Question about RCA D56W20 56" Rear Projection Television
Need to reset pin number for RCA D56W20 DON'T KNOW THE OLD PIN
D56W20 REAR PROJECTION TV 56 IN.
  • top5tech28 Dec 21, 2008
    solution #2 for RCA D56W20 RESETING PIN, GO TO MENU PARENTAL CONTROLS, IT ASK FOR PIN HOLD DOWN CH+ AND VOL+ AT THE SAME TIME, YOU CAN RESET YOUR PIN !!!!!
  • 837 Answers
Codes 2211 or 3308
Posted on Dec 20, 2008
Bad convergence rca d56w20
if model number is correct this is not a do it yourself repair.
Confirm actual model number and I will help you.
Nov 19, 2011 | RCA D56W20 56" Rear Projection Television
I have a rca tv d56w20.pero as I can align the convergence
Have you tried a degausser ,Generally CRT's get full of static and build up Guass, and generally get magnetized . A de-guasser will cure this. if this does not work , get back to me .K hope this helps.
Apr 12, 2011 | RCA D56W20 56" Rear Projection Television
I have a 56 inch RCA D56W20 and when i turn it on I can hear the sound, but i can't see any picture.
In menu check the Lamp Hours You may need a new lamp or the lamp has failed
Please rate my help++++Thanks for using FIXYA
Aug 13, 2010 | RCA D56W20 56" Rear Projection Television
RCA d56w20 changes aspect size and picture appears jumpy
Thats caused by the small signal board, which is actually a board known to fail when the aspect changes on its own like that. You can get replacement small signal boards at www.tvrepairworld.com
Mar 30, 2010 | RCA D56W20 56" Rear Projection Television
How do I change my parental control pin--I don't remember the one I put in
On the front of the set press the Chan + and the Vol + both in together and hold for 8 seconds the set will unlock and you can enter another code.
Nov 07, 2009 | RCA D56W20 56" Rear Projection Television
I have a 56 inch rca that blinks three timeswith a humming noise but wont turn on
The 3 blinks (an error code) and the hum (most likely from the flyback) indicate that the flyback transformer is bad and needs to be replaced as the simple way of putting it (fairly common problem with projection tvs). If you plan on doing it yourself, then you should have some electrical expertise since working in a projection tv like this can be very dangerous otherwise I would go through the local shop. Let me know how this turns out for you.
Benjamin
Jul 18, 2009 | RCA D56W20 56" Rear Projection Television
Tuner is broke off D56W20
Cost of that board is 352.00 if they are even available First CK 2 fuses thereis one on each of turner small brown rectrangle looking caps/but they arre fuses/ if they are open set will not startup.Also replace IF connector.to turner.
Dec 27, 2008 | RCA D56W20 56" Rear Projection Television
RCA D56W20 56" Rear Projection Television Logo
136 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
