Monitor not on but menu light are blinking - Computers & Internet
  • 781 Answers
You have a common problem with no simple solution.
the causes could be the following:
*faulty video card
*faulty data cable going to your monitor form the the computer
*faulty memory
*faulty motherboard-video controler
*faulty monitor
this is what I would do
1. Test the monitor on a known good computer (to see if the monitor is good or not)
2. test the computer with a known good monitor (to see if computer is the problem)
3. if 2 is telling you the computer is the problem. try replacing the video card or use a video card if you were using the video that came with your motherboard
4. if 3 did not give you good results, try replacing memory modules for known good memory modules (check your motherboard documentation to know what memory to get)
5. try replacing your motherboard.
Posted on Dec 20, 2008
    Problem Solver:
  • 16 Answers
Hi there, i assume you switch on the monitor but there's no display. Is the monitor working before this? If what i assume is right, you should check the connection between the monitor and the cpu. If that doesn't solve the problem, then you should check the vga card. Maybe the pci slot/vga port is damage. If that the problem, you should change another display card.
Blue light on with blank screen dell SE198WFP monitor
It depends on what type of connection you are using. If you are using a VGA (analog) cable then you need to select that mode on your monitor menu. If you are using a DVI (digital) cable then you need to choose that mode on you monitor menu.
Nov 24, 2013 | Dell SE198WFP LCD Monitor
Menu keep on blinking
Disconnect the monitor from the computer. Then turn on the monitor, if the menu keeps on blinking then that means the screen is starting to go bad and the monitor needs to be replaced.
You can also hook up the monitor to another computer. If the blinking stops then that means its an issue with the video card in your original computer.
Feb 05, 2012 | Samsung Computers & Internet
Rapid green blinking green light on monitor and power & no video
try to acces the menu and to reset the display settings.
try another monitor on your computer to be sure that your video board is working, and if it is change the resolution in 1024X768 and try again your dell display
Oct 27, 2009 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Main menu is going on blinking.
its a problem with the monitor and press and hold the menu button on the monitor and the problem will be resolved
Oct 01, 2009 | ViewSonic E70f 17" CRT Monitor
The power save light is blinking and the screen is black, but I cannot get it to turn on. Have rebooted everything. Disconnected the cord and just tried the monitor only. Hit Enter. Nothing is working
When you have the monitor by itself will it power on at all? You should be at least able to get to the menu. If not its likely the monitor itself is faulty.
Sep 30, 2009 | Samsung SyncMaster 920NW Monitor
My monitors light is blinking all the time n no pic Nec Multisync FP1355
there is a setting you can access from the monitor menu button. make sure that the monitor is set for the cable you have running to it.
If you are using DVI use the digital setting.
Anything else, use the analogue.
Jun 28, 2009 | NEC MultiSync FP1355 (White) 22 in.CRT...
Front panel lights blink on/off once per second
Hey,
I would like to agree to the diagnosis that you have done on the monitor . Thanks for a well complied solution. You can try the following website
http://werepairmonitors.com/monitor-repair.htm
dell generally sources the monitors from NEC,Hitachi or LG.
Thanks
proton
Mar 23, 2009 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
ACER AL1715 PowerLed blinking only,no picture,flash about .5secs
This sounds as if you are using the hibernate feature in windows reboot it and reset the power options to hibernate never check the vid connection as well
Dec 19, 2008 | Acer AL1715 17" LCD Monitor
F1703 17" Keeps blinking each 4sec, but I can see the PC scrren
it is a stupid moniter I have ever seen...I have 4 monitors with same problem...given many times for repair...no use...
Sep 07, 2008 | HP Pavilion F1703 17" LCD Monitor
Blinking lights when PC is turned off
This works if you boot the monitor with a pc, open the osd menu and go to reset. reset the monitor.
Dec 08, 2007 | Acer AL1715 (Black, Silver) 17" LCD...
Computers & Internet Logo
125 people viewed this question
Alun Cox
David Payne
David Payne
