Question about Mad Catz PS3 Bluetooth® Headset Wireless Headset
Ps3 headset wont work
Hi there my ps3 headset wont work. all it says is scanning now . iv'e tried numerous times but still nothing. iv'e used the usb cord and also tried not using it but still nothing. pls help
  • 2 more comments
  • Anonymous Jan 24, 2009
    It scans for 20mins and then says it can't find anything
  • Anonymous Feb 22, 2009
    I just can't get the headset to work. Sony standard one. Does my ps3 need to be online when scanning for it?
  • Anonymous Mar 19, 2009
    Same HELP US i need it to work....!!!!1
  • brian glenn
    brian glenn Jan 06, 2014
    connect it automatically. (main Menu)-[settings]-[accessory settings]-[audio something]-[press up and it should connect}
My sony wireless headset wont register please help
Posted on Dec 13, 2009
Epson xp 200
Hi -- A couple of ideas.
My scanner never works if computer is in hibernate mode so make sure computer is fully on and not in any sort of standby mode.
If you upgraded your operating system since you first did it, try uninstalling the printer and the software and then reinstall the Epson software and printer in the order in your get started guide
For the USB problem, make sure it is the Epson USB cord and shut down your system and then turn it on with this cord attached.
if it is a MAC, do not use OS X Classic mode
If none of those work, it is time to call in the pros and call Epson
Jan 27, 2014 | Office Equipment & Supplies
Ps3 wireless stereo headset wont charge
hi Karan.
as its already been asked by Anthony Cardenas,it would have helped if you had of said what model.
but this is all i could find out.
Try another USB cable.
If that doesn't work then the headphones may be faulty. Do they have easily replaceable batteries?
It's worth finding out if the batteries can be changed
I had the same problem with mine, I'd not used them for a few weeks and they wouldn't
charge. At least thats what I though.
Try leaving them on charge on the PS3 for a few hours regardless of charging light.
Also try pluging them into a PC with the wireless dongle, you're PC should recognise them as speakers and mic, if that works at least you know the headset is fine.
like i said this is all i could find on the internet so not sure if its any help to you,if not sorry for taking up your time,and i hope someone does get to help you out with this.
or see if this link helps you out.
Ps3 wireless stereo headset wont charge Google Search
Nov 30, 2017 | Sony Radio Communications
I have a HP USB Digital Stereo Headset connected to my laptop.. and accidentally pulled the cable, after that my headset wont work. how can i fix it.. i tried opening the usb of the headset and looked if...
Hi, Try using another USB connection. Most laptops have 2 or more. If you can borrow somebody elses headset to rule out that the set is or is not working. If that is good, check that USB is still OK. By using another divice. Good luck.
Jun 07, 2011 | HEWLETT-PACKARD HP Digital Stereo Headset
Cant pair ps3 wireless headset
sometimes it is easier just to watch a video!
Here ya go. please remember to leave me a positive rating and a testimonial really helps!!
thank you!
1. CompatibilityThe PS3 supports only one headset at a time. Multiple players on the same console will have to share.
Bluetooth:
  • The PS3 uses Bluetooth version 2.0, and is compatible with all earlier versions (1.0, 1.1, 1.2). 2009 may see version 2.1 Bluetooth headsets hit the market, so you will have to try it for yourself on PS3.
  • All brands of Bluetooth headset should work with the PS3.
USB:
USB (wired) Headsets can also be used with the PS3.
  • Any of the PS2 compatible USB headsets should work with PS3 games.
  • USB headsets are required for PS2 software used on the PS3.
Not Compatible with Bluetooth Stereo Headphones:
  • The Bluetooth audio signal for PS3 only carries voice chat. The game sounds and music are played through your TV or stereo receiver only.
  • If you want to listen to the gameplay with headphones then they will have to be compatible with your TV or stereo receiver.
2. Setup
A Bluetooth headset has to be registered, or "paired", with your PS3 before it can be used.
  • Make sure your Bluetooth headset is fully charged before you begin.
  • Check your headset instructions for entering "pairing mode". Activate your headsets' "pairing mode" so it can be recognized by the PS3.
  • On the Cross Media Bar (or XMB) of the PS3 go to the "Settings" tab, then down into "Accessory Settings", then down into "Manage Bluetooth Devices".
  • With your headset in pairing mode, follow the onscreen instructions and let the PS3 scan for your headset. When your headset is found, follow the prompts and enter a pass key (if necessary- the default is usually 0000 for all brands). The pairing should now be complete.
If you're using a USB (wired) headset, just plug it into one of the ports on the front of the PS3 (the system should auto-detect the USB headset).
Mic Test and Volume Setting
After pairing a Bluetooth headset, or after plugging in a USB (wired) headset, return to the XMB. Go to "Accessory Settings" and choose "Audio Device Settings". You can test your headset here.
  • Your headset should appear as the audio input/output device. If not, just use the D-pad to highlight the Input line, then scroll until you see yours. Any microphone you have used with your PS3 will be listed, but only the current one will be available to select.
  • Set the "Microphone Level" to 3. You can change the level any time if needed.
  • Speak into the headset, and the level bar at the top of the screen should move at the sound of your voice.
You can also view a list of Bluetooth accessories you have registered in the "Manage Bluetooth Devices" tab under "Settings".
If your mic doesn't appear there then try pairing it again.
There are more ways to configure the audio input and output that can be useful:
  • Set the input to (your mic) and leave the output on (default)- one person can chat with the other players, and the replys will play over your TV speakers rather than into your mic. Great when sharing one console because everyone can hear the team talk.
  • Set the input and output to (default)- you will hear the game sound and voice chat through your TV speakers but won't be able to talk back. Great if you don't have a headset, or if you want the room to hear the team chat.
  • Set the output to (default) to use stereo headphones with your TV or receiver. Then set the input to (your mic) and you can chat while wearing stereo headphones. Keeping the mic close to your face could be a problem since both ears are already taken! You could try a USB desktop mic and see if that works.
3. Troubleshooting
General:
If you are having trouble with a headset after it is paired with the PS3, there are a few things to check first:
  • Make sure your headset battery is charged and working. Be aware that some brands/models will need to be paired again after each recharge. It's not a problem, it's just the way those models work.
  • Make sure your controller is charged. Lots of strange things happen when the controllers don't have enough power, like dropouts and headset interference.
  • The headset should be set as the input/output device from the XMB.
  • For Bluetooth users, make sure there are no other Bluetooth devices in use near your PS3. Also try to eliminate any other radio frequency interference if possible.
  • For USB users, make sure the connection is secure and there are no wire breaks.
  • Update your console to the current available firmware.
Pairing Problems:
  • If the PS3 cannot locate your headset, make sure that your headset is in pairing mode before you start scanning. The headset instructions will tell you how to set yours to pairing mode.
  • If your headset is missing from the device menu after you re-start your PS3, you will have to pair again. Many headsets will only "remember" one device at a time, so you may have to register again after using your headset with a phone.
  • If your headset appears on the Audio Device menu but is "grayed out" or not selectable, it is not connected. Make sure the headset is charged, and that it is on in standby. I should connect automatically when the Audio Device menu is selected. Tap the call button on the headset if it does not connect, or click on the Connect Bluetooth tab on screen.
  • Make sure no other Bluetooth devices are in use nearby.
Voice Chat Drops:
  • Most in-game voice chat drops are simply network lag. Usually they go away after a short time, so be patient. In extreme cases you may have to leave a game and return to reset the chat function.
  • If you use wireless internet, a low signal strength to your modem/router can make voice chat malfunction. Make sure your wireless signal is as strong as possible to your access point.
  • Sometimes a headset will quit after changing discs to another game. Go to accessories and select your headset again.
4. Playstation 3 Links and Customer Support:
Apr 08, 2010 | Sony Playstation 3 (PS3) Console
How can i attach a bluetooth to ps3 plz help
Hello my friend this should help you out.
please remember to leave a positive rating for me and a testimonial if I helped you out!
Bluetooth:
USB:
2. Setup
and here's a video in case you are a visual learner.
Mar 26, 2010 | Sony Video Game Consoles & Games
Orb ps3 bluetooth head set will not scan to ps3
try holding the power button in till it blinks then try to connect the headset on the ps3 settings menu
Oct 15, 2009 | Video Game Consoles & Games
Plantronics BT headset can't connect to PS3 slim
Hi, first you have to enable the Bluetooth to scanning mode,
To do this, press and hold the power button continously for 10 seconds, you may have a stable LED, this shows that its in discoverable mode, Now perform scanning and you may get your device and you can pair and make it work
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Sep 18, 2009 | Ubi Soft Entertainment Tom Clancy''s...
Computer wont recognize me Saitek GH20 Headset
I have the same problem. I suspect that this headset is not USB compatible at all. It possibly only uses the USB connection as a source of power (for the vibration effect). This is a problem for me because I wanted to use the headset on a PS3. Saitek don't claim that it works with the PS3, but the claim of USB compatibility is ambiguous and misleading in my opinion.
Feb 20, 2009 | Saitek GH50 Headset
Pairing my headset to the PS3
Ok people, here is how it is done- Turn off your bluetooth. When it is off, press and hold the main button (power button) until it flashes(keep holding even after it flashes). The light on the device should turn solid blue (instead of flashing) now you can let go of the power button. My device was picked up immediately... after 2 hours of trying to figure it out of course, lol. Hope it works for y'all!
~Live long and prosper ;)
Jan 06, 2009 | Radio Communications
Connecting bluetooth headset to ps3
You have to do 2 things in order to use a bluetooth headset on your ps3. First you have to pair it with the ps3. To do this you go to your setting and register the bluetooth device. Make sure your bluetooth device is in pairing mode when you do this. On most headsets you can simply hold down the button until the light comes on a solid color. once it is in pairing mode you will have to scan for new devices. Once this is done you should see the headset on the list. Choose it and enter your pairing code. If you have not set one it will most likely be 0000. Once it is it paired you will have to change your audio output and input. Go to audio device settings and change the input and output device to your headset name. Enjoy!
Sep 25, 2007 | Video Game Consoles & Games
Mad Catz PS3 Bluetooth® Headset Wireless Headset Logo
995 people viewed this question
Top Mad Catz Radio Communications Experts
eradiostore
eradiostore
Marvin
Marvin
Are you a Mad Catz Radio Communication Expert? Answer questions, earn points and help others
