Can not setup modem:Westell 6100 to router:Linksys WRT54G
I have a laptop with Window Vista and I have it setup to the modem, Westell 6100. I have like a year that I bought the router, Linksys WRT54G, but I have not been able to set it up. I get no internet connections. I tried everything, even changing the modem address. I would really like to get setup before the end of this year. If anyone has any suggestion, please let me know. Also, be very detailed because I'm still not a pro at computers.
  • janitazo Dec 20, 2008
    I know how to bridge the DSL modem. I'm good up to this part. I'm having problem getting internet connection with the router. I tried putting the set up cd and following the instruction, but no luck.
    I want to setup the router so that I can pass internet connections to the desktop computer, which has no phone jack. I do have an adapter setup already.
  • Carl Navarro
    Carl Navarro May 11, 2010
    When someone has a Westel modem, the chances are it's a DSL modem. That menas PPPoE connections and username and password. It also means you need to call tech support and have them tell you how to bridge the 6100 for your router.
    Once you've done that, you will not be able to get on the internet without the router, or you will have to know what settings to use to direct connect your computer to the modem.
    Master:
  • 382 Answers
Hi you can try it on the link below hope it helps to solve your problem.http://www.dslreports.com/faq/6323
THanks.
Posted on Oct 07, 2011
  • 20 Answers
I think the best way is to describe to you the physical setup first. so you have a computer, a modem, and a router. the setup should be like this: from the walljack, the phonecable is connected to the 6100, make sure there are no micro filters connected between the walljack and the phone line because it will not allow you to connect to the dsl. from the modem, the data/internet cable at the back of it, using an ethernet cable, should be connected to the router. and at the back of the router E1 to E4, another ethernet cable is connected there and the other end of the cable is to be connected to your computer. you are right in bridging the modem, the reason for that is because both the westell 6100 and router have GUI's or Graphical User Interfaces, in short, they each have their own virtual brain. you will not have a connection if both of them have this GUI thing, so you need to bridge your westell 6100, so that the only GUI active is the routers. to bridge the modem you may need assistance from tech support of your ISP provider. assuming that's done, light status in your 6100 should have a solid DSL light. for the router, it should have lights in WAN, WLAN if you want to connect wirelessly and E1 to E4, whichever ethernet port you're using for a wired connection. you have to access the GUI of the router to make sure you have a routable WAN IP Address. As for the IP address in your computer, it should be a 192.168.x.xxx type of ip address. this is the LAN IP Address. Basically you need to have routable WAN and LAN IP Addresses to be able to connect online. you will need to configure the GUI of your router to be able to do this. for that you may need assistance from tech support of the router or if you can follow the instructions in the manual, by all means do so. the most important thing in this setup is bridging the modem.
Posted on Dec 20, 2008
How can i connect my linksys router to a westell modem
  • Cat 5 cable from Westell to Linksys to computer(s)
  • Enter the Linksys setup page in your browser window, see manual for setup page IP address 192.168.x.x ?
  • setup your WEP key and SSID if your are using wireless
Mar 22, 2011 | Linksys Wireless-G WRT54G Router
I have a linksy cisco and westell model 6100 and the wifi is not working-- i can only access the internet when i hook up my computer to my westell model--- whats wrong with my wifi?
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Jan 13, 2010 | Linksys Wireless-G WRT54G Router
Will not communicate with the westell modem 6100
You can reset first the router and reconfigure it back, to reset the router press and hold the reset button of the router for 10 seconds while power is ON and then after that reconfigure it back..........
Nov 02, 2009 | Linksys Wireless-G WRT54GS Router...
DSL line disconnects on WRT54GS only
Try to change the LAN IP address of your router to 192.168.2.1 by accessing the router's Setup page. You also need to set your Westell modem to "full-bridge mode". You need to ask assistance from your ISP to bridge the modem. After that, set-up the Linksys router to PPPoE then power cycle it.
Apr 15, 2009 | Linksys Wireless-G WRT54G Router
I have a westell 6100 and I have a linksys wireless-g 2.4 ghz broadband router. Not sure how to hook the router to the 6100
just set it up as a passive style and do not let it log on to your isp it should default to this setting if you plug it up and do not run the setup software
Apr 12, 2009 | Westell Wirespeed LiteLine 6100...
Ps3 key change timeout using westell 6100 modem on verizon
there might be a problem with the Linksys router, the Westell 6100 should be 1st set to bridge mode in order for your router to be connected to it. or there could also be a proble on the Verizon server.
Apr 10, 2009 | Westell Wirespeed LiteLine 6110 Modem
Need to redo wireless setup betw linksys & westell
You will need to assign a different ip address to the Westell modem - I am assuming that both the router & modem are using the same ip address 192.168.1.1? If that is the case, then assign 192.168.1.2 to the modem.
Mar 15, 2009 | Linksys Wireless-G WRT54G Router
Setup Wireless Router to Westell 6100 modem
Your Wireless router should have come with a CD. Insert the CD into your computer and follow it step by step. If it did not come with it here is a basic wiring setup.
From wall jack to Westell modem, From modem to uplink port on Max G router.
Reboot Westell modem. T
Everything should auto-configure unless you need a username and password for your DLS. If so you will need to program this into your router.
Dec 21, 2008 | U.S. Robotics MAXg USR5461 (738168036790)...
Get no connection useing 6100 modem connected to wireless B router
Hi starman re westell 6100.
Hi i hope you have find solution with your issue ifnot let me walk you through on how to get it up and working.
First , you need to connect your modem directly to your computer. We need to access its Graphic Unit Interface by opening your browser and type onyour address bar its default gateway.
The def. gateway can be 192.168.1.1 or depending what ISP youre connected to . For ATT broadband its 192.168.1.254 / verizon broadband is 192.168.1.1..  { onyour address bar : type in 192.168.1.1 and hit Enter.
to check def gateway : you can go to start > run > cmd then enter > on DOS command type in ipconfig /all  then HIT enter > itl provide you your network list > your default gateway is your westell modem or if your linksys is connected than it should be you linksys.
Itl route you to your westell page. Try to go to  Broadband and choose connection or configure connection.button. Look for configure and by default you will see its in PPPoE> change it to bridged ethernet and save.
By enabling bridge to your modem w/c is westell youl have a chance to configure you linksys to PPPoE.
Connect you westell to your linksys and on your computer try to check your default gateway as seen above. By default linksys can be access by typing in 192.168.2.1 or 192.168.1.1. Itl prompt you for UN and PW: by default your Username is : Blank and Password should be admin. { blank = dont type anything}
On your linksys SETUP page > by default it is set to DHCP or obtain IP address automatically. Pls change it to PPPoE and type in your UN and PW : username@isp { your ISP name}. and hit save settings or save.
Restart your linksys and try to browse to check fore connection.
For all types of modem such as westell : you need to set it to bridge mode first foryou wireless router to work ie linksys. Set linksys to PPPoE .. that should work .
For more detailed steps or questions re: this issue pls dont hestiate contact me. Best wishes.
Pls enable you Wireless Encryption for your home network security.
Ciao .
Prince
May 21, 2008 | Westell Wirespeed LiteLine 6100...
Computers & Internet Logo
1,551 people viewed this question
David Payne
David Payne
