Question about Kitchen Ranges
I need to know if a permit is suppose to be requiered to run a pellet stove
  • 2,692 Answers
It depends upon the juristiction of where you live. Your local  fire department wil have that information.
Posted on Dec 20, 2008
Just bought a house with a Gibraltar SCR stove in it. I want to use this thing, but have never owned a stove and don't know how. What fuel? How to set the fuel in the stove, etc. Can you help?
Gibraltar makes coal, pellet and wood stoves. Stoves that burn wood pellets have a hopper and feeder auger that feeds pellets into the burning chamber. They also require electricity to work. From what I read online you should be able to burn wood in the stove but I believe the coal stoves have a smaller burning chamber.
Nov 28, 2017 | Heating & Cooling
Alternative Heating Pellet Stoves and Pellet Inserts
Pellet stoves usually use wood pellets as their primary heat source. A pellet stove is defined as a stove that burns either compressed wood or biomass pellets to make heat to warm a home or other space.
Pellet stoves come as either free-standing units or fireplace pellet inserts which can be vented into an existing chimney. As an insert, you are able to replace your wood burning stove with this efficient and cost effect stove. Inserts also give the homeowner more of the look of a fireplace than that of a pellet stove. Pellet inserts can also be a great alternative for people who have busy lifestyles and are looking to get the beauty of a fire but prefer a cleaner burning renewable heat source.
Pellet stoves are freestanding structures that can give you the feeling that an old pot bellied stove did, tucked into a corner of a living room, den, or kitchen. Either the pellet inserts or freestanding stoves are a great alternative heating solution for keeping a house warm during the winter.
Many stove manufacturers recommend the using a corn and pellet mixture, but some are UL listed for many fuels other than pellets. These can include wheat, corn, sunflower seeds, and cherry pits.
Pellet stoves are a bit more efficient, burn cleaner, and are easier to use than conventional wood burning stoves. Pellet stoves often look very similar to wood stoves or fireplace inserts, however the similarities end there.
If you are considering burning alternative fuels then you will want to look into a pellet stove as a great way to heat your home. Pellet stoves and pellet insets have many great advantages over regular wood stoves that make them a practical heat for busy lifestyles.
on Dec 07, 2009 | Heating & Cooling
Heilsa Pellet Stove Manufacturers Information
pellet stove tp440 Pool & Spa Heaters Questions & Answers ... > Forum > Tags > pellet stove tp440
Pool & Spa Heaters pellet stove tp440 questions and answers. ... for a manual orinformation on this stove it is an older stove we just don't know how old. ... heilsa pellet stove model qcps-28000 my pellet stove is smoking how to change ...
General Infrared Sauna Heilsa Sauna Supplier, Find Best ...
Suppliers who can match your search. .... Outdoor Spa,Sauna Room,Jacuzzi,Swimming Pool,Sand Filter .... Infrared sauna room,Portable steam sauna,Infraredheater,Pellet stove,Clothes dryer ..... updates on topics such as trending hot products, buying requests and supplier information - sent directly to your email inbox!
Good Quality Far Infrared Sauna Supplier, Find Best Good ...
Suppliers > .... Outdoor Spa,Sauna Room,Jacuzzi,Swimming Pool,Sand Filter ...Infrared sauna room,Portable steam sauna,Infrared heater,Pellet stove,Clothes dryer heilsa infrared sauna with good infrared sauna accessories ..... buying requests and supplier information - sent directly to your email inbox!
Jan 06, 2016 | Pool & Spa
Which pellet stove do you have? A lot of pellet stoves have a part inside called a Draft Flow Switch the size of your palm and hook to the Draft Flow Switch is a Draft silicone hose and this will get clogged with debris you will need to look at your diagram to see if you have that on your stove. If you do you will need to "gingerly take off the hose and blow through it. and re connected to the draft flow Switch. After sometime the hoses become brittle. Another thing to look at is the exhaust at the back of the stove cleaned out and you are getting your pellet stove cleaned out by a chimney sweep.
Mar 03, 2014 | Us Stove Company Pellet Heater with...
Traeger pellet stove minuteman MPW070 user manual
does the auger in my mpd070 pellet stove have a carrier on both ends
Feb 08, 2014 | Kitchen Ranges
Can I run a pellet stove off a generator its a 3500 Watt generator I bought at tractor farm supply Just need to know Yes or no I got a harman invincible insert pellet stove
If you are just running the blowers and what not, then yes you can. Blower motors do not take more than between 200 and 500 watts or so, so you should be okay running the blowers.
Jan 06, 2014 | Electrical Supplies
What do you need to do to put a woopellet stove pipe thru wall
I'm confused by your question. If you are asking what is involved in installing a pellet stove well it varies greatly from model to model. Generally speaking, most pellet stoves will horizontally terminate behind the stove itself as opposed to running thru the roof like a woodstove does. Pellet stoves require the use of electricity for numerous functions, one of which is power venting thru this rear terminated pipe. As far as clearances to combustables, you will find that pellet stoves are very forgiving in that department, with minimal clearances required. Once again all stoves are different and they all are rated indepentently so my best advice to you is find a quality pellet stove dealer and go in and see them. They will be more than happy to answer your questions. Avoid the big box stores as they have pellet stoves at a good price but offer NO service or installation and believe me, I am in the business, you will need professional service at some point during the life of your stove so don't save a couple bucks by going cheap. You will be happier for it down the road. Good luck.
Mar 12, 2009 | Napoleon Auburn Pellet Stove Heater
Stove trips breaker
Begin by unplugging the pellet stove and using an extension cord, plug the pellet stove into a different circuit, with a different breaker. It is possible that the breaker itself is faulty. If you prove that the problem is in the breaker, replace it. If the new circuit also trips, then you will have to assume that the stove cord, or the stove mechanism is faulty and either repair or replace it. good luck with it. let me know.
please mark this answer as a fixya! ty.
Mar 11, 2009 | Napoleon Auburn Pellet Stove Heater
Kitchen Ranges Logo
94 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
