Question about Danby DTT420 Top Load Washer
Need a repair manul for my danby dtt420w washer/spindryer
I have purchased a rubber seal for the spin drum but need a manual and to see the way the seal is put on the motor
Richie_asg1
  • 1036 Answers
SOURCE: Inner drum of my 7
Hi there!
I would say it is the rear drum bearing which needs replacement. This is what supports the load of the entire drum. The seal is just a water seal.
The good news is that it's a bosch, and replacements are easily available. You are lucky to get 7 years use without problems. Cheaper models give up after 12 months!
Check online for spares under the model number, or have it replacd by a local technician. It is the main drum bearing you need.
If this assists to a solution, Please take a moment to rate as fixya! Thanks.
Posted on Jun 18, 2008
onthejob5130
  • 640 Answers
SOURCE: Kenmore HE 3t Front Loading washer, rubber seal torn
fix ya..do it your self and save big,,im going to talk you through..and give you the part number...what you need is the bellows part # 8182119...ok vack unplug unit..open the door,,now you see the front lip of the bellow theres a wire with a spring stick a srew driver and pull off,,wire off ..ok now look in the unit right behind the front panel and in front of the tub in the upper right hand corner of tub font or bellows backside there a nut take screwdiver and losen pull bellows off,,easy to put back just reverse but open clamp a bit on back...onthejob
Posted on Jan 27, 2009
  • 100 Answers
SOURCE: Hotpoint Aquarius WF220 Front Load Washer dirty rubber drum seal
its a matter of removing the front retaining wire and the inner one which holds it onto the drum, an easy enough job to get off, sometimes a pain to get the inner off and on depending whether it s the screw or clamp type , screw=easy. to get the clamp off use a screwdriver to wiggle the bent wire out of the ratchet grooves. to put back is done with long nose pliers, preferably bent nose ones.
Posted on Feb 03, 2009
abhishek33
  • 1239 Answers
SOURCE: Water leaking out at bottom of drum during washing and spin cycle
hi it is the problem o outlet valve, clean it...... thank u.......
Posted on Jun 03, 2009
SOURCE: The wire around the rubber seal on my bosch washer
I have the same washer, and have run it for some time without the wire. As long as you make sure the seal is seated when you close the door, it doesn't leak.
I have no idea about the mildew problem - never had that happen to mine.
Posted on Mar 30, 2010
WHEN I FILL THE WASHER, WATER FLOWS INTO THE SPINNER HOW CAN I FIX THIS
If what you mean is that the water level rises too much, then what you have is a bad water level switch. You will spot it easy, for it has a hose attached to it. Sometimes they just jam and all it needs is a gentle tapping. But is likely that it will jam again
May 06, 2016 | Danby DTT420W Portable Washer
Spinner only spins one way .
I have the same problem the spinner spins one way, after attempt to change the motor drive it can't spin any more what's the problem
Mar 16, 2014 | Danby DTT420W Portable Washer
Applying for Free extra 2months warrantry on my Danby SpinDryer purchased today. Model # DTT420 W
Are you sure you are applying at the right place? This site doesn't do warranty work on anything!
Jun 03, 2011 | Washing Machines
In spin cycle the drum vibrates like it has no support at the front i need a service manual
PLease go to this website. you can download a free manual:
http://www.danby.com/product.php?cod_prod=DWM5500W&code=5
I hope this helps. please remember to rate FIXYA
Thanks
Mar 25, 2011 | Danby DWM5500 Front Load Washer
Danby front loader becomes very loud during spin cycle
Most likely this will be the drum bearings.
Bearings normally last quite a long time but some will fail sooner than others. Quite often bearing failure is due to a faulty drum shaft seal which allows a small amount of water through and in to the bearings. The bearings then start to rust, which then accelerates the wear on the bearings.
Replacing the bearings needs well above average DIY skills to do, so unless you feel confident to tackle the job, can get hold of a tech manual, and can get hold of new bearings, it's time to call an engineer.
Sep 30, 2009 | Danby DWM5500W Front Load Washer
Whirlpool Ultimate Care II drum does not spin.
Depending on your washing machine model, the drum and motor are connected by 2 plastice yellow circular pieces, with a black rubber washer in the middle with holes where the pegs or rods go into. The 2 plastic circular pieces have 3 pegs or rods if you will, that connect to the black rubber washer via 3 holes. Sometimes, one or both of the 2 plastic circular piece pegs get broken off or the rubber washer cracks and breaks apart, so that the motor will not turn the drum. If thats the case, you can purchase the 2 circular pieces and black washer piece as a set.
Jan 05, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Loud noise(not jet whirring sound) during rinse & spin cycles.
the rear bearing is bad the bearing is press in to the outer tub the outer tube is like a **** shell you need the rear half and new seals it is a big job if you are going to do it you will need a manul
Dec 02, 2008 | Maytag Neptune MAH5500B Front Load Washer
Danby DTT420 Top Load Washer Logo
118 people viewed this question
Top Danby Washing Machines Experts
shaun taylor
Samyfam
Samyfam
Mike
Are you a Danby Washing Machine Expert? Answer questions, earn points and help others
