Question about Dacor Preference RSD30 Gas Kitchen Range
Rsd 30
Where did you find the reset switch for the dacor rsd 30?
  • candomom May 11, 2010
    I believe I followed the instructions posted by Rotu on 11/11/06--remove the black grill that surrounds the oven door latch (it's held with 4 black phillips-head screws about 3" on either side of the latch)-I had to use a flashlight to see into the area behind the grill-as I recall there are a bunch of wires. But you will locate a small (maybe 3/8")red (mine had darkened) upright button-we had to use a screwdriver to reach it and push it back down to reset it(be sure your circuit breaker is OFF). Replace the front grill with screws , turn on the breaker and you're good to go.
I believe I followed the post by Rotu on11/11/06--remove the black grill surrounding the oven door latch (it's held on by 4 black phillips-head screws about 3" on either side of the latch). I had to use a flashlight to see into the space (there are a bunch of wires as I recall). In the middle several inches back you will see a small (about 3/8") red (mine had darkened) button. We used a screwdriver (be sure your circuit breaker is OFF) to reach it and push it down to reset. Replace the grill, turn on the breaker and you are good to go.
Posted on Dec 20, 2008
My Dacor RSD 30S has an Error Code FO
first off you need to find the description on the code see what it stands for .then a repair issue can be looked at!
Jun 19, 2013 | Dacor Preference RSD30 Gas Kitchen Range
How to increase Dacor oven door spring tension
The hinge is most likely out of adjustment as the tension should not have to be much to hold the door closed. The pivot point and the attachment to the door must be correct however.
The hinges usually have a hole exposed when you open the door to put a nail in so the hinges will be held open to work on them.
Feb 08, 2010 | Kitchen Ranges
My Dacor PGR-30 oven won't heat. It stays on 135 degrees. There are no codes set.
Called Dacor with same problem. They said the high temp switch needed to be reset but wouldn't tell me how to do it.
Looked at another site and found out how. On double oven remove grill that latch sticks out of. There should be 6 screws. On left side is a switch with a red button that faces inward. Press this button until it clicks. Test oven by turning on to see if this fixes problem. It did for me.
Rescrew grill back on being careful that the latch continues to line up with the door.
Nov 12, 2009 | Dacor Preference PGR30 Gas Kitchen Range
New Dacor Vent does not work
Hi, we have a Dacor RV 30 (I think) and twice I have had the unit go up and down endlessly until I turn the breaker off. The problem was water getting inside the switch. The first time, I got a real Dacor replacement ($80?) the next time, I got the part number off the switch, googled it and got two of them for about $4 each plus shipping.
Mar 22, 2009 | Dacor : 36" Pop-up Intake System RV36S...
Does the Dacor rsd30 have an internal circuit breaker?
Hi!!!you seem to have a problem with your hi- limit switches show here they are resetable in dacor products..just press the top of the hi-limit swith and you will be fine'' they are show here.Good luck
Jan 04, 2009 | Dacor Preference RSD30 Gas Kitchen Range
Dacor ERDS30 clock and display OK, all bake buttons non responsiv
Most likely the interuption of power is what caused the problem. try shutting down the circuit breaker that controls the range for 30 minutes then turn it back on if this does not reset the electronics. You may need to replace the keypanel and /or electronic control as either or both may have been damaged by the power surge.
Dec 31, 2008 | Dacor Epicure ERD30 Dual Fuel (Electric...
Clock is in Military time...can't change it back...
If you call Dacor they will talk you through the solution but you have to have another person ready to turn the breaker off while someone is pushing a button. I have contacted them and am trying to get the instructions emailed.
Dacor Toll free: 800-793-0093 have model # ready
Oct 11, 2008 | Dacor Preference RSD30 Gas Kitchen Range
Dacor Preference RSD30 Gas Kitchen Range Logo
236 people viewed this question
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
