Question about Mitsubishi VS-50603 50" Rear Projection Television
Mitsubishi VS50603 will not turn on
I have a Mitsubishi VS-50603 that will not turn on. When I press the power button, the green LED next to it blinks quickly but set will not turn on, it apears to be some type of short. I attempted to reset it by un plugging the set for a couple of hours with no luck.
  • 66fordcobra Jul 16, 2008
    try to turn on the set ,it clicks on green and turns off immediately no picture
    Genius:
  • 1,074 Answers
If you are not a tech the tv needs to go to a tech to be fixed.the probleis in the power supply or related circuit good luck.
Posted on Apr 02, 2007
Mitsubishi VS-50603 won't turn on.
Hi Friend,
Please folliow the below steps one by one
Step 1: Turn on the TV
Step 2: Hold the ON/OFF Button for 10 to 20 Secs
Step 3:Without taking the hand from the ON/OFF button unplug the power cable connected to the wall outlet from the TV
Step 4:Without taking the hand from the ON/OFF button put the power cable back to the outlet
Step 5:Now take the hand from the ON/OFF Button and try to turn it ON again and check
If still you are having the same problem then please check the resolution configured in the Screen,try to reduce the Colour and the brightness of the TV
Even after that you are facing the same issue please check with the Display Card in the TV,
If you have any Clarification please feel free to contact us
Regards,
Ayyasam
Apr 02, 2010 | Mitsubishi VS-50603 50" Rear Projection...
Mitsubishi Projection TV Model #VS-50603 will not turn on.
The TV is going into a "protect mode", the micro-processor has sensed a circuitry problem and has shut the set down so that no furhter damage can happen, you will need to have the TV serviced by a Mitsubishi tech. Good luck !
Jan 07, 2010 | Mitsubishi VS-50607 50" Rear Projection...
Disassembling Mitsubishi VS50603
Yes, it is possible!
Your set has three picture tubes, also known as CRT's, when the set is on there is aprox 30,000 volts going to the CRT's usually on large red wires that come from a common point. The CRT's can store a charge, the manufactures do put some circuits in that should drain that voltage away but if the set had a problem it may not happen.
Also, the CRT's are sealed in a vacume so if they are hit the wrong way can implode, all the glass gets sucked in toward the middle then flys outward. Another concern is inside the CRTs is a phospher coating, not good for you.
Sep 12, 2009 | Mitsubishi VS-50603 50" Rear Projection...
Mitsubishi VS-50603 Wont Turn on
The power supply will need to be changed. The capacitors inside the power supply are not sending the correct amount of power to tv and will need to be changed.
May 13, 2009 | Mitsubishi VS-50603 50" Rear Projection...
Good Day, jessayala;
It sounds like you may have Ethylene Glycol on the boards, leakage from the TV's CRT's. The Glycol is a fluid that help's the tube cool. If you are not handy, very, very handy, I would call an Authorized Service Center to come out and give you an estimate before the repair is performed.
Good Luck, big IRISH......PS..... If can handle your self ..... come back here.
Aug 28, 2008 | Mitsubishi VS-50603 50" Rear Projection...
Will on ocassion power on and get sound and image
press the menu and input/device buttons both in together on the front panel and hold in for 5 seconds to see if the Led will blink a two digit blink code. Then let me know what the code is., and I will help you with the problem.
Aug 10, 2008 | Mitsubishi VS-50603 50" Rear Projection...
Won't turn on
Good Day, Check these two areas: 1. CHECK IC700 PIN 4 (AC-OFF) FOR 0 VOLTS DC, IF HIGH, CHECK FOR LEAKY D980 PART # 264P045040 ON THE MAIN PCB. 2. CHECK FOR 4.7 VOLTS DC AT CONNECTOR RF PIN 3 AND 4 ON THE SIGNAL PCB IF LOW SUSPECT PROBLEMS WITH THE SWITCHES/BUTTONS ON THE CONTROL PCB PART # 935D394001. 2). CHECK FOR 10 VDC AT PIN 5 OF IC502 OF LOW, CHECK IC503 PART # 270P704010 ON THE MAIN PCB. 2. CHECK R529 .82 OHM 1/2 WATT OFF PIN 4 OF THE FLYBACK. IF OPEN CHECK C411 2200 UFD @ 35V AND IC 451 PART # 270P064020. ON THE MAIN PCB. Good Luck, big IRISH.
Nov 17, 2007 | Mitsubishi VS-50603 50" Rear Projection...
Mitsubishi 50" Projection TV (Model VS-50603) Has sound but no picture
MJBNATL:
I reluctantly scheduled a technician to come out next week and take a look at my set. I was going to pay, at minimum, $65 for the service visit. I was then blessed with the intutition to do a bit more research regarding the PIP box being stuck on my television and other input functions (Inputs 1,2, and DVD) being unavailable.
I stumbled across a post on the internet that mentioned that the VS50603 can reset certain error conditions by pressing and holding the Input and Menu buttons (simulatneously) on the front panel on the TV while it is off. At some point after initiating this internal reset the LED light should starting flashing at defined intervals. The number of flashes correlate to a particular error code. Please go to the Mitsubishi website and download the owners manual (VS50609 in my case, couldn't locate VS50603) to lookup what the various error codes mean.
It seemed to me that that the LED flashing did not start immediately after pressing the Input and Menu buttons. In fact, I awoke the next morning to find the TV off but the LED flashing 10 times, pausing briefly, then flashing 10 times again. The sequence of the flashes mean something. Here again, consult your owner's guide for specifics.
Long story short, after awaking to find the LED flashing, I then turned the TV on and voila-my big screen was back minus that pesky PIP box prominently displayed.
I hope this helps someone like it helped me!! Truly a Blessing for sure.
Michael in Atlanta
Oct 27, 2007 | Mitsubishi VS-50603 50" Rear Projection...
Set won't turn on
I would check the convergence output IC`s first.
Sep 27, 2006 | Mitsubishi VS-50603 50" Rear Projection...
Televison & Video Logo
287 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
