Question about Panasonic PT-47WX53 47" Rear Projection HDTV
Degassing how do you degass the television
  • Josh Crager
    Josh Crager May 11, 2010
    why? what makes you think it needs degaussing?
  • Panasonic Master
  • 5,138 Answers
You dont only signal tubes ,have degaussing sheild.What is your problem?
Posted on Dec 20, 2008
What is the name of that tube that runs from the thermostat housing behind the heat shield?
There is often a small diameter hose connected to the thermostat housing for degassing purposes usually connecting directly or indirectly to the degassing tank/coolant reservoir.
The thermostat housing also often provides a hot water outlet for the intake manifold and/or cabin heater.
The top radiator hose usually also connects to the thermostat housing.
Feb 18, 2018 | Cars & Trucks
I have a Mazda 6 2004 when I am driving the air gets hot and when I slow down it gets cold what could be the problem?
Coolant flow through the heater slows considerably at low engine speeds and can often be stopped by air or gas in the cooling system gathering in a convenient place, which in many cars is the heater, as engine speed rises the rate of flow increases and the (air) blockage can be overcome.
It is normal for gas bubbles to leak from the cylinder head gasket and a well designed cooling system will allow gas bubbles to escape easily into the degassing tank (coolant reservoir). Sometimes the degassing system becomes blocked or restricted and sometimes a failing cylinder head gasket produces more gas than the system can handle.
Dec 16, 2017 | Mazda Cars & Trucks
Kia sportage is overheating regularly
Check the coolant level, check the concentration 50/50? check the fan, radiator, thermostat and water pump.
Apr 15, 2017 | Kia Cars & Trucks
95 Acura legend LS,problem with engine overheat. changed radiator,thermostat,& most of the coolant hoses.however,the trapped air in the coolant has progressed,I was told to put a AST tank.Any thought?
Most modern engines have a degassing facility and sometimes those small ports and hoses block with silt and the small amounts of gas the head gasket has failed to seal will build up in the cooling system, displace coolant and perhaps disrupt the proper operation of the thermostat. Degassing is required to allow the gas to escape harmlessly to the space above the coolant where it eventually vents.
When a failing head gasket allows too much gas to pass into the cooling system even the degassing won't be sufficient and the thermostat operation is likely to be affected causing overheating and excess coolant displacement.
My thought in response to you mentioning trapped "air".
Feb 12, 2017 | Acura Cars & Trucks
2000 Yukon XL not blowing hot air and overheating
The two symptoms are probably connected...
There are a number of possible conditions that could cause both symptoms and the possibility two unrelated faults have coincidentally caused them should not be ignored. The possibilities should be carefully checked by a competent person to ensure the cure is no more expensive than it needs to be.
It is possible the cause is a defective cylinder head gasket leaking more combustion gas into the cooling system than the degassing system can cope with or the degassing system itself is defective. It is also possible it is a simple leak and a low coolant level.
Sep 21, 2016 | 2000 GMC Yukon XL
What can i do if my ecco tv screen is showing red colour only instead of full colour? i suspect the reason to be the external speaker that were near the tv screen
If the speakers inside the external box is not magnetically shelded type, placing it near to the TV; might cause this problem. An external degassing should be done, if it is so; as well as place the speaker boxes away from the TV too. Contact any service technician. Gopakumar Gopalan Google
May 11, 2015 | Televison & Video
Degassed tube how to fix? repair?
Do you mean de-purged tube or de-gause tube? Image intensifiers are not like CRT where they have a gausing problem. If a spot is burnt into the image intensifier, it unfortuantely is permanent.
If you mean de-purged (gasless), this can be done by a reputable service/repair workshop with nitrogen.
Aug 12, 2008 | Tasco NV200 Monocular
Powers up, but does not illuminate.
tube is most likley degassed remove lens and look at front coating on tube it should be evenely bronze tinted if it is grey and blotchy tube is degassed and has to be replaced
wayne
Jan 21, 2008 | ATN Night Scout Binocular
Colored Circles
check the degassing circuit and replace the degassing relay, then use a degausing ring to bring the colors back to normal you should be ok. good possiblity a bad solder connection at the degausing circuit themister.
Mar 17, 2007 | Panasonic CT-27HL14 27" TV
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
50 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
