle. it is even throughout the bottom, so my dishwasher is balanced. This is a brand new washer.
If the drain line is connected to a disposer, check to make sure the plug has been removed from the disposer. (typically, the plastic plug inside the tube where the drain hose connects onto disposer needs to be knocked out) If this OK, look for a kinked drain hose.
Sep 01, 2008 | KitchenAid Dishwashers
Water will not drain
check for dirty filter it's inside under drying element
Jul 06, 2008 | Kenmore 24 in. 15252 / 15254 / 15259...
Just connected a new garbage disposal up, and dishwasher won't drain anymore
The disposal has a knock out plug at the point where you connect the dishwasher hose. This is case someone doesnt have a dishwasher. It can be knocked out pretty easily with a hammer and screwdriver. Make sure that the power is disconnected because you will have to remove the plug by hand. Hope this helps!
-Walter
May 27, 2008 | Hotpoint 24 in. HDA2000Z Built-in...
How to knock out garbage disposal plug
Turn off the power source to the garbage disposal. Take the drain hose from the dishwasher off the connector going to the disposal (if connected). Insert a flat blade screwdriver in the drain hose fitting and tap a few times with a hammer. The plastic plug will pop off inside the garbage disposal. Reach inside from the top of the disposal to retrieve the plastic plug. Sometimes you have to use a little force to tap the plug out. Hope this helps you.
Apr 07, 2008 | Frigidaire 24 in. PLD2850 Built-in...
Installation
It sounds like you have connected your dishwasher to a garbage disposal.
  1. The 2 hoses provided with your dishwasher connect together.
  2. You run the drain hose through a hole in the bottom/back of your cabinet, then up to the top of the cabinet, then connect it to the drain on the garbage disposal. (The reason that you run your drain up to the top of the cabinet is: This is called an air gap, and helps keep a little water in the drain line, which will prevent sewer gases from entering your dishwasher.)
  3. Be sure to knock the plug out of the drain of the garbage disposal. A garbage disposal is designed to work with or without a dishwasher. The plug is in the center of the drain. The best way to knock this plug out is to pull the garbage disposal, and with a flat screwdriver, knock the plug out.
  4. Then remove the plug from the disposal. Reinstall the disposal.
  5. Install the drain hose. The drain hose will connect right up to the disposal using the clamp provided with the dishwasher.
This should help you. If not please attach more info.
Please rate this solution
Sep 09, 2007 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
320 people viewed this question
Top Ace Hardware Electrical Supplies Experts
Craig Butler
Craig Butler
Mike
Steve Allison
Steve Allison
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
