Question about Neovo F-417 17" LCD Monitor
F-417 working inconsistently after power fluctuation/outage.
Since a power fluctuation, followed by a complete failure, my F-417 has been behaving weirdly:
It works normally for some time, then the screen goes blank and the power LED blinks unevenly. While it's doing this, the power button seems to neither turn it on, nor off. A random time of this, and the picture returns, and the monitor continues to function for a bit more, and then back and forth between these two states. Changing the power cable didn't help.
Could anyone offer any ideas as to what this is, and if it can be fixed?
  • lordlandon Dec 20, 2008
    The monitor continues to do this when connected to another computer, and it was connected to one of them power strips when the power problem occured.
    Problem Solver:
  • 6 Answers
You may want to check the VIDEO cable that goes from the monitor to the computer. Make sure its in tight. If the montor still continues doing this, it could be caused either by A) a faulty monitor, or the monitor is going bad B) the video card inside the computer is going bad. If you have another monitor in the house, try it and see if you have the same problems. If you do it's most likely the video card inside the comptuer going bad. If you don't, then replace the monitor. Was the monitor plugged into a surge protector? Let me know how it turns out... THANKS
Posted on Dec 20, 2008
  • Questman
    Questman Dec 21, 2008
    Seeing that the monitor is doing the same thing on a different computer, looks like your monitor might be shot. If the surge protector is old, it may have lost it's protection ability and would be time to replace it. If I were you I'd purchase a new power strip with the abilty to protect electronics from power surges, they usually have a guarentee to replace the equiptment plugged into them up to $25,000. Then I would get a new monitor. Good Luck...
2000 lincoln town car light control module wiring diagrams
You don't need a wiring diagram ,what you need is a scan tool that will pull codes from the LCM , an LCM Parameter Identification (PID) Index ! Checking codes first !
LCM Diagnostic Trouble Code (DTC) Index DTC Description DTC Caused By Action B1312 Lamp Headlamp Input-Short to B+ LCM REFER to Section 417-01 . B1334 Decklid Ajar-Short to Gnd LCM REFER to Section 501-14B . B1340 ESC Tone Input Request Short to Ground LCM REFER to Section 501-14B . B1342 ECU-Defective LCM REPLACE the LCM. REFER to Section 419-10 . TEST the system for normal operation. B1352 Ignition Key-In-Ckt Failure LCM GO to Pinpoint Test C . B1359 Ignition Run/Acc Circuit Failure LCM REFER to Section 211-05 . B1462 Seat Belt SW_Ckt Failure LCM GO to Pinpoint Test B . B1485 Brake Pedal Input Circuit Short to Batt. LCM REFER to Section 417-01 . B1555 Ignition Run/Start Circuit Failure LCM REFER to Section 211-05 . B1569 High-Beam-Short to B+ LCM REFER to Section 417-01 . B1577 Park Lamp Input-Short to B+ LCM REFER to Section 417-01 . B1581 Panel Dim Increase Input Circuit Short to B+ LCM REFER to Section 413-00 . B1585 Dim Panel Decrease Input Circuit Short to B+ LCM REFER to Section 413-00 . B1676 Battery Voltage Out of Range LCM REFER to Section 414-00 . B1687 Dome Lamp Input Short to B+ LCM GO to Pinpoint Test D . B1689 Autolamp Delay Input Circuit Failure LCM REFER to Section 417-01 . B1691 Autolamp Delay Input Circuit Short to B+ LCM REFER to Section 417-01 . B1695 Autolamp ON/OFF Short to B+ LCM REFER to Section 417-01 . B1873 Turn Signal/Hazard Power Feed Short to Ground LCM REFER to Section 417-01 .
Aug 12, 2016 | 2000 Lincoln Town Car
Bad line ge nomogram
You need to think of these ovens as electronic devices. If you get this message after a power outage, it is behaving just like your cable box or internet router when they have functional upset from a power outage. Turn the power off to the oven at the electrical box for 10 minutes then turn it back on. The oven should cycle up and then work. Mine did!
Mar 17, 2014 | GE Monogram ZDP48L4GHSS Dual Fuel...
My samsung model RF263AEPN is flashing an 88 89 after the power went out
This is taken directly from the Samsung website:French Door: Why Is The Display Blinking 88 88 And Not Responding?Cyber
Drastic power fluctuations such as power outages and surges can cause electronic device to behave abnormally. If the refrigerator display is showing 88 88 (all eights) and is still cooling properly, unplug the refrigerator for 60 seconds and then plug it back in. If the display returns to normal after approximately 2 minutes service is not required. However, if the display does not return to normal service is required.
Sep 23, 2013 | Samsung RF263AEPN French Door Refrigerator
Won't turn on
This is a clear failure of the power supply or the control panel due to the power outage and so will require that the power to the unit internally is checked. Sometimes this can be due to a fuse blown out or a control panel failure within the unit due to the intermittent fluctuation.
Nov 30, 2011 | Pool & Spa
I have a Utilitech In Wall Digital Timer Lowes Item #: 141224 | Model #: LW60418, purchased from Lowes. I've lost the instructions and can't figure out how to set the timer after a power...
Open following link for Utilitec timer manual:
http://waterheatertimer.org/Program-wire-Utilitec-LW60418.html
This timer should have a back-up capacitor so that programming is kept in memory during power outage.
Power outage is known cause of timer failure. When power turns on, the surge knocks out electronics.
People writing to fixya report electronic timers and electronic water heater controls stop working after power outage. Probably many other electronic devices are affected too, but that would be out of my specialty.
Troubleshoot says 'in case of operational failure, press reset button to clear all settings and restart.'
If timer has failed, buy another from Lowes and return defect in new package.
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 11, 2011 | Intermatic Inc. ST01C Digital In-Wall...
Panasonic AG-DS550 VCR shuts itself down about 2 seconds after switched on. No error code appears in that brief interval. Toggling the power switch immediately is ineffective, but after waiting a while,...
This is a typical symptom of a power supply failure. There are some self-checks performed at power-up that are not completing correctly. Were there any symptoms before the complete failure? Often, the units start to behave strangely before complete shutdown. The power supply failure is tied to defective capacitors in most cases. These supplies are what are called "switch-mode" supplies and must oscillate to work. Defective caps will either not provide the kikcker to start the oscillation or prevent the oscillation completely. While there are other causes, this is the most common. AG units are professional decks and should be serviced by authorized service centers.
Hope this helps,
Dan
Dec 07, 2009 | Panasonic Televison & Video
My computer doesn't power up. There is power throught the motherboard as my speakers have power. There was power to my mouse but that seems to have gone now. Has been working fine to date but went to turn...
might be that the power supply you have does not have enough wattage or power to power the new graphics card you have. If you insert or install your old graphics card does that allow it to work ?
Also what wattage power supply do you have and what new graphics card did you get, does the new graphics card have a molex on it to allow you to connect an actual power connector to it ( presuming it will be a 5 volts molex connector ) ?
Some graphics cards require extra power hence the molex conncetors.
Apr 10, 2009 | Computers & Internet
There was a power outage in the middle of the night. My computer was turned on during the outage (Presario 2200). Now it will not turn on ; it is plugged in (was in a surge protecting power strip during...
Please try to remove the battery and than try to switch on the laptop directly from mains power and if it works than its your battery problem or if it still not starts than there is possibility of some components of your laptop may fired due power fluctuation. So go and contact service station.
Jan 08, 2009 | HP Compaq Presario 2200 Notebook
Wii completely stops working after power outage
I just had the same problem as everyone else. I had a brief power loss and our new Wii system's power would no longer work. To fix the problem, I unplugged everything from our Wii and unplugged the power cord from the outlet. I let the system set for 10 minutes and re-plugged the power only. That did the trick. Then I was able to plug everything back up and we are now back to playing.
Supposedly, doing the steps above resets the Wii according to the Nintendo online trouble shooting guide.
Sep 28, 2008 | Nintendo Wii Console
Neovo F-417 17" LCD Monitor Logo
578 people viewed this question
Top Neovo Computers & Internet Experts
Steve Allison
Steve Allison
Are you a Neovo Computer and Internet Expert? Answer questions, earn points and help others
