Question about Car Audio & Video
My amp shuts off kicker zx 1500.1 wiring is good...
I had this amp for 3 months and the amp turns off when its on use i have to tap it so it will turn on sometimes hard any ideas
  • erick300m Dec 20, 2008
    i have checked conections ive tried another amp on my conections and it works well....ive tryied on another car and it wont work..this is a zx1500.1 kicker amp and theres no fuse outside i think they have internally but dont know how they look any idea?
    Sergeant:
    Champion:
  • 247 Answers
It sounds lik you have either a loose wire where they hook up or a bad electrical part on the inside. i would check your connections first.
Posted on Dec 20, 2008
  • 1 more comment
  • Thomas Dec 20, 2008
    you can try and take the outside cover off and check for any fuses but from my understanding there is supposed to be at least on or two red or blue retangle fuses on either on power side or the speaker side of the amp there should not be any at all in the inside. i think the one of your resistors or capacitors is going out on the motherboard and that would be why you have to hit it so hard sometimes.
    i believe that you could give a better to me since the onlt other thing you can do for you issue is take it in and get it fixed at a shop, so i think you could give a rating fixya please.
    tom
  • Thomas Dec 22, 2008
    Did my solution work for you? If so will you please change the rating to fixya, please?
    Thanks
    Tom
Kicker zx1000.1 stopped working completely. I have 3 Kicker 10" cv subs hooked to it. The first time it shut off I turned the system off. When I turned it back on it worked for a few minutes and...
First check to see if your'e getting power to the amp by using a test light and touch the main power(12V battery) connector on the amp, test light should come on since it's constant 12v supply. Now turn on the radio and test the remote wire connector on the amp and you should have 12V(test light should come on). Also make sure that you have a good connection with your ground wire, check both connection points to make sure it's good. Now if you have power where your'e suppose to and when your'e suppose to and the amp does not power up, then it may be time for a new amp. Try wiggling the connections at the amp a bit, the solder may be cold/loose.
Jul 12, 2011 | Kicker Car Audio & Video
My Kicker ZX-350.4 don´t shut down
I will assume that it used to and has a remote wire connected. if this is the case the only things I can think of would be the remote wire is disconnected/loose/damaged. if that isn't it I would look at your ground wires (all of them at both ends)
if nothing I have mention pans out then I would simply add a heavy duty switch. :)
Dec 14, 2010 | Kicker ZX-350.4 Car Audio Amplifier
Hi, I currently have the following Kicker Amp's.\r...
it depends, sometimes if your speaker is wired, if you have two dual 2 ohm subs and wire them in series ( +to+ -to- ) then they will wire down to .5 ohms, in which your amp is not stable other possible problems may occur if you wire these amps together to power one or two subs
May 18, 2010 | Car Audio & Video
My protection light keeps turning on.
i'm almost positive that your amp is overheating. i would either buy another one or bring it in to the geek squad. but i'm 99.9% sure it's overheating
Apr 28, 2010 | Kicker ZX10001 Car Audio Amplifier
Zx-8100 amplifier is red lighting.
try wiring them differently. here is a link for u to go to http://www.crutchfield.com/learn/learningcenter/car/subwoofers_wiring.html . once there find your amp configuration (ie. mono, or 2 channel) then down to the type of subs an how many subs ( ie. 2 dvc (dual voice coil) 4 ohm subs) an that will show u how the subs should be wired and wired to the amp.
Mar 21, 2010 | Volfenhag ZX-8100 Car Audio Amplifier
I wanna know if a 1500.1 amp good for 2 15'' kicker L7 solobarics
yes but you might get better results from it if you wire it for use on 2ohms
Oct 13, 2009 | Car Audio & Video
My kicker amp zx 300 want turn off when i turn my car off had the remote wiring check dont no what to do
Hello pruittdarryl,
Does the amp turn off when you remove the remote wire? If it does, then wire a toggle switch into the remote wire and just use it to turn the amp on and off. If the amp does not turn off with the remote wire removed, there is probably a short between the 12V+ and remote terminals. In that case, the amp is probably defective. If it is OK otherwise, you could still use it by putting a heavy duty toggle switch into the power wire itself.
Hope this helps.
Oct 10, 2009 | Kicker ZX300.1 Car Audio Amplifier
Kicker zx1000.1 the green led turns off and the red is lit
check your wiring make sure it is not grounding out check you sreaker wiring make sure they are not reversed +to- make sure it has plenty of air ti breath make sure your speakers are wired for two ohms or four it is not stable for one ohm it has a circuit protection if any one of these thins are happening it will kick the red light on and shut down.
Mar 22, 2009 | Kicker ZX10001 Car Audio Amplifier
Shuts off i have to tap it to turn on
make sure theres no corrosion on the screws and terminals. if that dosent do it open the amp look for loose wires and re solder. ps make sure ur wires are hooked to the amp properly
Dec 20, 2008 | Car Audio & Video
Kicker ZX 750.1
I figured it out!!! Thank yopu for responding though. I had a weak graound signal:)
Apr 12, 2008 | Kicker 06ZX750.1 Car Audio Amplifier
Car Audio & Video Logo
646 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
