Question about Whirlpool GBD307PDS Electric Double Oven
We had a power outage today during the self cleaning process of our double oven.. The Electronic Oven Control panel is dead. No lights of any kind. The circuit breaker is ok. Upper door is locked.
  • 750 Answers
Turn the breaker off for 5 minutes. this will reset the system. If you still have no power then it spiked your control board and it's the board that is fried.
Please remember to leave rating before you sign off
Posted on Dec 20, 2008
No power on double oven after a storm
I have a RBD275PRS00 built in double oven. Had an electric
www.fixya.com/support/t8971528-rbd275prs00_built
Apr 16, 2011 - Had an electric storm the other night and ever since the oven won't -Whirlpool ... Question about Whirlpool RBD275PR Electric Double Oven ... For an oven to require parts after 2.5 yrs of service and 2 self cleanings tells me ... fiest press the on key see if the display comes if not the turn the power off for 5-8 ...
Whirlpool panel buzzing Ovens Questions & Answers - Fixya
www.fixya.com > Forum > Tags > panel buzzing > Ovens
Whirlpool ovens panel buzzing related questions and answers. ... the control panel on my Whirlpool electric double oven Model is RBD305PDS14? ... No power on control panel During self clean cycle the power to the panel went out. ... panel the instrument panel on an oven won't change time because of a storm problem.
Jan 01, 2016 | Whirlpool RBD275PR Electric Double Oven
Power failure control panel beeps no lights on panel and oven wont turn on. have lights on inside of oven. do i need a code, never have before. always showed PF for power failure.
Was the oven doing a self clean when the PF occurred? If so the cavity limit probably tripped.
Sometimes the owner wants to shut down the process of self clean for whatever reason that also trips the cavity limit. If the oven circuit breaker is weak then their could be a power failure during which the oven was on and that could cause the cavity limit to trip. No lights on panel means the temp inside the oven control panel exceeded normal operating temp and the small inline fuse going into the control panel has melted:
This is what that small fuse looks like. To get to the insides
you usually drop the side trim exposing the screws then the controls fold outward.
Service manual for American stoves and more
Oct 23, 2011 | Whirlpool Ovens
Replaced control panel and keypad 1 1/2 years ago seen the error codes now I was self cleaning oven everything went off no error codes or anything house breaker ok PLEASE help.
Self clean is hard on controls. I do not recommend self clean. Kills expensive parts. If the temp goes above 300 in the control panel, a control panel fuse will melt, killing the power to the control.
It looks like this:
Service manual for late model whirlpool double oven
and some more interesting oven stuff
Mar 08, 2011 | Whirlpool GBD307PDS Electric Double Oven
I used the self cleaning for the top oven of my double whirpool Accubake ovens today. It worked fine during the process. But now, after it has cooled down. The panel is not lit up with the clock etc. and I...
There is a non-resettable fuse on the back of the oven that will have to be replaced. The oven will have to be removed from the wall and the back panel removed from the oven to access the fuse.
Nov 22, 2009 | Whirlpool RBD305PD Electric Double Oven
Oven shut down during self clean. Door won't open
Cycling the power off and then on again will sometimes reset it...often you will have to call the customer service number to get the steps to take to unlock that...
Also check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Aug 21, 2009 | DCS (WOTD-227) Double Oven
Dead Whirlpool Double Oven
This happened to us the first time we used the self-cleaning feature. The repairman said we had to replace the whole electronic panel -- but when he put in the new panel it didn't work either. It turned out he just needed to replace the oven shutdown thermal fuse I believe. We finally got up enough courage to try the self-cleaning again and the exact thing happened. The door is locked and the electronic panel is dead again. So when we get it fixed we will never use the self-clean again.
Nov 05, 2008 | Whirlpool RBD305PD Electric Double Oven
Thermador SC302T clicking noise, locked door after power outage
iodine, open the upper oven, look thru the grill below the control panel on the right side and there is your model number. The issue here is that when the power came back on the oven run thru a test and your lower lock motor has failed. It will need to be replaced. Yes the only way to stop this is to shut off the breaker.
Feb 03, 2008 | Thermador SC302T Electric Double Oven
Kenmore 47779 double oven; lower oven doesn't work after self clean
Sounds like a thermal overload has opened up during clean. It may be mounted on the back.
Nov 02, 2007 | Kenmore 47772/47774/47779 Electric Double...
Whirlpool GBD307PDS Electric Double Oven Logo
419 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
