Question about HP Pavilion 8860 (P2941A) PC Desktop
RAM I am trying to install a new chip of RAM into the PC but it is behind the Cd and hard drives. How do you take these out to get to the RAM port?
    Problem Solver:
  • 18 Answers
Depending on your pc, on some pc's the side panel will come off with your motherboard. You should then be able to get to your memory. on others the side panel will come off and then you can unscrew the cd, dvd (screws on both sides of pc)and push them out(forward, unplug the power line and ide connections).
Posted on Apr 01, 2007
Where is the sound card located in a dell dimension 1100?
The sound is integrated onto the motherboard in this model, it isn't a separate card.
Jan 01, 2011 | Dell Dimension 1100 PC Desktop
My macbook has a grey screen with a file and question mark
This means it can't find the operating system. Try taking RAM chips out and re-inserting firmly. Also, make sure you got the right kind of RAM chips in the two slots as Macs are picky. Also, make sure you got more RAM memory than you need so the Mac will run super fast. If none of these RAM tricks help, then re-install the operating system by doing an archive and install so you can retain your data. Alternatively, you can take the hard drive out and insert it into an external drive case, then install a new hard drive into the laptop, and do a clean install. Then you can extract the data from the old external hard drive.
Nov 06, 2010 | Apple MacBook Mac Notebook
It has freezd, it does not start
Remove and re-insert the RAM chips. Nothing? Replace the RAM chips with new higher memory RAM chips. Nothing? Replace the hard drive and re-install the OS. Nothing? Repair or replace the logic board.
Sep 15, 2010 | Apple MacBook Pro Laptop Computer with...
Windows xp instalation stpos givibg a blue screen in aspire m5640 desktop
Windows Xp installtion give Blue Screen of Death when XP tries to installed devices driver during installation or when the cd is corruptted and cannot be read in graphical mode installation or when the hard drive is corrupted with Bad sector.
Get a new windows XP CD and configure your system BIOS to default setting ( load optimal settings) and configured for IDE drive configuration to compatible mode or disable mode if you are using SATA hard drive.
If problem still occured, get "Bad sector recovery pro" and try to repair the hard disk.If the bad sector are unrecoverable then change the hard drive.
Sometimes, faulty RAM also give blue screen too. Check your RAM too.
Dec 19, 2009 | Acer Aspire m5640 PC Desktop
I get a 3sec beep everytime the pc tries to boot from the hd, the actual hard drive is fine, we know this as we have connected to another pc, any suggestions ?
Hello
The beep code you are getting has nothing to do with your HDD, it is actually a fault with the ram chip(s) in your computer.
If you have 2 or more ram chips installed, take out all the ram and install the one by one. Doing this you can find out which ram chip is faulty. If you only have one chip installed, take it out and test in in another computer before buying a new chip.
This is how the ram module looks like in general:06931a6.jpg
Hope this can help
Kind regards
Andrea
Nov 15, 2009 | Radio Communications
New ram not speedy
well, the lowest speed of those rams will be effective for all rams. If you install same sized ram on 1st and the 3rd port, it should be run on dual channel mode and will be fastest possible. please try this if you have 4 ports.
Apr 19, 2009 | Compaq Evo D500 PC Desktop
Cannot get comp to install resource cd
pls take out all pci cards and have u installed AGP for VGA instead of in built tell me the make of ur vga , i think i can help u in this the first blue screen thing u were facing was not ur motherboard infact ur RAM u have changed it it should be gone even on ur old system, u have also changed the hard drive it has nothing to do with freezing thing u were facing ok
tell me how many pci cards have u installed in ur system and what abt VGA is it in built on mother board or additionally fixed by u , actually something is faulty and it is causing u trouble in hardware kindly do this
take all pci cards out modem , sound,tv card
use new RAM chips
just install RAM and VGA to start take out all drives like dvd or cd just leave one for installation the newest one
u can use ur old hardrive or new i dont feel it is ur hard rive
and then try to install OS without pci cards if u have
check the CPU fan is it running and also check the Casing Fan also
pls tell me the results
if not resolved tell me the whole config of ur system what u have inside
i can solve ur problem if u want
regards
Feb 28, 2009 | Dell Dimension 4300 PC Desktop
Pc chips a33g no boot windows
If you have a SATA hard drive your windows disk needs SATA drivers on it.
Download Driverspack from this site
http://driverpacks.net/DriverPacks/
Mass storage one
then copy windows CD to hard drive and use "Nlite" to install driverpack into it then burn windows to new CD and try again.
This should solve your problem
Dec 27, 2008 | PC Chips A33G (V1.0) Motherboard
Windows XP installation error
i have had the same problem when the hard drive was about to die or the ram is faulty
take ram out and clean gold edges with rubbing alcohol or a pencil eraser,
insert ram, if you have more than one chip try one at a time as one may be failing, ie (a bad spot on the chip and only stops the install when it gets to that location on the ram chip)
when you are running the install ,windows will ask you if you want to use the partitions on the drive
,say no and delete select partition ,this will format the hard drive and set a new one up,if the drive has problems it should show up then.
good luck ,and let me know how you go
Terry
Mar 31, 2008 | Computers & Internet
Emachines 1900+ gets power to the monitor and computer but wont boot
There could be a number of causes. Do you hear any beeps when the computer starts up? Try seating all the chips in the motherboard. That means, apply pressure to each individual chip on the motherboard with your finger or thumb. The goal is to make sure each chip is securely attached to the board. Sometimes, heat or new h/w installs partially "pop" some of the chips out of the motherboard - causing the circuitry to be disconnected...
Aug 03, 2006 | E-Machines eMachines Refurbished EMA...
HP Pavilion 8860 (P2941A) PC Desktop Logo
27 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
