Question about RCA RT2600 System
I've found an RCA RT-2600 HT for $10. Receiver showed "overload", now won't power. It's also missing a rear speaker. Is the receiver fixable? If not, what receivers are compatible w/the subwoofer? Also, what speakers would be a good replacement? I want to spend next to nothing (~$50) on this. I should be able to solder in new components in receiver.
  • 5 more comments
  • raunch Dec 20, 2008
    It's a powered sub.
    Just RT2600. No DVD.
    Other posts have said when you get an overload on this it's fried.
    Any chance it's fixable?
  • raunch Dec 21, 2008
    Might I be able to fix it myself if you can tell me the most obvious parts to replace? I'm paying $10 for the speakers. This was free. I'm willing to put $30 or so into it.
    Also, is there a way to run the powered sub with a non-sub receiver?
  • dadamczy Jan 05, 2009
    My system will not power up. It was working fine until the other night when we tryed to watch a DVD. After 10 min. the sound went out and the system shut off. Tryed to start and nothing. When I push the power botton the diplay flashes. I couldn't make the word out until I got real chose to the unit. I believe it says "overload". I hope it's not fried!!!!
  • 69 Answers
There may be a fuse inside the cover. I replaced the 2 front and 2 rears with pioneer S-HF21-lR 2 way,100 watters. they are bookshelf size speakers, but trust me they rock. you wont be disappointed. im pwering them with a sony receiver. no problem. if its a typical rca sub, its non powered and will work with about any receiver. Steve
Posted on Dec 20, 2008
  • 3 more comments
  • Stephen Evans Dec 20, 2008
    is this a RCA model rtd 260 with 5 disc changer and sirruis capable
    if you can give me a day or two. im still researching it. Steve
    sounds about right, thats what rca replied to me.
    It would cost more to fix it than you paid for it. It has been discontinued by Rca
  • Stephen Evans Dec 21, 2008
    I really cant get any info on the unit, being dicontinued. Does it have a circuit board? if so remove it and see if their are anysigns of burns on it, some of the components you may be able to get at radio shack. Also there should be a step down transformer, so to speak. see if you can see if it has power coming out of it. About the speaker, if it has no sub output, you wont get the sound field designed to go to a subwoofer.
Intermittent speaker performance - receiver issue - not a speaker issue
Matt,
Have you checked/cleaned the leads on each speaker as one bad lead or speaker can pull/push extra power from/to other speakers causing shorts, this is likely not the case but could be the easy fix. Try cutting one speaker out at a time rotating which one is disconnected to see if this fixes the issue and possibly points out either a bad speaker or connection.
Dec 04, 2013 | RCA Onkyo Ht-r510 Receiver 6.1 Channel...
"Protect" flashes on the receiver. Fixable? Weather related?
The receiver will go into protection mode when there is a short in the speaker wires or the amplifier was overloaded. verify that none of the speaker wire connections are loose at the back of the receiver or at each speaker. And verify that none of the wires are making contact with each other.
if it is, then remove the speaker wires and connect them again properly. After disconnection g the speaker wires, unplug the receiver for 10 to 15 minutes. This will make the overload protection back to normal
Try this and let me know. I hope this would solve the issue
Thanks
Nov 10, 2011 | Audio Players & Recorders
I can not figure out how to adjust the balance on my speakers. It seems that one speaker in louder than the other. I cant find my manual and i've been tinkering with the receiver with no avail.
Tinkering won't work. HT510??? Not HTR510? Maybe that's what you meant.
All AVR's have settings for individual speaker channel levels and distances from the listening position.
http://filedepot.onkyousa.com/Files/own_manuals/HT-R510.pdf
Jul 11, 2011 | Onkyo HT510 Receiver
I have an onkyo HT-R560 receiver that won't turn on. the standby light light up and when you hit the power button you can hear a click-like sound but nothing happens. what should i do to fix my...
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the
speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
May 07, 2011 | Onkyo HTR500 Receiver
After many years of great service, ht\\the display now shows "overload" after about 5-10 seconds of playing. Sound is interrupted. Any help would be appreciated.
if the unit detects a speaker or speaker wire short it will go into protect..will it stay on with no speakers attached? if so theirs a good chance the unit is ok and 1 or speakers or their wires is at fault
Aug 30, 2010 | Pioneer VSX-305 Receiver
My reciever plays then cuts out
They don't overload from missing speakers. I'm curious, what buggered the one speaker?
Examine all of your speaker wires carefully to be sure no unintended contact is made between them and anything else.
Is "overload" being displayed?
“OVERLOAD” starts flashing on the display.
Speakers are overloaded because of high volume.
1. Press STANDBY/ON on the front panel to turn off the receiver.
2. Stop the playback source.
3. Turn on the receiver again, and adjust the volume.
Speakers are overloaded because of short circuit of speaker terminals.
Press STANDBY/ON on the front panel, then check the speaker wiring.
If “OVERLOAD” does not disappear after turning on the receiver again, unplug the AC power cord, then plug it back in again.
If speaker wiring is not short-circuited, contact your dealer.
Mar 31, 2010 | JVC RX-6042 Receiver
Receiver shuts off at higher volumes
The receiver may be too under powered for your speakers or the speaker ohm's may not be matched for your amp.
The reason it is shutting off is likely because the amp is becoming overloaded. At lower volumes the amp can handle the load of the speakers, but at higher volumes the power supply of the amp can't keep up with the power demand the speakers are pulling.
If you were previously able to turn the reciever high without turning off, then there is likley something wrong with the amp or possibly a blown speaker.
Try measuring the resistance of the speakers if you have access to a multimeter. They should normally read 8 ohms for home speakers, but some common home speaker impedances in order from (I'm assuming) most common to least common are are 8, 4, 2(bose), and sometimes 10 or 12 ohms. The lower the number of ohms, the more power the amp will need to put to the speakers and the more chance you could be overloading your amp.
Mar 30, 2010 | Audio Players & Recorders
Receiver Overload error message
Disconnect all speaker wires at the receiver, then turn it on and up. If it stays on, check your speaker wires one by one, then check your speakers one by one. If it still cuts out with nothing attatched, it needs serviced or replaced.
Aug 30, 2009 | RCA RT2660R Receiver
Have an overload on a Dolby Digital Audio video reciever RCA model: RT2360/RT2360BK
please check your speaker cables for internal short circuit or cable touched each other in receiver rear side=take all speaker cables out and check if overload goen you have cables problem-connect speaker one by one until you find the bad one-try to change its cable first and then speaker itself.----if over load remain you have a problem in your receiver itself.
Jul 15, 2008 | Audio Players & Recorders
Hooking up the RT 2600
connect all the devices into the receiver inputs then there should be 1 set of outputs to the tv. This is to play everything using surround sound as all the video and audio is going through your recevier... if you want to do HD and have surround sound you will need a new receiver as this one has no hdmi inputs or outputs.
Feb 26, 2008 | RCA RT2350 System
RCA RT2600 System Logo
495 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
