Question about Acer Aspire 3690-2196 Notebook
When i turn my laptop on all i get is a curser
I took my hard drive to computer solutions and they said that there was no files on my hard drive that some one had erased it how do i restore it please help me
  • 136 Answers
Use the recovery disks you received when you bought the machine. Turn the computer on, insert the cd and reboot the computer.
If all you have is a cursor and there is nothing on the hard drive, then you can either restore to the state it was in when you first bought it, or spend thousands of dollars on data recovery that may not even work.
Posted on Dec 20, 2008
  • 68 Answers
You will have to reload your operating system, you can do this with your os dvd/cd or over a network with tftpd
When i turn on laptop, i get blank screen with blinking curser and can not do anything
This indicates a hard drive issue or windows files have been corrupted, try a full recovery of windows, if you have the backup disc all the better, if not power the computer, wait for acer logo press ALT key and tap F10 until it goes into recovery, if nothing happens have your hardware tested.
Jun 23, 2012 | Computers & Internet
My Advent laptop has power but no picture, however the curser is showning
The hard drive has issues, or windows files are corrupted, If you have a CD installation disc try and reload your operational system, if that fails! have the hardware checked out for possible replacement.
Apr 25, 2012 | Computers & Internet
When i turn my computer on i had a black screen with a curser in the top left hand curser
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Mar 21, 2011 | Computers & Internet
My IBM think pad does not boot. it only shows black screen and blinking curser. after few seconds it shows a message saying pxe-e61: media test failure, check cable.
There are two possiblities, first is your data cable it may damage so you need to change it or your data cable not plugged properly so check it. Secondly, you need to reset your boot order to resolve your issue.
Thanks & Best of Luck
Mar 09, 2011 | Computers & Internet
Hi i have a dell inspiron1545 and when i turn it on i get the dell screen then it just goes black with a flashing curser in the left hand corner i rang dell but its out of warrenty but they did say it...
Hello
It seems the Hard drive error but first you check hard drive in CMOS Setup, if the HD is appearing in Setup thats mean that the Hard Drive is OK
Then you have to try recover the system by installing Operating System with Recovery CD if you have or by any windows CD/DVD you may have.
Hope this helps, if so do rate the solution Good Luck
Jan 05, 2011 | Dell Inspiron 1545 Notebook
Hi,\r\n When i plug in my Western Hard Disk WD4000ME, its detected by the system and all files are shown, but I cannot copy those files back to the system. It gives the following error:- "The requst could...
An I/O error indicates an issue with the device driver(s) that handle input/output processes such as copying files to/from hard drives, data in resident memory (RAM) waiting to be processed by the CPU or the controller chipset that handles the primary calls to/from the subsystems or a faulty hard drive.
Below are a few solutions that may help resolve the issue and allow you to transfer your files:
Before proceeding, you will need the following:
A. Computer B. External USB Hard Drive C. USB Cable D. RAM Module (Replacement, if necessary) E. Hard Drive (Replacement, if necessary) F. USB Hard Drive Enclosure (Replacement, if necessary) G. USB Cable (Replacement, if necessary)
Note: Solutions B/C apply only to Windows OS.
Solution A. Faulty USB Cable
1. Replace the USB cable. 2. Connect USB hard drive to the computer. 3. Attempt to copy a file from the drive. 4. If successful, copy additional files, as needed. If not successful, skip down to Solution B, step #1.
Solution B. Locked I/O Processes
1. Press and hold the power button on your desktop/laptop for about 10 seconds (or until the system has powered off completely). Then release the power button. 2. Make sure the USB drive is plugged in. 3. Wait another 10 seconds and press the button once again to power on the computer. 4. Once logged in, attempt to copy a single file from the drive 5. If successful, go to step #6. If not successful, skip down to Solution C, step #1. 6. Continue to copy files from the drive. Make sure to pay attention to what files (if any) prompt the I/O error message. If you receive an I/O error, skip down to Solution C, step #1.
Solution C. Motherboard Device Driver Installation/Update
1. Click on the "Start" menu and click on "Control Panel". 2. A new window will open, double-click on "System". 3. A new window will open, click on "Device Manager". 4. A new window will open, listed in the hierarchy are all the hardware components installed on the desktop/laptop. Look for any devices that display either a red "X", yellow "!" or yellow "?". These devices have either incorrect, incomplete or missing drivers/software and need to be installed, as they might be the root cause of the trouble. 5. If any of the above icons are present, perform a Windows Update by visiting the site below:
http://update.microsoft.com
Perform any updates available on the software and hardware side. 6. Restart your computer. 7. Follow Solution C, steps #1-4 to determine if any drivers still need updates. 8a. If updates are not needed, attempt to copy files from the hard drive. If successful, go to step #9. If not successful, skip down to Solution D, step #1. 8b. If updates are needed, you may need to visit the support site for your desktop/laptop's make/model and download any missing drivers. 9. Continue copying files, as needed.
Solution D. Faulty RAM
1. Power off the desktop/laptop and disconnect all cables. 2. Open the desktop/laptop. 3. Remove all the existing RAM. 4. Install the replacement RAM. 5. Power on the desktop/laptop. 6. Connect USB hard drive. 7. Test by copying some files from your hard drive. 8. If successful, close your desktop/laptop and continue copying files, as needed. If not successful, remove replacement RAM and reinstall previous RAM and skip down to Solution E, step #1.
Solution E. USB Hard Drive Case Faulty I/O Board
1. Power off computer/desktop and disconnect all cables. 2. Open your USB external case. 3. Remove your existing hard drive. 4. Install hard drive into replacement USB case. 5. Power on your computer. 6. Connect your USB external drive. 7. Copy files from your external USB hard drive. 8. If successful, continue to copy files, as needed. If not successful, skip down to Solution F, step #1.
F. Hard Drive Malfunction
1. Power off computer/desktop and disconnect all cables. 2. Open your USB external case. 3. Remove your existing hard drive. 4. Install replacement hard drive into USB case. 5. Power on your computer. 6. Connect your USB external drive. 7. Copy files from your external USB hard drive. 8. If successful, continue to copy files, as needed. If not successful, this could be an indiction of a much larger problem in the form of a Motherboard issue.
If the motherboard is malfunctioning, this is a sign of bigger things to come and will require a replacement board in order to correct.
In the event that the motherboard needs replacement, depending on the make/model of the desktop/laptop, the cost could range from $35-120 for 3rd-party boards or $85-300+ for consumer-level systems from manufacturers such as HP, Dell, etc. and $350-1000 from Apple.
If your desktop/laptop is still covered by the manufacturer's warranty or 3rd-party extended warranty, any hardware component that needs replacement should be covered at little to no out of pocket expense to the end-user. This also includes the external USB hard drive, as well.
Aug 15, 2010 | Western Digital Passport 320GB External...
Will not turn on - when I turn I the screen is blank with a curser in the top left cornwe
Generally an indication of a failed hard disk drive. Remove the hard drive and try to boot to a XP CD or Resource CD. If system boots to the CD, then replace the hard drive.
Oct 17, 2009 | Dell Inspiron 6000 Notebook
Recovery options onboard hard drive
Your hard drive is bad. That is what the SMART test is telling you. Replace the hard drvie.
Mike
Jul 20, 2009 | HP Pavilion dv4000 Notebook
Acer Aspire 3690-2196 Notebook Logo
48 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
