Question about Toro Blowers Rake and Vac - Electric Blower/Vac - 51573
Not sure what Carborater adjustments need be?
Do not have the owners manual and not sure what the carborater adjustments need to be.
  • mary284 Feb 27, 2009
    Thank you for the help.
  • 398 Answers
While your running it play with the screws, until it sounds steady and runs with out stalling
Posted on Feb 27, 2009
Geting gas to carborater but not to sparkplug
Check the Jets in the Carborater they my be stopped up also check the float it could be stuck as well
Sep 20, 2015 | Honda Cars & Trucks
Craftsman weedwacker
If yiu remive the cap on the fuel tank and kook inside you will see one line only just enters the tank, this one giesto the orime bulb, tge ithet gies ti the carb inket.
Aug 02, 2013 | Garden
Why does my truck backfire thru the carborater when it is hot outside?
A backfire is caused when your intake valve/s aren't closing completely before ignition in the cylinder. This ignites any fuel/air mixture left in the intake manifold. Fine tune your timing.
Aug 15, 2012 | Cars & Trucks
I have a stink 032av spits gas out.carborater And won't fire I tried starting fluid in the cylinder and it still spit out of carborater
Do the easy stuff first: Rebuild the carbuerator... If the diaphram of the fuel pump has deteriorated or has a hole this will cause the problem. One side of the diaphram connects to the crankcase getting pressure pulses that drive this fuel pump diaphram. More than this you wil probably have to take it in for service. The carburator kits usually run around $20. Be careful to not lose parts and assemble exactly the same. AVOID adjusting the idle screws.
May 13, 2012 | Garden
Fuel not getting to carborater
then it is fuel related make sure the fuel shut off is turned on if fuel was left in it for a long time dump it out and try fresh fuel then take apart the carb and clean it completely
Mar 26, 2012 | Husqvarna Garden
Truck will run only when i pour gas into carborater once it uses gas in carborater it stops firing
This sounds like a problem with the fuel pump. I would suggest that you check the fuel pressure. it should be 60psi. If not...fuel pump most likely the problem.
Feb 02, 2011 | 1999 Ford F250 Regular Cab
Back fires through carborater at high speed
mcdevito75 here, Either you have a worn / burnt / cracked intake valve, worn timeing chain / belt or the ignition system needs to be checked and adjusted. The shop has the tools and equipment to help you out.
Oct 25, 2009 | 1985 Nissan Pickup
Where is the carborater located on a 1996 toyota camery?
find the air filter and follow it up to the throttle body and get a can of starter fluid and spray a small amount into the throttle body also take the gas cap off a few minutes and then put back on because it could have a vacuum pressure in the tank and if it does not work with the starter fluid you may have a plugged fuel filter too also look in owners manual and find out where your fuse shut off switch is and if no owners manual check here www.edmonds.com they have owners manuals online and you can try autozone.com to see if they have your car listed for diagrams pictures and step by step instructions if your car is not listed then try your local library they have all the car manuals and even copy them for you if you need anymore instructions
Mar 21, 2009 | 1996 Toyota Camry
Carborater gets stuck on my 1989 jeep cherokee pioneer
The 1989 Jeep did not come with a Carb it was throttle body injected and the motor should be a 4.0. let us know what motor it is.
Feb 28, 2009 | 1989 Jeep Cherokee
Toro Blowers Rake and Vac - Electric Blower/Vac - 51573 Logo
119 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
