Question about Toro Blowers Rake and Vac - Electric Blower/Vac - 51573
What are Carborater adjustments for Toro 524 Snowblower?
No longer have the owners manual for the Toro 524 snowblower so we are not sure what the carborater adjustments need be.
  • mary284 Jan 30, 2009
    Thank you. We will give this a try and let you know. Sorry, I didn't see your suggestion until now.
2 Suggested Answers
  • 398 Answers
SOURCE: Not sure what Carborater adjustments need be?
while your running it play with the screws, until it sounds steady and runs with out stalling
Posted on Feb 27, 2009
I replaced the auger on my Toro 1800 electric snowblower and now the auger stops as soon as it hit the snow. How do I adjust the auger?
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Jan 08, 2017 | Toro Garden
How do I adjust the belt ona Toro 726 snowblower
There should be a tension pulley between the main pulleys. Usually it is mounted on the side wall and can be adjusted with a nut and bolt.
Mar 16, 2016 | Toro Power Max 726 OE Snowblower - 37771
Problems shifting toro power max 726 oe snowblower
adjust the cable easy to do , get the manual or just look good at it ,
Feb 04, 2014 | Toro Power Max 726 OE Snowblower - 37771
Toro snowblower troubleshooting
adjust the cable to accelator so it revs higher ,
Oct 27, 2013 | Toro Power Clear 621 R Snowblower - 38451
How to install the needle valve in a carburetor of a toro 524 model 38040 2 stage snowblower
take bowl of the bottom of carb pull out little pin that holds float bowl on change needle valve put back together make sure you put the bowl gasket on right or it will leak
Oct 11, 2013 | Toro Garden
Just cleaned out my father's garage and came up with a Toro 524 snowblower this unit has not been running for over 6 years what should i do to get it up and running? can't find an owner manual online...
You need to clean the carb, make sure fuel lines are not cracked and brittle (replace if necessary) , clean fuel tank thoroughly, especially if there was still fuel in tank. Check for spark, mix a new batch of fuel (if mix is required) and start that mother it will probably run as good as new. Good Luck...
Nov 07, 2010 | Toro Blowers Rake and Vac - Electric...
Dec 20, 2008 | Toro Blowers Rake and Vac - Electric...
Toro Blowers Rake and Vac - Electric Blower/Vac - 51573 Logo
2,093 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
