Question about Motion Computing LE1600 Tablet PC
Slow not responsive Motion computing LE1600 tablet pc
I've had my LE1600 Tablet about 3 years now. Over the past few months, and more constant over the past month, my computer has been very slow and between the internet and microsoft outlook, I frequently get the message on being "not responding".
Daily, I have great difficulting in getting Microsoft outlook to open. I'll get an error message that will say,"cannot start microsoft office outllook. Unable to open the outlook window. The set of folders could not be opened. The server is not available. Contact your administerator if this condition persists" as it opens showing archive folders and then shuts down. I'll have to try and open outlook, say up to 10 times before it finally opens or I'll have to restart the computer before I can get it to open.
Should I assume that I've outlived the life of the computer (3 yrs) and need to buy a new one or is it something else? Thank you for your help and direction.
  • 73 Answers
Do you have a lot of extra programs running in the background? These are great devices, but they do not have a lot of processing power or memory. Try cleaning up unnecessary programs to see if that makes a difference.
The sure fire way to make sure there isnt anything running is a reformat. Just make sure you backup your data first.
Posted on Feb 07, 2009
Motion Computing LE1600 Tablet PC won't charge.
know of similar problems. either the cable and connection end you have or the receiving end in the tablet. can be diagnosed by getting replacement charging cable. if the problem goes away then its the cable if not it is probably the receiving end in the tablet
Apr 05, 2012 | Motion Computing LE1600 Tablet PC
I replaced the 30 G toshiba HDD that was not functioning on my LE1600 Motion tablet with a 60 G toshiba HDD and tried to install windows xp from an external CDD. It formated the drive and installed the...
Tried the same thing and got the same result using the motion computing DVD/CD external reader/burner.
Has anyone found an answer to this problem of trying to switch to a larger hard drive on the 1600 with format/installing? The new hard drive was not able to read the recovery disk with OS on it.
Thanks.
Dec 14, 2010 | Motion Computing LE1600 Tablet PC
Installation
istall the drivers manually , it will work again
May 21, 2010 | Motion Computing LE1600 Tablet PC
Hi .I am trying to Install WIN 7 on LE1600 from the USB (Enabled with Bootable Win7).I am able to boot from the USB but stucking at giving the Inputs for Regional seting at Installtion as the KEYBoard is...
As far as I am aware windows 7 has not been confirmed for tablets or win CE platform type devices
Check you manuals and any Cd's that came with the 1600 and see if there is some form of reset or original system restore ability.
Microsoft has a win7 compatibility check utility anyone wishing to try win 7 on these types of device is recommended to use that first to identify potential issues.
Sep 11, 2009 | Motion Computing LE1600 Tablet PC
USB port on docking station does not work
Power. You may find that the ower managment settings need to be changed or an external supply is needed.
May 28, 2009 | Motion Computing LE1600 Tablet PC
Have motion tablet pc 1600 , suddenly when starting up get "problem or unable to load operating system"
It could be one of several problems:
1. Bad hard drive (reasonable likely depending on age); does the hard drive make noise or spin?
2. Loose hard drive cable (less likely)
3. Virus (likely)
If it doesn't boot at all you can open up the back and make sure the hard drive is "seated" properly - that means all the connections are firmly in place. If that doesn't take care of it you will have to try and reinstall the OS.
John Hill
www.alltp.com
www.tabletpcbuzz.com
Mar 01, 2009 | Motion Computing LE1600 Tablet PC
Power port on le1600 does not charge batteries.
In some Motion LE1600 tablet pcs, the AC adapter port becomes separated from the motherboard. It will charge in the convertible keyboard or docking station because the power comes from the USB connection (for the kb) or the dock connector (for the FlexDock). Motion used to fix this by repairing the solder joint but now they just replace the motherboard (very expensive). There are ways to solder this but the repair doesn't always last unless you have someone really good do it.
Oct 24, 2008 | Motion Computing LE1600 Tablet PC
Glass replacement
A replacement display can be purchased from some sources for around $600 but you'll find that now an off-lease LE1600 can be purchased for less than that. With all the time to replace the display (about an hour for an experienced tech) I would consider buying another used unit and moving your hard drive to that rather than try and get the glass replaced.
John Hill
www.alltp.com
Aug 25, 2008 | Motion Computing LE1600 Tablet PC
Processor spped issue
Does it shift to a slower speed while operating from battery?
Dec 05, 2007 | Motion Computing LE1600 Tablet PC
Motion Computing LE1600 Tablet PC Logo
470 people viewed this question
Top Motion Computing Tablets & eReaders Experts
jason
Chris Larocque
dante
Are you a Motion Computing Tablet and eReader Expert? Answer questions, earn points and help others
