Question about E-Machines T2642 PC Desktop
Old emachine T2642 will not boot...disk monitor LED stays on and CPU fan does not rotate...no boot access to CD-ROM, or disk drives...changed power supply...think it might be BIOS backup battery...
  • ronnyharris Dec 21, 2008
    OK thanks...sounded like dead mobo to me too...CPU fan doesn't rotate and no disc access so recovery discs of no use....can't seem to find CMOS battery...duh...
    ron
  • zabrina liang May 11, 2010
    Are you telling me you have no reinstall or emergency recovery disk??
    If the CPU fan is not rotating, it would more than likely have something to do with the the hardware and not the operating system.
    If you are not getting anything, it's probably its time to die. You can salvage any workable parts, but it is not the CMOS battery. That is only if the date settings is not working.
  • 62 Answers
It sounds like a dead motherboard. Try removing the CMOS(BIOS) battery and replacing it. Then try removing and replacing the CPU as well. If you get the same result then you might be looking at replacing the motherboard.
Regards
Posted on Dec 20, 2008
Is it possible to fix my desktopPC?
Not compatible. Make a flash drive/CD rom of your OS and start again.
Aug 07, 2016 | Acer Computers & Internet
E-MACHINE 6532 WON'T BOOT
Could do with more info here
1.) Does the machine power up (ie is the power lED lit and are there signs of activity such as the cPU fan running, hard drive actuating and lights to the DVD rom drive, if not, worth checking the pSU is giving out power, the easiest way of which is to substitute a new PSU.
2.) Can the computer access the Bios (F1 or Del or F2)? If it can, does it "see" the hard drive and DVD rom?
3.) Are there any beeps when it tries to start up? If not, the cPU is most likely dead
can you clarify any additional symptoms if (1) does not solve them
Dec 28, 2010 | E-Machines eMachines Desktop PC
The yellow power led light blinks on front of the emachine w2646. The CPU Fan works. The power button will not turn the PC on or off, you just have to plug in the power cord to turn it on. The monitor just...
Did you flash the main board ??
1.) remove battery
2.) press and hold the power button for 10 - 30 seconds
3.) replace battery.
4.) when the system boots it will say press XX (e.g F2) to load defaults and continue ,, press that key.
It could also be the power button is stuck!.
find were it connects to the main boad and unplug it
bridge the 2 pins it jacks into to turn the computer on. if it works u will need to replace that button or the case.
Feb 26, 2010 | E-Machines eMachines Desktop PC
What does the red light mean next to the power button?
The red light next to the power button is usuall the hard drive led which should blink every time the hard drive is in use, there is normally a green or yellow light for the power that shoukld stay on constant when the computer is on.
Feb 09, 2010 | Intel Compaq EVO D500 (RBMDTCPQP42400) PC...
CD drive button broken
You might try to remove front cover from you CDROm and checked whether button is not broken or stucked
Oct 07, 2009 | E-Machines emachines (emachinees) CD-ROM...
My pc was doing this but now it's doing something different but simular
Try telling it to boot the CD instead of the disk for now, since you need to install from that...or perhaps a newer OS.
Jun 23, 2008 | E-Machines eMachines T3830 PC Desktop
Boot up problem
plz check the first boot device is hard disk in your bios setup if it is not then make it, then put your findings here
May 27, 2008 | Samsung (SC-152) Internal 52x CD-ROM Drive
Upgrade to a new motherboard?
I think there may be another issue.. It could be the power supply.. Have you tried a new one?
Have you installed any additional ram lately?
You can use the old XP software with a new motherboard, but it can be a pain in the **** to set-up if it is the OEM version of Windows, or a Recovery Disk that came with your machine..
What you could do, if you bought another motherboard, find someone with a Genuine Windows XP disk, and use your Product Key to install it..
Apr 12, 2008 | E-Machines eMachines Refurbished EMA...
Emachines 1900+ gets power to the monitor and computer but wont boot
There could be a number of causes. Do you hear any beeps when the computer starts up? Try seating all the chips in the motherboard. That means, apply pressure to each individual chip on the motherboard with your finger or thumb. The goal is to make sure each chip is securely attached to the board. Sometimes, heat or new h/w installs partially "pop" some of the chips out of the motherboard - causing the circuitry to be disconnected...
Aug 03, 2006 | E-Machines eMachines Refurbished EMA...
Buy a dianostics card, and find out if its the RAM, CPU, OR Motherboard. (sounds like a ram or CPU problem though) if you have more than one stick of ram in the system, take one out, and power it up, if still not response, to the other stick out, and put the stick you took out the first time, and put it back in.
E-Machines T2642 PC Desktop Logo
423 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
