Question about One For All URC-6820 Remote Control
Remote will not work at all
Put new batteries in the remote worked to change 1 channel then stopped working
2 Suggested Answers
kaybicks
  • 85 Answers
SOURCE: RC00013 remote, channel change and power not working, how to fix?
hi,
your power button lose its contact or misplaced to its proper position. open your remote control and turn back your power button it its correct positioning. having a new one is probably the instant solution to your problem.
regards,
kaybicks
Posted on Feb 27, 2010
Tv remote wont work even though new batteries are put in.cannot change channels or volume or even turn the tv off or on
Try opening up the unit and cleaning the contacts and bottom of the buttons with a q-tip and a bit of rubbing alcohol. Over time the oil from your fingers gets inside and creates a film between the contacts and the button so the circuit will not complete and your buttons stop working.
Feb 17, 2015 | LG RU-42PX10 42 in. HD-Ready Plasma...
Magic eye light is on, but the remote control doesn't work anymore
open the remote control, and clean the keypads from oxide, corrosion, dirty.
change the batteries and put a new ones.clena the contacts batteries with pencil erase.
retight the springs contacts batteries, for better contacts. and try again.
Otherwise you must go to the repair shop TV for fix it.
God bless you
Sep 23, 2012 | Televison & Video
L32W761 32 in. LCD TV: my channel changer stopped working only the power ...
Channel changer from the remote? or from the TV? if it is from the remote, that's an easy fix, take off the batteries open the back of the remote, clean the circute board the one that is painted green, clean the remote contact pads as well the one that has a black dot like thingy with cotton balls slightly damp in rubbing alcohol, let it dry put it back together and replace with a new battery.
May 18, 2010 | Envision L32W761 32 in. LCD TV
Tv won't stop changing channels
You need to isolate the problem.
1) Unplug the set for a few seconds then plug it in.
2) Operate the TV with the control/buttons on the TV. (Channels etc)
If the TV operates correctly then do the following.
3) Try operating with the remote unit. If the problem returns then it's the remote failing.
Sometime remotes can be reset.
Try this;
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
Try it again. If the problem is still there then the remote is bad.
Since this is a new TV you should use your warranty to replace any bad parts.
Mar 16, 2009 | Vizio L32 32 in. LCD HDTV
My Panasonic Omnivision TV won't change channels...
just press Stop/Eject Rew/<< buttons (Action) to get setup menu
Sep 01, 2008 | Televison & Video
Remote control not responding
Perhaps you can try what I do when my KV24FV300 runs through channels and will not stop.  Hard to watch and remote will not work.  Nothing works but on and off from set.
Sony Says:  Take all batteries out of ALL remotes that you use in any way for that set, VCR, etc.  ALL batteries out.  Turn TV off at set.  Unplug TV.  Wait at least 15 minutes then replace all batteries in ALL remotes.  Plug TV back in and turn TV on from set.
Maybe, just maybe it will work.  If it does not work why not call Sony, they always say that cannot happen but they have a solution for it.
niteowl@dejazzd.com
Sep 30, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Can't change channels!!!!
take the batteries out of the remote...now check if you can change channels manually on the big screen. if so the remote is stuck on one signal that channel u said. get a new remote. if still same trouble on big screen look hard at the buttons and make sure none are jammed. also try to get to your setup menu and auto-program the channels it should search everything and then try changing channels. new stuff alot times plugs come loose, goes back to the factory workers...not pushing them tight have a tech check that at your home.
Aug 18, 2007 | Samsung PCJ522R 52" Rear Projection...
Televison & Video Logo
Top One For All Televison & Video Experts
Steve Allison
Steve Allison
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
