Question about Samsung DLP HL-P5663W 56" TV
T.v has a dark area on the lower part of screen
When I switch on my t.v..the image covers small part of the upper part of the t.v. after a while..the images start appearing on the lower part. it only goes upto a few centimetres from the lower part of the screen and stops there.There is a dark layer on the lower part of the screen running from left to right.i do not see all the images. Before the problem occured..there was a power blackout.the power capacitor and the posistor went.they were both replaced and this problem has remained since then.
    Genius:
  • 1,074 Answers
You are having problem in either in your vertical,horizontal circuit and power supply.have the tech check it out for repairs.good luck
Posted on Apr 02, 2007
I just replaced bulb with new and after a day there is a dark spot on the screen
I have the same TV - I have a dark spot in the upper left hand corner. I have always thought this TV was dark. Be sure to get OME lamp. Cheaper ones are not worth it and can damage your TV more.
dlplampsource,com--Just a note if this ever happens to you. TV would not come on in the AM-Had no picture, but had sound. It was not the lamp, but the safety switch. It's blue and at the bottom of the lamp housing. As soon as I flipped it and replaced the back cover, the TV came on.
Dec 22, 2012 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Vizio 55" Inconsistant Dark Screen
you have to open the back cover to check weather the screen back light need replacement. usually if the lamp is almost black in color it needs replacement. the backlight is covered with metal shield installed at the upper portion and lower portion of the panel of the tv.
Nov 01, 2012 | Vizio VF Televison & Video
With the switch in the up position(toward input screws on back) and placing the ohm meter probes; one on the upper left, one on the lower right, continuity is read. Reversing (one lead on upper right, one...
I answer questions for free.
I understand electrical devices.
It is unclear how many screws are on the switch you are testing.
If your switch does not show ohms when the switch is in one position, then it sounds like the switch is bad. But you can read information below for more information about your testing.
You can also add a comment and continue the discussion.
Let me provide more information about switches because you seem interested in electricity and the information may help us understand where the other is coming from in case you add a comment needing more help:
2 screws on switch: (excluding ground screw)
An ordinary single-pole switch usually has 2 brass colored screws.
These screws only read ohms or continuity when switch is in one position.
When the switch is in the other position, there are no ohms that pass through the switch.
3 screws on switch: (excluding ground)
A 3-way switch has 3 screws. There are 2 brass-colored screws and one dark-colored screw.
Put ohm tester on dark screw and continuity will show between the dark screw and one of the brass screws.
Flip the switch and ohms will test between dark colored screw and the other brass screw.
4 screws on switch. (excluding ground)
There are 2 screws on each side of switch.
This type of switch might be a special purpose double-pole switch.
Or it might be the more common 4-way switch.
Add a comment if you have a switch with 4 screws.
Below is a typical 3-way switch application showing the dark-colored screws:
Here is a typical 4-way switch circuit:
Notice the switch in middle has 4 screws:
Link below goes to a special application double-pole-double-throw switch:
http://waterheatertimer.org/images/30-Amp-DPDT-switch-a-800.jpg
Nov 01, 2010 | Leviton Decora Gray Rocker 4-Way AC Quiet...
Screen has dark area in upper left, and shows double images in area next to that. Is this a color gun problem? Can it be fixed easily/
Start out with replacing convergence ics -Their will be 2 of them STK392-110, use 120s Mats has them 1-800-628-1118
Let me know if you need anymore help .
Oct 05, 2010 | Hitachi 43UWX10B 43" Rear Projection...
Faint lines show up when i get dark screens in movies
First check what color of faint lines comes then reduce Screen Volts in TV of that CRT (tube)
Take off lower front cover, speaker grille of TV, there you will see focus control block that has 6 control knobs, upper 3 knobs are focus adjustment of red-green-blue CRTs and lower 3 knobs are screen volt controls for red-green-blue CRTs. Turn screen volt control knob CCW to reduce screen volts of desired CRT.
Put TV on any free AV input so screen will be dark enough to adjust screen volts.
Thanks.
Aug 28, 2009 | Sony KP-57WS500 57" Rear Projection...
Small dark area in corner of screen on Samsung HLP5085W
What you have is a lens that has been jarred loose or a plastic support melted. That's what it sounds like anyway. you may have a recall on this problem if it is common for your model. Not likely something you can fix yourself. if you are Gadget inclined you maybe able to though. check recalls first.
Jan 02, 2009 | Samsung HLP5085W 50" Rear Projection...
IMAGE TOO DARK ON GEI GRAPHIC ZOOMER POSTER BANNER SYSTEM
First I would give the optical area a good cleaning --- mirrors, lens, etc.. If this device has the 'slide' adjust for the image quality, the slide may have come out of the holder. Try seeming if the slide is seated properly. If this is the 'thumb / circle ' adjust, the POT ( value adjust on the board) may need to be reset. There is always the chance the the board is cracked or has a cold solider joint (pins) for the adjuster. IF you are inclined, that the cover off and check for crack, if no crack heat and re-solider the pins for the adjust switch.
Dec 30, 2008 | Standard Registar SD650 Color Copier
Picture darker around the edges
okay okay sir
every thing that u ve done till naow is ok
follow me
first chek the connections
if all the connections are cheked try
toend me ur model number its locate here and i will give u the full help of ur product but dont rate my help yet till i tell u that am finished okay??d4d39a7.jpg
Aug 17, 2008 | Philips 62PL9774 62 in. HDTV LCD...
Dark PIP almost covers screen
I think you have the text close caption on try turning off the close caption
good luck
May 15, 2008 | Protron PLTV-32 Television
Black Spot
Dead Pixel Test This free utility enables you to easily test your digital camera for dead and hot pixels. http://www.starzen.com/imaging/deadpixeltest.htm
Sep 12, 2005 | Fuji FinePix S7000 Digital Camera
Samsung DLP HL-P5663W 56" TV Logo
155 people viewed this question
Jerry Greenberg
Jerry Greenberg
