Question about RIM BlackBerry Curve 8310 Smartphone
Blackberry curve8310 I am having trouble with my blue tooth on this phone I can send any other phone ringtones and pictures through bluetooth but when someone else tries to send me a ringtone or a pictures it always says failed on their handset. What can i do to fix this problem
  • 2 more comments
  • gudnyxox Dec 25, 2008
    I'm having the same problem. I can send pictures but when others try to send me ringtones or pictures it doesn't work.
  • jwmusicman Dec 30, 2008
    I can send anything via Bluetooth but I cannot receive. The sending phone always says Failed.
  • Anonymous May 06, 2009
    Blackberrie curve 8310
    I can send stuff 2 someone but when someone wants 2 send me stuff then it keeps on telling me that it is failing!!
    HELP!!!!!!!!!!!!
  • Coco261 May 10, 2009
    I have the same problem with items being bluetoothed to me. Says "Failed to send" on the other phone.
Ok if you want to recieve anything via bluethooth you have to go into media and scroll over to the one you want to recieve and click options and it will say something like recieve.
Posted on Feb 28, 2009
Can i use my plantronics 230 bluetooth for my blackberry phone?
Hi, yes you can use plantronics 230 blue tooth for your blackberry phone.All you would need to do is to pair the device with your phone.that will do.
How to pair a phone to a blue tooth device?
Instructions
Pair Your Blackberry with a Blue-tooth Headset
Turn on Blue-tooth headset and Blackberry hand-held.
Enable the Blue-tooth radio by going to the options window and clicking on Blue-tooth. Click on Enable Blue-tooth in that window.
Add your Blue-tooth headset to your Blackberry by clicking on Add Device in the Blue-tooth window.
Find and select the name of your Blue-tooth headset from the list that appears. The Blackberry will search for all Blue-tooth devices within range, so other devices might show up on the list.
Click Activate Blue-tooth device if you receive a call and the Blue-tooth headset does not pick up automatically.
Use your Blue-tooth Headset with your Blackberry
Make sure the Blue-tooth radio on your Blackberry is turned on before you try to use your Blue-tooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the hand held.
Tips & Warnings
Pair your Blackberry with any Blue-tooth-enabled device using the same steps as those for connecting a Blue-tooth headset.
Remove your Blue-tooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Jan 06, 2011 | Plantronics Explorer 230 Bluetooth Headset
I just bought a used blackberry rim and im haveing problems getting it to allow me to bluetooth any pictures or ringtones..please help
For any 2nd hand BlackBerry, you have to format you device and configure newly ,.
for enable blue tooth,
Or follow the below instruction
Screen menu> manage connection> check mark on <blue tooth>
Save
sedngi via blue tooth ,
open any picture or ringtone and press the menu button > send using blue tooth”
receiving via blue tooth ,
Screen menu > media> press the menu button ,”Receiving using blue tooth”
Jul 17, 2010 | RIM BlackBerry 7290
Blackberry curve 8520 unable to receive files transfered from other Mobile device through bluetooth. But able to transfer data to other mobiles through blue tooth
My Blackberry curve 8520 can send data via bluetooth but it unable to receive data from another bluetooth enabled device. please send me solution.
Jun 17, 2010 | RIM Holster For BlackBerry Curve 8520
Blue tooth is on and partnered but will not send. It say's service unavailable. The sim card-blue tooth has worked in other phones.
Restart your smart phone and restart your bluetooth as well. Then reconnect with your device. This should solve the intermittent problem.
Regards
Apr 09, 2010 | RIM BlackBerry Bold 9000 Smartphone
I'm trying to transfer pictures from my sanyo 2700 to my mac comp by blue tooth and i cant figure it out.... any suggestions??
Best way I can ever suggest sending pics to a computer is simply just email them.
Bluetooth isn't the best way to do anything. It's unreliable, and a lot of phones block media transfer via bluetooth to prevent "piracy" of ringtones and stuff.
Sep 19, 2009 | Sanyo SCP-2700 Cell Phone
I can not receive incomming blue tooth on my blackberry 9500
To send and receive files between two BlackBerry smartphones using Bluetooth® wireless technology, complete the following steps:
  1. Enable Bluetooth technology on the BlackBerry smartphones. For instructions, see the Turn on Bluetooth technology section of the BlackBerry User Guide.
  2. Make the BlackBerry smartphones discoverable. For instructions, see the Make your BlackBerry device discoverable section of the BlackBerry User Guide.
  3. Pair the BlackBerry smartphones. For instructions, see the Pair with a Bluetooth enabled device section of the BlackBerry User Guide.
  4. Set the Trusted field to Yes on both BlackBerry smartphones by completing the following steps:
    1. In the Bluetooth application, highlight the BlackBerry smartphone and press the Menu button.
    2. Select Device Properties.
    3. Set the Trusted field to Yes.
    4. Press the Menu button and select Save.
  5. Send and receive the transfered file.
On the recipient's BlackBerry smartphone
  1. On the Home screen of the BlackBerry smartphone, select Media.
  2. Select a media type (Music, Video, Ring Tones, Pictures).
  3. Press the Menu button and select Receive using Bluetooth. The File Transfer dialog box appears, followed by a prompt to Save or Cancel the file.
  4. Select Save to save the file to the current location, or select the folder icon to save the file in a different location.
On the sender's BlackBerry smartphone
  2. Select the same media type selected on the recipient's BlackBerry smartphone.
  3. Press the Menu button and select Send Using Bluetooth.
  4. When prompted to select a BlackBerry smartphone, select the recipient's BlackBerry smartphone.
from :http://www.blackberry.com/btsc/search.do?cmd=displayKC&docType=kc&externalId=KB05409
chathudagr8@yahoo.com
Aug 27, 2009 | RIM BlackBerry Storm 9530 Smartphone
How can i download a free ringtones from the computer using a blue tooth. when my cellphone is panasonicX700
First, you should have a program on your computer that you are giong to use for downloading music. You may install LimeWire for PCs or FrostWire for Mac.
Those programs will allow you to search and download songs. You have to save the downloaded songs into a folder.
Now, in order for you to transfer those songs from the computer to the phone via Bluetooth, your computer should be Bluetooth enabled also.
1. Turn on the Bluetooth on your phone.
2. Pair up the phone with the computer via Bluetooth.
3. The computer will recognized the phone.
4. Select the song, right-click on it and then select Send
5. Select via Bluetooth and select your phone.
It should transfer after doing those steps.
Good luck and have a great day!
May 16, 2009 | Cell Phones
How do u bluetooth ringtones to an lg chocolate
you cant if if its version Version cant blue tooth ringtones its kind ******* stupid they can olny bluetooth other version phones....
Apr 15, 2009 | LG CHOCOLATE VX8500 Cellular Phone
Want to send picture from phone to computer
Can you not use bluetooth to send pictures from phone to computer. Search on your mobile phones menu to see if there is bluetooth and enable it. If your mobile is not bluetooth enabled, you may still be able to send pictures from phone to pc if there is a USB cable slot in the phone. To send to the pc via bluetooth, either your pc has been set up with bluetooth, or, if not, you have
to install bluetooth using a bluetooth dongle which comes with CDrom, and may be purchased from computer stores like Currys or online for £10-15. Let me know if you have bluetooth, and I'll help you more. Once there is Blue tooth it needs to be turned on, and discovery mode has to be enabled, (not disabled) in order to communicate with other nearby bluetooth enabled devices. Get back to me tell me what you found out, Good luck papertigers
Dec 13, 2008 | RIM BlackBerry Curve 8310 Smartphone
Bluetooth
Blue tooth software revisions keep occuring. The previous generation did not permit the transfer of MP3.... are your ring tone MP3's?
Also, make sure the the ring tone is not "copy protected"....
J.
Mar 07, 2008 | RIM BlackBerry 7290
RIM BlackBerry Curve 8310 Smartphone Logo
155 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
ismael castillo
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
